- 73
- 2005-5-26
发表于 2005-10-31 13:25:35
来自 湖北武汉
Re:MATLAB进行图像分割问题
你的版本不是7.0的吧,很多函数没有。
help imregionalmin
IMREGIONALMIN Compute regional minima of I.
BW = IMREGIONALMIN(I) computes the regional minima of I. The output
binary image BW has value 1 corresponding to the pixels of I that belong
to regional minima and 0 otherwise. BW is the same size as I.
Regional minima are connected components of pixels with the same
intensity value, t, whose external boundary pixels all have a value
greater than t.
By default, IMREGIONALMIN uses 8-connected neighborhoods for 2-D
images and 26-connected neighborhoods for 3-D images. For higher
dimensions, IMREGIONALMIN uses CONNDEF(NDIMS(I),'maximal').
BW = IMREGIONALMIN(I,CONN) computes the regional minima of I using
the specified connectivity. CONN may have the following scalar
values:
BW = IMREGIONALMIN(I,CONN) computes the regional minima using the
specified connectivity. CONN may have the following scalar values:
4 two-dimensional four-connected neighborhood
8 two-dimensional eight-connected neighborhood
6 three-dimensional six-connected neighborhood
18 three-dimensional 18-connected neighborhood
26 three-dimensional 26-connected neighborhood
Connectivity may be defined in a more general way for any dimension by
using for CONN a 3-by-3-by- ... -by-3 matrix of 0s and 1s. The 1-valued
elements define neighborhood locations relative to the center element of
CONN. CONN must be symmetric about its center element.
Class support
I can be of any nonsparse numeric class and any dimension. BW is
always logical.
Example
A = 10*ones(10,10);
A(2:4,2:4) = 3; % minima 3 lower than surround
A(6:8,6:8) = 8 % minima 8 lower than surround
regmin = imregionalmin(A)
See also conndef, imimposemin, imreconstruct, imregionalmax.
Reference page in Help browser
doc imregionalmin |
