我用imesh命令对gasket单元进行网格划分的时候,弹出错误提示:“Aera 50 and 55 are not
in the same aera!”查看帮助文件,“The IMESH command requires that the target line or area exactly match the source line or area. Also, both target and source lines or areas must be in the same area or volume. ”后面一句我不理解,要求源面(线)和目标面(线)在相同的体或面中。可是体或面不是被gasket单元分隔开了吗?源面(线)和目标面(线)怎么可在相同的体或面中呢?期望哪位大虾和斑竹能指点一下。感激 不尽!
