- 6
- 2005-5-31
*** WARNING *** SUPPRESSED MESSAGE CP = 3.375 TIME= 20:26:15
Element 1 references undefined MURX or BH table for material 1.
Element 2350 references undefined MURX or BH table for material 2.
*** WARNING *** SUPPRESSED MESSAGE CP = 4.547 TIME= 20:26:18
Max. Friction coef. 0.3 is defined in the model. Switch to the
unsymmetric solver (NROP,UNSYM) instead if convergence difficulty is
encountered.
*** WARNING *** SUPPRESSED MESSAGE CP = 13.203 TIME= 20:27:00
There are 3 small equation solver pivot terms. May be a transitional
effect caused by the Newton-Raphson logic.
*** WARNING *** SUPPRESSED MESSAGE CP = 18.328 TIME= 20:27:31
The calculated reference FORCE CONVERGENCE VALUE = 7.967645729E-13 is
less than the default minimum of 1 (MINREF field of CNVTOL command).
Check results carefully.
The calculated reference HT FLOW CONVERGENCE VALUE= 0 is less than the
default minimum of 1E-6 (MINREF field of CNVTOL command). Check
results carefully.
*** ERROR *** SUPPRESSED MESSAGE CP = 22.703 TIME= 20:28:07
The analysis type must not be changed after the first load step.
For a new analysis, FINISH now and reenter /SOLUTION.
搞的我丈二的和尚摸不着头~~~~ |
