- 2004-9-11
老是说我存储器不够,咋回事吗?我上火了!各位大哥,帮忙啊!
Date: 08/19/2005 Time: 21:48:38
___________________________________________________
| Livermore Software Technology Corporation |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Version: 970 Date: 08/13/2003 |
| Revision: 3858 Time: 00:02:26 |
| Features enabled in this version: |
| ANSYS Database format |
| Shared Memory Parallel |
| Licensed to: |
| Platform : |
| OS Level : WINDOWS XP |
| Hostname : ljxin |
| Precision : Single precision (I4R4) |
| Unauthorized use infringes LSTC copyrights |
SCALE FACTOR for file size = 7
new file size = 1835008
Use this scale factor on all restarts.
Input file: x0819.k
expanding memory to 8500000
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Explicit Finite Element code. *
* the validity, accuracy, or applicability of any results *
* obtained from this system. The user must verify his own *
* results. *
* LSTC endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LSTC through your site focus. *
* Copyright (C) 1990-2003 *
* by Livermore Software Technology Corp. (LSTC) *
* All rights reserved *
contracting memory to 878808
expanding memory to 1737616
expanding memory to 2011234
expanding memory to 5902870
expanding memory to 5927870
expanding memory to 5987870
expanding memory to 6018888
expanding memory to 6080388
expanding memory to 6100388
expanding memory to 6120388
expanding memory to 6140388
expanding memory to 6160388
expanding memory to 6180388
expanding memory to 6200388
expanding memory to 6220388
expanding memory to 6240388
expanding memory to 6260388
expanding memory to 6280388
expanding memory to 6301094
expanding memory to 6322894
expanding memory to 6342975
expanding memory to 6362975
expanding memory to 6383075
expanding memory to 6403175
expanding memory to 6423275
expanding memory to 6443375
expanding memory to 8202094
expanding memory to 8246697
expanding memory to 8291300
expanding memory to 8335903
expanding memory to 12182539
*** Error Memory is set 3682539 words short
increase the memory size.
Current memory size 8500000
T i m i n g i n f o r m a t i o n
CPU(seconds) %CPU Clock(seconds) %Clock
Initialization ....... 0.0000E+00 0.00 0.0000E+00 0.00
Element processing ... 0.0000E+00 0.00 0.0000E+00 0.00
Binary databases ..... 0.0000E+00 0.00 0.0000E+00 0.00
ASCII database ....... 0.0000E+00 0.00 0.0000E+00 0.00
Contact algorithm .... 0.0000E+00 0.00 0.0000E+00 0.00
Contact entities ..... 0.0000E+00 0.00 0.0000E+00 0.00
Rigid bodies ......... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Nonlinear ... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Lin. Alg. ... 0.0000E+00 0.00 0.0000E+00 0.00
T o t a l s 0.0000E+00 0.00 0.0000E+00 0.00
Problem time = 0.0000E+00
Problem cycle = 0
Total CPU time = 0 seconds ( 0 hours 0 minutes 0 seconds)
CPU time per zone cycle = 0 nanoseconds
Clock time per zone cycle= 0 nanoseconds
Number of CPU's 0
Start time 08/19/2005 21:48:38
End time 08/19/2005 21:48:43
Elapsed time 5 seconds ( 0 hours 0 minutes 5 seconds)
E r r o r t e r m i n a t i o n |
