The first part is APDL commands file
ATTACHMENT—APDL file
1. APDL for the tank with flat end
!! setting the background of the window
WPSTYLE,,,,,,,,0
/RGB,INDEX,100,100,100, 0
/RGB,INDEX, 80, 80, 80,13
/RGB,INDEX, 60, 60, 60,14
/RGB,INDEX, 0, 0, 0,15
!recovery the original background color
! /RGB,INDEX, 0, 0, 0, 0
! /RGB,INDEX, 60, 60, 60,13
! /RGB,INDEX, 80, 80, 80,14
! /RGB,INDEX,100,100,100,15
/PMETH,OFF,0
KEYW,PR_SET,1
KEYW,PR_STRUC,1
/UNITS,SI
/title, Assignment #3 E563
WPSTYLE,,,,,,,,0
FINISH
/PREP7
Diff=0.2 !!! tolerance for exact location
!ET,1,SOLID45 !! solid95 node limit
!Et,2,solid95
!et,1,plane42
et,1,shell93
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,200000
MPDATA,PRXY,1,,0.3
MPDATA,DENS,1,,7.85E-6
FINISH
/PREP7
/REPLOT,RESIZE
!K,1,500,,,
K,1,502.5,1252.5,,
k,3,502.5,1252.5-502.5,,
K,2,0,1252.5,,
!LFILLT,2,1,25, ,
!LSEL,ALL
KSEL,ALL
KSYMM,Y,ALL, , , ,0,0
LSTR,1,2
LSTR,1,3
lstr,3,6
LSTR,6,4
lstr,5,4
LFILLT,1,2,25, ,
LFILLT,4,5,25, ,
lsel,all
aROTAT,all, , , , , ,2,5 ,180,1,
allsel,all
/VIEW,1,1,1,1
/ANG,1
wpro,,,-90
!wpro,90
WPRO,180
wpro,180
CSWPLA,11,1,
cswpla,12,0
csys,12
k,200,0,-152.5,0
k,201,0,-152.5,-680
k,202,0,0,-680
k,203,0,0,0
L,200,201
L,201,202
!l,200,203
FLST,2,2,4,ORDE,2
FITEM,2,21
FITEM,2,-22
FLST,8,2,3
FITEM,8,202
FITEM,8,203
AROTAT,P51X, , , , , ,P51X, ,180,1,
allsel,all
aptn,all
asel,s,area,,10,13,3
ADELE,all, , ,1
/VIEW, 1, -0.424968791673 , -0.295430929554 , -0.855641333718
/ANG, 1, -93.4021764054
lplot
/image,save,model_line,bmp,
erase
allsel,all
aplot
/image,save,model_area,bmp,
R,1,5,
R,2,50,
ASEL, , , , 9
AATT, 1, 2, 1, 0,
allsel,all
asel,u,area,,9
AATT, 1, 1, 1, 0,
CSYS,0
LSEL,S,LOC,Z,-300+DIFF,-1250-5-DIFF
lesize,all,,,36
type,1
mat,1
SMRT,4
MSHAPE,1,2D
MSHKEY,0
asel,all
amesh,all
erase
eplot
/image,save,model_element,bmp,
/SOL
ANTYPE,0
!!! ############ APPLYING CONSTRAINTS
csys,0
lsel,s,loc,z,-diff,diff
dl,all,,symm
CSYS,0
kSEL,s,LOC,y,2500/2-500-5,2500/2-500+5
kSEL,R,LOC,X,-500-DIFF,-505+DIFF
nslk,s
D,all,ux,0
CSYS,0
kSEL,s,LOC,y,-(2500/2-500-5),-(2500/2-500+5)
nslk,s
D,all,all,0
!! gravity applied
ACEL,9.8,0,0,
!!! ######### APPLYING LOADS
!!! selecting inside surfaces to be loaded with pressure
allsel,all
asel,u,area,,7,14,7
SFA,all,1,PRES,2 !!! not 20 MPa!
asel,s,area,,7,14,7
sfa,all,1,pres,-2
allsel,all
/PSF,PRES,NORM,2,0,1
/PBF,TEMP, ,1
/PIC,DEFA, ,1
aplot
/image,save,model_loadconst,bmp,
solve !!! success!
