- 75
- 2002-10-7
楼主 |
发表于 2006-1-19 11:58:24
来自 上海浦东新区
Re:Out of mesh memory
Hi,
It is nice to have chat with Femlab users.
About out of memory, we can pick up the answer from the website as follows:
"Out of memory", why do I get this message?
Especially in 3D modelling, extensive memory usage urges some extra precautions. The "Out of Memory"-problem occurs whenever FEMLAB tries to allocate an array which does not fit sequentially in memory. It is common that the amount of available memory seems large enough for the array - but there may exist no continuous block of that size, due to fragmentation. If you for example look in the task manager of Windows, this may have the effect that you can't see any high memory allocation, and get "out of memory" anyway.
The "Memory Usage" column in the Windows task manager can also be misleading, because it only shows the currently swapped portion. A better indicator of total usage can be found like this (Win2000, WinNT, Win XP):
Press Ctrl-Alt-Del to bring up the Task Manager.
Go to the "processes" tab.
From the View menu, choose Select Columns.
Select the Virtual Memory Size check box.
Now find the javaw.exe process that corresponds to the FEMLAB process in the process list and look in the "VM Size" column. This shows a better value on the actual memory used.
I hope this will give you help.
rgrds,
Hady |
