/PREP7
CGOMGA,0,0,0,
CGLOC,0,1e-010,0,
FLDATA35,VFTO,VOFL,1e-005,
FLDATA35,VFTO,VOFU,1e-005,
FLDATA35,VFTO,LAML,0.01,
FLDATA35,VFTO,LAMU,0.01,
FLDATA35,VFTO,TRBL,0.1,
FLDATA35,VFTO,TRBU,0.1,
G***DATA, F,0,MX,0,MY,1000,
G***DATA, F,0,MX,0,MY,-1000,
FLST,5,26,5,ORDE,2
FITEM,5,27
FITEM,5,-52
CM,_Y,AREA
ASEL,R, , ,P51X
CM,_Y1,AREA
CMSEL,S,_Y
CMDELE,_Y
DA,_Y1,VY,100,1
CMDELE,_Y1
FINISH
/SOL
SOLVE
FINISH
/POST1
SET,LAST
/VSCALE,1,1,0
PLVECT,V, , , ,VECT,ELEM,ON,0
PRNSOL,PRES
NSORT,PRES, ,0,0, ,0
FINISH
/SOL
FINISH
/PREP7
FLST,5,26,5,ORDE,2
FITEM,5,27
FITEM,5,-52
CM,_Y,AREA
ASEL,R, , ,P51X
CM,_Y1,AREA
CMSEL,S,_Y
CMDELE,_Y
/GO
DA,_Y1,PRES,0,1
CMDELE,_Y1
VPLOT
FINISH
/SOL
SOLVE
FINISH
/POST1
SET,LAST
/VSCALE,1,1,0
/EFACET,1
PLNSOL, PRES,, 0
FINISH
/PREP7
FLST,5,26,5,ORDE,2
FITEM,5,27
FITEM,5,-52
CM,_Y,AREA
ASEL,R, , ,P51X
CM,_Y1,AREA
CMSEL,S,_Y
CMDELE,_Y
DA,_Y1,VY,100,1
CMDELE,_Y1
FINISH
/SOL
/BATCH
/COM,ANSYS RELEASE 9.0 UP20041104 11:32:36 07/29/2005
RESUME,'fenshan1','db','.'
/COM,ANSYS RELEASE 9.0 UP20041104 11:32:37 07/29/2005
/REPLOT,RESIZE
/SOLU
SOLVE
FINISH
/POST1
SET,LIST
SET,LAST
/EFACET,1
PLNSOL, V,SUM, 0
VPLOT
/EFACET,1
PLNSOL, V,SUM, 0
/EFACET,1
PLNSOL, PRES,, 0
/VSCALE,1,1,0
FINISH
/PREP7
G***DATA, F,0,MX,0,ROTY,360,
FLST,5,26,5,ORDE,2
FITEM,5,27
FITEM,5,-52
CM,_Y,AREA
ASEL,R, , ,P51X
CM,_Y1,AREA
CMSEL,S,_Y
CMDELE,_Y
DA,_Y1,VY,-100,1
CMDELE,_Y1
FLST,5,26,5,ORDE,2
FITEM,5,27
FITEM,5,-52
CM,_Y,AREA
ASEL,R, , ,P51X
CM,_Y1,AREA
CMSEL,S,_Y
CMDELE,_Y
FLST,5,26,5,ORDE,2
FITEM,5,27
FITEM,5,-52
CM,_Y,AREA
ASEL,R, , ,P51X
CM,_Y1,AREA
CMSEL,S,_Y
CMDELE,_Y
DA,_Y1,UY,-100,1
CMDELE,_Y1
FLST,5,10774,1,ORDE,2
FITEM,5,1
FITEM,5,-10774
CM,_Y,NODE
NSEL,R, , ,P51X
CM,_Y1,NODE
CMSEL,S,_Y
CMDELE,_Y
BF,_Y1,FORC, ,-100,
CMDELE,_Y1
FLDATA4,TIME,METH,BACK
FLDATA,ADVM,MOME,SUPG
FLDATA,ADVM,TURB,SUPG
FLDATA,ADVM,PRES,MSU
FLDATA,ADVM,TEMP,SUPG
FLDATA18,METH,PRES,3
FLDATA22,MAXI,PRES,1000,
FLDATA20,SRCH,PRES,2
FLDATA21,CONV,PRES,1e-012,
FLDATA23,DELT,PRES,1e-010,
KEYOPT,1,3,0
CGOMGA,0,-1000,0,
CGLOC,0,1e-010,0,
FINISH
/SOL
RSYMM,DEFINE, 0, , ,
RSURF,DEFINE, ,2,
SOLVE
FINISH
/POST1
SET,LAST
SET,LAST
/EFACET,1
PLNSOL, V,SUM, 0
/EFACET,1
PLNSOL, PRES,, 0
/VSCALE,1,1,0
/ANNO,REFR
/ANNO,REFR
PLVE,V,
ANTIME,10,0.5, ,1,0,0,0
FINISH
/PREP7
FSTI,1,0,
FSDT,1,
FSAN,0
FSOR,FLUID
FSTR,FLUID,TRAN
FSTR,SOLID,TRAN
FSIN,NONC
MFTI,0.5,
MFDT,1,
MFRS,100,
VPLOT
FINISH
/SOL
SOLVE
FINISH
/POST1
SET,LAST
/VSCALE,1,1,0
/EFACET,1
PLNSOL, V,SUM, 0
/EFACET,1
PLNSOL, PRES,, 0
/EFACET,1
PLNSOL, V,X, 0
/EFACET,1
