- 75
- 2002-10-7
楼主 |
发表于 2006-2-10 15:50:25
来自 上海浦东新区
Re:use of a PC with two processors
Arman,
Hello. Unfortunately, I don't believe that using 2 processors will be of any help. COMSOL/FEMLAB does not support multi-threading which is what you would need to be able to use 2 different processors simultaneously. This is more of a problem inherent to the Finite Element Method more than it is to COMSOL. This is why a lot of persons will opt for Finite Difference Time Domain (FDTD) based simulation approaches. Having a good processor with a high clock rate will help but in the end adding memory is the best way to enhance a computer that you are going to run COMSOL on. Also, there are tricks that can help you in building more "efficient" models. If there is any type of symmetry condition that you can introduce into the model, that will help you by effectively cutting your model size in half. Also, proper choice of the type of mesh elements you and the solver are critical. Iterative methods take longer but they run on much less memory so you can run even bigger models than using a direct solver. Also, I have found that the multigrid solver is amazing and makes COMSOL/FEMLAB run much more efficiently. I hope this helps. Please feel free to email me if you have any more questions.
Regards,
Jason Deibel |
