很久以前做的了,计算的是一个变压器的磁场分布。
负载是一个电阻,用到了场路耦合,希望对你有所帮助。
/FILNAME,Load
!Part 1: Initializing the parameter of geometry and properties.
Ri=395E-03/2 !Radius of iron core ;
Hi=(1940/2+20)*1E-03 !Height of iron core;
G1=20E-03 !Gap between core and inner high voltage winding;
Whv1=80.5E-03 !Width of inner high voltage winding;
Hw=970E-03 !Height of winding;
G2=10E-03 !Gap between high and low voltage windings;
Wlv=69E-03 !Width of low voltage winding;
Whv2=262E-03 !Outer high winding;
Wt=1320E-03 !Total width;
Nlv=132 !Turns of premary winding;
Slv=185E-06 !Area of core conductor about premary(low) winding;
Flv=(Nlv*Slv)/(Wlv*Hw*2) !Fill factor abou premary winding;
Nhv1=110 !Turns of inner secondary(high) winding;
Shv=70E-06 !Areas of core conductor about high winding;
Fhv1=(Nhv1*Shv)/(Whv1*Hw*2) !Fill factor about inner high winding;
Nhv2=330 !Turns of outer high winding;
Fhv2=(Nhv2*Shv)/(Whv2*Hw*2) !Fill factor about outer high winding;
!Part 2: Creating half FEM model;
/PREP7
Rectng,0,Ri,0,Hi !Coil area;
R1=Ri+G1
Rectng,R1,R1+Whv1,0,Hw !Inner high voltage winding;
R2=R1+Whv1+G2
Rectng,R2,R2+Wlv,0,Hw !Low winding;
R3=R2+Wlv+G2
Rectng,R3,R3+Whv2,0,Hw !outer high winding;
Rectng,0,Wt,0,Hi
AOVLAP,ALL
NumCmp,All
!Part 3: Defining the properties.
ET,1,53,,,1 ! Air and core;
ET,2,53,2,,1 ! Premary (Low) winding;
ET,3,53,3,,1 ! Secondary (High) winding;
MP,MURX,1,1 !No.1= Air;
Mp,Murx,2,5000 !No.2=Iron core;
Rsvx_Al=2.6178E-08
UIMP,3,MURX,RSVX,,1,Rsvx_Al !No.3=Aluminium conductor;
R,1,2*Whv1*Hw,Nhv1,,-11,Fhv1 !Inner high winding;
R,2,2*Wlv*Hw,Nlv,,1,Flv !Low winding;
R,3,2*Whv2*Hw,Nhv2,,-1,Fhv2 !Outer high winding;
ASEL,S,AREA,,1 !Core;
AATT,2,,1
ASEL,S,,,2 !Inner high winding;
AATT,3,1,3
ASEL,S,,,3 !Low winding;
AATT,3,2,2
Asel,S,,,4 !Outer winding;
AATT,3,3,3
ASEL,S,,,5
AATT,1,,1
Allsel,All
!Part 4:Meshing model.
!Part 4.1: Meshing coil
LSel,S,,,5,11,2
Lesize,All,,,2
LSel,s,,,6,8,2
LSel,A,,,14,16,2
Lesize,All,,,28
Lsel,S,,,10,12,2
Lesize,All,,,33
Lsel,s,,,13,15,2
Lesize,All,,,6
Asel,s,Type,,2,3
MShape,0,2D !Qualaterial elements;
Mshkey,1 !Mapped Meshing;
Amesh,All
!Part 4.2: Meshing iron core;
Lsel,s,,,1,3,2
LEsize,All,,,6
Lsel,s,,,2,4,2
Lesize,All,,,30
Mshkey,1 !Mapped meshing;
Asel,s,mat,,2
AMESH,All
!Part 4.3:Meshing air region;
Smrt,2
Mshape,1,2D
MshKey,0
ASel,S,mat,,1
Amesh,All
!Part 5: Creating circuit;
Allsel,All
Et,4,Circu124,0 !Resistor;
Et,5,Circu124,5 !Stranded Coil (To FEM domain);
R,4,1.0E+03 !Magnitude of load resistor;
R,5,2 !Symmetry factor for stranded coil
N !No 1. terminal node linked resistor;
N !No.2 terminal node linked resistor;
*Get,Nmax,Node,0,Num,Max
Type,4
Real,4
E,Nmax,Nmax-1 !Resistor element;
Type,5
Real,5
E,Nmax,Nmax-1,Node(R1,0,0)
!Part 6: Applying the boundary conditions.
Allsel,All
ESel,S,Type,,2
NSLE,S
CP,1,CURR,ALL ! Couple Current inside premary winding;
Esel,s,Type,,3
NSLE,S
Cp,2,Curr,All
Cp,3,EMF,All
Allsel,all
CSYS,0
NSEL,S,LOC,X,0
D,ALL,AZ,0
Allsel,All
FINISH
!Part 6: Applying the load and solving.
/SOLU
Frq=50
ANTYPE,Harmic
HarFrq,Frq
ESEL,S,Type,,2
BFE,ALL,VLTG,,10500*Sqrt(2),0 ! 10.5kV Voltage Load
Allsel,ALL
SOLVE
Save
FINISH |