!!!____________________________________
!!! ##### STARTING POSTPROCESS #####
*GET,total_Node_number,NODE,,NUM,MAX ! CURRENT MAXIMUM NODE NUMBER
*get,total_element_number,elem,,num,max !! CURRENT MAXIMUM elem NUMBER
!#### starting the process of postprocess ####
allsel,all
/post1
/DSCALE,1,1
pldisp,1
/image,save,deflection_contour,bmp,
/DSCALE,1,1
PLNSOL, U,SUM, 0,1.0
/image,save,maxdisp,bmp, !!! displacement vector sum
erase
/post1
plnsol,s,1,
/image,save,principal1,bmp,
erase
/post1
plnsol,s,2,
/image,save,principal2,bmp,
erase
/post1
plnsol,s,3,
/image,save,principal3,bmp,
erase
/post1
plnsol,s,int,
/image,save,maxsint,bmp,
erase
/post1
plnsol,s,eqv,
/image,save,maxseqv,bmp,
!!! exploring local plot for nozzle
FLST,5,3,5,ORDE,3
FITEM,5,9
FITEM,5,14
FITEM,5,-15
ASEL,S, , ,P51X
aplot
nsla,s
esla,s
plnsol,s,int
/image,save,localsint,bmp,
plnsol,s,eqv,
/image,save,localseqv,bmp,
/image,save,localUsum,bmp,
pldisp,1
/image,save,localdisp,bmp,
!! ### define the max. value and the points of max. quantities
allsel,all
nsort,s,eqv
*get,Max_SEQV_value,sort,,max
*get,node_number_max_Seqv,sort,0,imax !!! the node number of max. Von Mises stress
nsort,s,int
*get,max_Sint_value,sort,,max
*get,node_number_max_Sint,sort,0,imax !!! the node number of max. stress intensity
nsort,u,sum
*get,max_Disp_value,sort,,max
*get,node_number_max_Disp,sort,0,imax !!! the node number of max. Displacement
*get, maxdisp_x,node,node_number_max_disp,loc,x
*get, maxdisp_y,node,node_number_max_disp,loc,y
*get, maxdisp_z,node,node_number_max_disp,loc,z
*get, maxseqv_x,node,node_number_max_seqv,loc,x
*get, maxseqv_y,node,node_number_max_seqv,loc,y
*get, maxseqv_z,node,node_number_max_seqv,loc,z
*get, maxsint_x,node,node_number_max_sint,loc,x
*get, maxsint_y,node,node_number_max_sint,loc,y
*get, maxsint_z,node,node_number_max_sint,loc,z
!!_______________________________________________________
!!! #### graph the von-mises stress distribution of the plate
allsel,all
/POST1
CSYS,0
!! ### point of maximum stress over the plate
!!! %%% checking -->list-->other-->parameters %%%
*create, report
*CFOPEN,reports,txt
*VWRITE, TOTAL_ELEMENT_NUMBER
('THE TOTAL NUMBER OF ELEMENTS:', F9.0,TL1, ' ')
*VWRITE, TOTAL_NODE_NUMBER
('THE TOTAL NUMBER OF NODES:', F9.0,TL1, ' ')
*VWRITE, MAX_DISP_VALUE, NODE_NUMBER_MAX_DISP
('THE VALUE OF MAXIMUM DISPLACEMENT:', E15.6, ' AT THE NODE:', F9.0,TL1,' ')
*vwrite, maxdisp_x,maxdisp_y,maxdisp_z
('THE LOCATION OF MAXIMUM DISPLACEMENT (X=', F7.1, ' , Y=', F7.1,' , z=', F7.1, ')')
*VWRITE, MAX_SEQV_VALUE, NODE_NUMBER_MAX_SEQV
('THE VALUE OF MAXIMUM VON MISES STRESS:', F7.1, ' AT THE NODE:', F9.0,TL1,' ')
*vwrite, maxSEQV_x,maxSEQV_y,maxseqv_z
('THE LOCATION OF MAXIMUM VON MISES STRESS (X=', F7.1, ' , Y=', F7.1,' , z=', F7.1, ')')