PLNSOL, V,Y, 0
/EFACET,1
PLNSOL, V,Z, 0
/EFACET,1
PLNSOL, ENKE,, 0
/EFACET,1
PLNSOL, STRM,, 0
/EFACET,1
PLNSOL, DENS,, 0
PLNSOL,V,SUM
ANCNTR,10,0.5
PLNSOL,VISC,
ANCNTR,10,0.5
TRTIME,2,0, ,0,0,
PRNSOL,V,COMP
PRESOL,ELEM
/SHOW,WIN32C
SET,FIRST
/PLOPTS,INFO,3
/CONTOUR,ALL,18
/PNUM,MAT,1
/NUMBER,1
/REPLOT,RESIZE
PLVE,V,
eplot
eplot
! /UIS,ABORT,1
/SHOW,WIN32
/REPLOT,RESIZE
/DIST,1,1.08222638492,1
/REP,FAST
/REP,FAST
/REP,FAST
/DIST,1,0.924021086472,1
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
FINISH
! /EXIT,NOSAV
/BATCH
/COM,ANSYS RELEASE 9.0 UP20041104 16:16:59 07/29/2005
/PREP7
CGOMGA,0,0,0,
CGLOC,0,1e-010,0,
FLST,2,26,5,ORDE,2
FITEM,2,27
FITEM,2,-52
DADELE,P51X,PRES
APLOT
FLST,5,26,5,ORDE,2
FITEM,5,27
FITEM,5,-52
CM,_Y,AREA
ASEL,R, , ,P51X
CM,_Y1,AREA
CMSEL,S,_Y
CMDELE,_Y
/GO
DA,_Y1,PRES, ,1
CMDELE,_Y1
FLST,5,26,5,ORDE,2
FITEM,5,27
FITEM,5,-52
CM,_Y,AREA
ASEL,R, , ,P51X
CM,_Y1,AREA
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
FINISH
/SOL
FINISH
/PREP7
FINISH
/SOL
SOLVE
/COM,,Steady State Analysis,0
FLDATA2,ITER,EXEC,100,
FLDATA2,ITER,OVER,0,
FLDATA2,ITER,APPE,0,
FLDATA3,TERM,VX,0.01,
FLDATA3,TERM,VY,0.01,
FLDATA3,TERM,VZ,0.01,
FLDATA3,TERM,PRES,1e-008,
FLDATA3,TERM,TEMP,1e-008,
FLDATA3,TERM,ENKE,0.01,
FLDATA3,TERM,ENDS,0.01,
FLDATA5,OUTP,SUMF,10,
SOLVE
FINISH
/POST1
SET,LAST
SET,LAST
/VSCALE,1,1,0
/EFACET,1
PLNSOL, V,SUM, 0
FINISH
/PREP7
FLST,5,26,5,ORDE,2
FITEM,5,27
FITEM,5,-52
CM,_Y,AREA
ASEL,R, , ,P51X
CM,_Y1,AREA
CMSEL,S,_Y
CMDELE,_Y
DADELE,_Y1,VX
DADELE,_Y1,VY
DADELE,_Y1,VZ
CMDELE,_Y1
FINISH
/POST1
FINISH
/SOL
FLDATA2,ITER,EXEC,15,
SOLVE
FINISH
/POST1
SET,LAST
/VSCALE,1,1,0
/EFACET,1
PLNSOL, V,SUM, 0
/EFACET,1
PLNSOL, PRES,, 0
/VSCALE,1,1,0
/VIEW,1,1,2,3
/ANG,1
/REP,FAST
/VIEW,1,1,1,1
/ANG,1
/REP,FAST
/ANG,1,30,XS,1
/REP,FAST
/ANG,1,-30,XS,1
/REP,FAST
/ANG,1,-30,XS,1
/REP,FAST
/ANG,1,-30,XS,1
/REP,FAST
FINISH
/PREP7
G***DATA, F,0,MX,0,MY,100000,
FLDATA12,PROP,DENS,6
FLDATA13,VARY,DENS,0
FLDATA12,PROP,VISC,6
FLDATA13,VARY,VISC,0
FLDATA12,PROP,COND,0
FLDATA13,VARY,COND,0
FLDATA12,PROP,SPHT,0
FLDATA13,VARY,SPHT,0
FLDATA7,PROT,DENS,AIR-MM
FLDATA8,NOMI,DENS,-1
FLDATA9,COF1,DENS,0
FLDATA10,COF2,DENS,0
FLDATA11,COF3,DENS,0
FLDATA7,PROT,VISC,AIR-MM
FLDATA8,NOMI,VISC,-1
FLDATA9,COF1,VISC,0
FLDATA10,COF2,VISC,0
FLDATA11,COF3,VISC,0
FLDATA12,PROP,IVIS
FLDATA7,PROT,COND,CONSTANT
FLDATA8,NOMI,COND,-1,
FLDATA9,COF1,COND,0
FLDATA10,COF2,COND,0
FLDATA11,COF3,COND,0
FLDATA7,PROT,SPHT,CONSTANT
FLDATA8,NOMI,SPHT,-1,
FLDATA9,COF1,SPHT,0
FLDATA10,COF2,SPHT,0
