- 13
- 2003-9-25
发表于 2006-11-24 14:11:22
来自 天津
Status
Flexible License Manager status on Fri 11/24/2006 13:57
[Detecting lmgrd processes...]
License server status: 27000@SG-CSHL
License file(s) on SG-CSHL: D:\ABAQUS\license.dat:
SG-CSHL: license server UP (MASTER) v9.2
Vendor daemon status (on SG-CSHL):
ABAQUSLM: UP v9.2
Feature usage info:
Users of adams: (Total of 50 licenses issued; Total of 0 licenses in use)
Users of aqua: (Total of 50 licenses issued; Total of 0 licenses in use)
Users of beamSectGen: (Total of 50 licenses issued; Total of 0 licenses in use)
Users of cadporter_catia: (Total of 50 licenses issued; Total of 0 licenses in use)
Users of cadporter_catiav5: (Total of 50 licenses issued; Total of 0 licenses in use)
Users of cadporter_ideas: (Total of 50 licenses issued; Total of 0 licenses in use)
Users of cadporter_parasolid: (Total of 50 licenses issued; Total of 0 licenses in use)
Users of cadporter_proe: (Total of 50 licenses issued; Total of 0 licenses in use)
Users of cae: (Total of 50 licenses issued; Total of 0 licenses in use)
Users of cmold: (Total of 50 licenses issued; Total of 0 licenses in use)
Users of cosimulation: (Total of 50 licenses issued; Total of 0 licenses in use)
Users of design: (Total of 50 licenses issued; Total of 0 licenses in use)
Users of explicit: (Total of 50 licenses issued; Total of 0 licenses in use)
Users of foundation: (Total of 50 licenses issued; Total of 0 licenses in use)
Users of moldflow: (Total of 50 licenses issued; Total of 0 licenses in use)
Users of noGUI: (Total of 50 licenses issued; Total of 0 licenses in use)
Users of standard: (Total of 50 licenses issued; Total of 0 licenses in use)
Users of viewer: (Total of 50 licenses issued; Total of 0 licenses in use)
Users of parallel: (Total of 50 licenses issued; Total of 0 licenses in use)
这是abaqus6.5.1的license里面没有abaqus/safe的注册许可。
fe-safe calculate the fatigue life, provides comprehensive graphical
output for critical elements. These include cycle and damage
distributions, calculated stress histories, and crack orientation.
fe-safe will calculate which loads or loading directions are the most
significant in causing fatigue damage. This makes re-design easier,
and simplifies component testing. Complex assemblies containing
different materials and surface finish can be analysed in a single
run. Selected parts of a model can be analysed. The effects of
temperature and time-dependant creep-fatigue can be included in the
analysis. fe-safe can be used by non-specialist designers - it will
automatically select the most appropriate analysis method, and will
estimate materials properties if test data is not available.
Specialist engineers can select from a number of advanced multi-axial
fatigue methods, and can set up standard analyses for easy re-use.
User-configurable features can be accessed and used to set defaults.
fe-safe features an intuitive user interface with integrated
graphics, macro recording of standard tasks, and on-line help. The
user interface is identical for all FEA codes and is easy to use.
Powerful batch functions make repeated analysis easy and convenient.
ysis easy and convenient. raphics, macro recording of standard tasks,
and on-line help. The user interface is identical for all FEA codes
and is easy to use. Powerful batch functions make repeated analysis
For more information:
http://www.safetechnology.com
这是fe-safe的介绍
在abaqus6.5.1的manual中有一段话:
The full range of ABAQUS products is supported on Windows/x86-32 platforms. All ABAQUS products except fe-Safe Version 5 are supported on Linux/x86-32 platforms.
这说明fe-safe就是abaqus/safe
因此需要单独安装。
[ 本帖最后由 mercurycai 于 2006-11-24 14:21 编辑 ] |
