- 6
- 2002-10-11
上次做设计的时候,高人给的资料
Distribution of an SQL Toolkit Executable or DLL
The following files must be distributed with an executable or DLL that
uses SQL Toolkit instrument driver functions.
1) The following files need to be placed into the Windows system directory.
IVCD.LIC ODBC driver license file
cvidb32.dll sql toolkit dll
cviauto.dll ActiveX automation dll
Note: You cannot redistribute the database driver files included in the
SQL Toolkit without purchasing a LabWindows/CVI SQL Toolkit Database Driver
Run-Time License. Contact National Instruments for further information
regarding database driver file redistribution and LabWindows/CVI SQL Toolkit
Database Driver Run-Time License purchasing.
2) You must distribute the Microsoft Data Access Components(MDAC/ADO). You
can freely distribute and install MDAC 2.0 (MDAC_MIN.EXE located in the
root directory of the SQL toolkit directory). The error "Error loading
database dll" will occur if it is not properly installed.
The latest version of MDAC is available from Microsoft's web site at
http://www.microsoft.com/data/.
Many new products from Microsoft install MDAC. Such products include
Internet Explorer 5 and newer versions of Microsoft Office and Microsoft
development environments.
To determine which version of MDAC is installed on a system, check the
version numbers of the following specific .dll files associated with MDAC.
The following table summarizes what file versions correspond to which
MDAC versions.
MDAC version Msdadc.dll Oledb32.dll
MDAC 1.5c 1.50.3506.0 N/A
MDAC 2.0 2.0.3002.4 2.0.1706.0
MDAC 2.0 SP1 2.0.3002.23 2.0.1706.0
MDAC 2.0 SP2 2.0.3002.23 2.0.1706.0
MDAC 2.1.0.3513.2 (SQL Server) 2.10.3513.0 2.10.3513.0
MDAC 2.1.1.3711.6(Explorer 5) 2.10.3711.2 2.10.3711.2
MDAC 2.1.1.3711.11 (GA) 2.10.3711.2 2.10.3711.9
MDAC 2.1.2 (GA) 2.10.4202.0 2.10.4202.0