FLDATA11,COF3,SPHT,0
FLDATA12,PROP,DENS,4
FLDATA12,PROP,VISC,4
FLDATA7,PROT,DENS,AIR-SI
FLDATA9,COF1,DENS,0
FLDATA7,PROT,VISC,AIR-SI
FLDATA9,COF1,VISC,0
FLDATA12,PROP,IVIS
FLDATA9,COF1,COND,0
FLDATA9,COF1,SPHT,0
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDE,DENS,1
MPDATA,DENS,1,,1.23
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDE,VISC,1
MPDATA,VISC,1,,1.79E-005
LSCLEAR,ALL
G***DATA, F,0,MX,0,MY,100,
VPLOT
/VIEW,1,1,1,1
/ANG,1
/REP,FAST
G***DATA, F,0,MX,0,MY,-100,
FLST,5,26,5,ORDE,2
FITEM,5,27
FITEM,5,-52
CM,_Y,AREA
ASEL,R, , ,P51X
CM,_Y1,AREA
CMSEL,S,_Y
CMDELE,_Y
/GO
DA,_Y1,PRES, ,1
CMDELE,_Y1
FLST,5,26,5,ORDE,2
FITEM,5,27
FITEM,5,-52
CM,_Y,AREA
ASEL,R, , ,P51X
CM,_Y1,AREA
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
FLST,5,26,5,ORDE,2
FITEM,5,27
FITEM,5,-52
CM,_Y,AREA
ASEL,R, , ,P51X
CM,_Y1,AREA
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
FINISH
/SOL
SOLVE
FLDATA2,ITER,EXEC,300,
SOLVE
FINISH
/PREP7
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDE,DENS,1
MPDATA,DENS,1,,1.23
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDE,VISC,1
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDE,DENS,1
MPDATA,DENS,1,,1.23
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDE,DENS,1
MPDATA,DENS,1,,1.23e-3
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDE,VISC,1
MPDATA,VISC,1,,1.78e-8
FLDATA9,COF1,DENS,0
FLDATA9,COF1,VISC,0
FLDATA12,PROP,IVIS
FLDATA9,COF1,COND,0
FLDATA9,COF1,SPHT,0
FINISH
/SOL
SOLVE
FLDATA2,ITER,EXEC,30,
FINISH
/POST1
SET,LAST
/VSCALE,1,1,0
/ANG,1,-30,XS,1
/REP,FAST
/ANG,1,-30,XS,1
/REP,FAST
/ANG,1,30,XS,1
/REP,FAST
/ANG,1,30,XS,1
/REP,FAST
SAVE
SAVE
/EFACET,1
PLNSOL, PRES,, 0
/EFACET,1
PLNSOL, V,SUM, 0
PLVFRC,0
PLNSOL,V,SUM
ANCNTR,10,0.5
PLNSOL,U,SUM
ANCNTR,10,0.5
/VSCALE,1,1,0
PLVECT,V, , , ,VECT,ELEM,ON,1
VPLOT
VPLOT
/VSCALE,1,1,0
/REP,FAST
/REP,FAST
/EFACET,1
PLNSOL, PRES,, 0
/VIEW,1,1,1,1
/ANG,1
/REP,FAST
/VIEW,1,1,2,3
/ANG,1
/REP,FAST
PLNSOL,V,SUM
ANCNTR,10,0.5
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/VSCALE,1,1,0
/VIEW,1,1,1,1
/ANG,1
/REP,FAST
/REP,FAST
/REP,FAST
/ANG,1,-30,YS,1
/REP,FAST
/ANG,1,-30,YS,1
/REP,FAST
/ANG,1,-30,YS,1
/REP,FAST
/ANG,1,-30,YS,1
/REP,FAST
/ANG,1,-30,YS,1
/REP,FAST
/ANG,1,-30,YS,1
/REP,FAST
/ANG,1,-30,YS,1
/REP,FAST
/ANG,1,-30,YS,1
/REP,FAST
/ANG,1,-30,YS,1
/REP,FAST
/ANG,1,-30,YS,1
/REP,FAST
/ANG,1,-30,YS,1
/REP,FAST
/ANG,1,-30,YS,1
/REP,FAST
/ANG,1,-30,YS,1
/REP,FAST
/ANG,1,-30,YS,1
/REP,FAST
/ANG,1,-30,YS,1
/REP,FAST
/ANG,1,-30,YS,1
/REP,FAST |
