一三维六面体试件,尺寸30mm×10mm×10mm,顶底面位移固定,底面温度200度,顶面温度20度,求在试件内部产生的热应力。下面是我的apdl流程文件,出现错误信息:Large negative pivot value(-0.458137512) in Eqn.system.
May be because of a bad temperature-dependent material property used in the model. 请教各位高手,该如何解决?我的Email地址:xukyle@163.com.
/BATCH
finish
/clear
/PREP7
ET,1,SOLID70
MP,KXX,1,5
BLOCK,0,30,0,10,0,10,
/RGB,INDEX,100,100,100, 0
/RGB,INDEX, 80, 80, 80,13
/RGB,INDEX, 60, 60, 60,14
/RGB,INDEX, 0, 0, 0,15
Lsel,s,line,,1,3,2
LESIZE,all, , ,10
Lsel,s,line,,6,10,2
LESIZE,all, , ,10
Lsel,s,line,,11,12,1
LESIZE,all, , ,10
Lsel,s,line,,2,4,2
LESIZE,all, , ,30
Lsel,s,line,,5,7,2
LESIZE,all, , ,30
vmesh,1
FINISH
/solu
antype,static
asel,s,area,,5
nsla,s,0
d,all,temp,200
lsel,s,line,,1
nsll,s,1
d,all,temp,200
lsel,s,line,,12
nsll,s,1
d,all,temp,200
lsel,s,line,,8,9
nsll,s,1
d,all,temp,200
asel,s,area,,6
nsla,s,0
d,all,temp,20
lsel,s,line,,3,6,3
nsll,s,1
d,all,temp,20
lsel,s,line,,10,11,1
nsll,s,1
d,all,temp,20
allsel
Outpr,basic,all
solve
finish
/post1
set,last
plnsol,temp
finish
/PREP7
ETCHG,TTS
MP,EX,1,5e10
MP,PRXY,1,0.25
MP,ALPX,1,5e-6
asel,s,area,,5
nsla,s,1
cp,8,ux,all
asel,s,area,,6
nsla,s,1
cp,9,ux,all
allsel
finish
/SOL
ANTYPE,0
asel,s,area,,5,6
nsla,s,1
d,all,ux,0
LDREAD,TEMP,,, ,,,rth
allsel
solve
finish |
