- 30
- 2003-4-18
楼主 |
发表于 2006-1-5 18:35:36
来自 江苏南京
Re:abq在作静力分析时,可以用单元生死么?
jeckaer wrote:
可以用*shear failure , node erotion=yes和*plastic联合起来
很奇怪啊,
我的doc里面没有node erotion=yes这个选项!:O)
Optional parameters只有以下方面的介绍。
如下:
Optional parameters:
DEPENDENCIES
This parameter is relevant only for TYPE=TABULAR.
Set this parameter equal to the number of field variable dependencies included in the definition of the equivalent plastic strain at failure, in addition to temperature. If this parameter is omitted, it is assumed that the strain at failure depends on the plastic strain, the plastic strain rate, the dimensionless pressure-deviatoric stress ratio and, possibly, on temperature. See “Using the DEPENDENCIES parameter to define field variable dependence” in “Material data definition,” Section 9.1.2 of the ABAQUS Analysis User's Manual, for more information.
ELEMENT DELETION
Set ELEMENT DELETION=YES (default) to allow element deletion when the failure criterion is met.
Set ELEMENT DELETION=NO to allow the element to take hydrostatic compressive stress only when the failure criterion is met.
TYPE
Set TYPE=JOHNSON COOK to define the Johnson-Cook shear failure criterion. It requires the use of the *PLASTIC, HARDENING=JOHNSON COOK option.
Set TYPE=TABULAR (default) to define the failure strain in tabular data form. It requires the use of the *PLASTIC, HARDENING=ISOTROPIC option.
ps:我用的是6.5的。谢谢,
而且,里面的*SHEAR FAILURE只能用于explicit分析。
如下:
*SHEAR FAILURE
Specify a shear failure model and criterion.
This option is used with the Mises or the Johnson-Cook plasticity models to specify shear failure of the material. It must be used in conjunction with the option *PLASTIC, HARDENING=ISOTROPIC or JOHNSON COOK.
Product: ABAQUS/Explicit
Type: Model data
Level: Model |