*VWRITE, MAX_SINT_VALUE, NODE_NUMBER_MAX_SINT
('THE VALUE OF MAXIMUM STRESS INTENSITY:', F7.1, ' AT THE NODE:', F9.0,TL1,' ')
*vwrite, maxSINT_x,maxSINT_y,maxsint_z
('THE LOCATION OF MAXIMUM STRESS INTENSITY (X=', F7.1, ' , Y=', F7.1,' , z=', F7.1, ')')
*CFCLOS
*end !!! must match "*creat"
!!/output, results, txt
*use,report
node1p1=2
node2p1=263
nsel,s,node,,node1p1
nsel,a,node,,node2p1
path,p1,2,30,20 !!!node1p1, node2p1
!!!path,p1,2,node1p1,node2p1
PPATH,1,node1p1
ppath,2,node2p1
PATH,STAT
PATH,P1
AVPRIN,0, ,
PDEF, ,S,EQV,AVG
PLSECT,S,X, ,0
/image,save,p1_path,bmp,
2. APDL for the tank with hemispherical end
WPSTYLE,,,,,,,,0
/PMETH,OFF,0
KEYW,PR_SET,1
KEYW,PR_STRUC,1
/REPLO
/UNITS,SI
WPSTYLE,,,,,,,,0
FINISH
/PREP7
!Et,2,solid95
!et,1,plane42
et,1,shell93
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,200000
MPDATA,PRXY,1,,0.3
fINISH
/PREP7
K,1,502.5,1252.5,,
k,2,502.5,1252.5-502.5,,
k,3,502.5,-1252.5,
K,4,0,1252.5,,
k,5,0,-1252.5,,
k,6,502.5,-1252.5+502.5,,
CIRCLE,4,502.5 , , ,90,1,
allsel,all
kplot
FLST,3,1,4,ORDE,1
FITEM,3,1
LSYMM,Y,P51X, , , ,0,0
lplot
LSTR, 3, 6
LSTR, 6, 2
LSTR, 2, 1
allsel,all
AROTAT,1, , , , , ,4,5 ,180,1,
AROTAT,2, , , , , ,4,5 ,180,1,
AROTAT,3, , , , , ,4,5 ,180,1,
AROTAT,4, , , , , ,4,5 ,180,1,
AROTAT,5, , , , , ,4,5 ,180,1,
allsel,all
/VIEW,1,1,1,1
/ANG,1
/REP,FAST
wpro,,,-90
!wpro,90
WPRO,180
wpro,180
CSWPLA,11,1,
cswpla,12,0
csys,12
k,200,0,-152.5,0
k,201,0,-152.5,-680
k,202,0,0,-680
k,203,0,0,0
L,200,201
L,201,202
!l,200,203
FLST,2,2,4,ORDE,2
FITEM,2,21
FITEM,2,-22
FLST,8,2,3
FITEM,8,202
FITEM,8,203
allsel,all
aptn,all
asel,s,area,,9,12,3
ADELE,all, , ,1
lplot
erase
allsel,all
aplot
R,1,5,
R,2,50,
ASEL, , , , 8
AATT, 1, 2, 1, 0,
allsel,all
asel,u,area,,8
AATT, 1, 1, 1, 0,
CSYS,0
lesize,all,,,36
type,1
mat,1
SMRT,4
MSHAPE,1,2D
MSHKEY,0
asel,all
amesh,all
erase
eplot
/SOL
ANTYPE,0
csys,0
dl,all,,symm
CSYS,0
nslk,s
D,all,ux,0
CSYS,0
nslk,s
D,all,all,0
!! gravity applied
ACEL,9.8,0,0,
allsel,all
asel,s,area,,3,8,5
allsel,all
asel,u,area,,3,8,5
sfa,all,1,pres,-2
allsel,all
/PBF,TEMP, ,1
/PIC,DEFA, ,1
aplot
solve !!! success!
allsel,all
/post1
/DSCALE,1,1
pldisp,1
/DSCALE,1,1
erase
/post1
plnsol,s,1,
erase
/post1
plnsol,s,2,
erase
/post1
plnsol,s,3,
erase
/post1
plnsol,s,int,
erase
/post1
plnsol,s,eqv,
FLST,5,3,5,ORDE,3
FITEM,5,8
FITEM,5,13
FITEM,5,-14
ASEL,S, , ,P51X
aplot
nsla,s
esla,s
plnsol,s,int
plnsol,s,eqv,
pldisp,1
allsel,all
nsort,s,eqv
nsort,s,int
nsort,u,sum
allsel,all
/POST1
CSYS,0
*create, report
*CFOPEN,reports,txt
*CFCLOS
*use,report
ASEL,S, , , 1
nsla,s
esla,s
/post1
plnsol,s,EQV
/image,save,hemisphericalendSEAV,bmp,
plnsol,s,int
/image,save,hemisphericalendSINT,bmp,
plnsol,U,SUM
/image,save,hemisphericalendUsum,bmp, |
