- 1
- 2004-10-27
我想用inp 文件中的 nodeprint 命令把模型中指定节点的 受力情况打出来, 但是在dat 文件中总是找不到,一直没有找出什么原因, 我记得今年夏天做的时候还可以打出来。
不知道哪位能不能帮我看一眼,是不是什么语法出了问题,谢谢!
我把 模型的图放在附件中了。 inp 文件不让上传,我就直接贴在帖子里了。
感恩节快乐!
*Heading
** Job name: Job-1 Model name: Model-1
*Preprint, echo=NO, model=NO, history=NO, contact=NO
** PARTS
*Part, name=Part-1
*End Part
** ASSEMBLY
*Assembly, name=Assembly
*Instance, name=Part-1-1, part=Part-1
*Node
1, 0., 0., 3.
2, -0.5, 0., 3.
3, -1., 0., 3.
4, -1.5, 0., 3.
5, 0., 0., 2.5
6, -0.5, 0., 2.5
7, -1., 0., 2.5
8, -1.5, 0., 2.5
9, 0., 0., 2.
10, -0.5, 0., 2.
11, -1., 0., 2.
12, -1.5, 0., 2.
13, 0., 0., 1.5
14, -0.5, 0., 1.5
15, -1., 0., 1.5
16, -1.5, 0., 1.5
17, 0., 0., 1.
18, -0.5, 0., 1.
19, -1., 0., 1.
20, -1.5, 0., 1.
21, 0., 0., 0.5
22, -0.5, 0., 0.5
23, -1., 0., 0.5
24, -1.5, 0., 0.5
25, 0., 0., 0.
26, -0.5, 0., 0.
27, -1., 0., 0.
28, -1.5, 0., 0.
*Element, type=S4R
1, 1, 2, 6, 5
2, 2, 3, 7, 6
3, 3, 4, 8, 7
4, 5, 6, 10, 9
5, 6, 7, 11, 10
6, 7, 8, 12, 11
7, 9, 10, 14, 13
8, 10, 11, 15, 14
9, 11, 12, 16, 15
10, 13, 14, 18, 17
11, 14, 15, 19, 18
12, 15, 16, 20, 19
13, 17, 18, 22, 21
14, 18, 19, 23, 22
15, 19, 20, 24, 23
16, 21, 22, 26, 25
17, 22, 23, 27, 26
18, 23, 24, 28, 27
*Nset, nset=_PickedSet2, internal, generate
1, 28, 1
*Elset, elset=_PickedSet2, internal, generate
1, 18, 1
** Region: (Section-1icked)
1, 18, 1
** Section: Section-1
*Shell Section, elset=_PickedSet2, material=Material-1
0.1, 5
*End Instance
*Nset, nset=_PickedSet4, internal, instance=Part-1-1, generate
4, 28, 4
*Elset, elset=_PickedSet4, internal, instance=Part-1-1, generate
3, 18, 3
*Nset, nset=_PickedSet5, internal, instance=Part-1-1, generate
1, 25, 4
*Elset, elset=_PickedSet5, internal, instance=Part-1-1, generate
1, 16, 3
*Nset, nset=_PickedSet6, internal, instance=Part-1-1, generate
25, 28, 1
*Elset, elset=_PickedSet6, internal, instance=Part-1-1, generate
16, 18, 1
*Nset, nset=_PickedSet7, internal, instance=Part-1-1, generate
1, 4, 1
*Elset, elset=_PickedSet7, internal, instance=Part-1-1, generate
1, 3, 1
*Nset, nset=BM, instance=Part-1-1
25,
*Nset, nset=DP, instance=Part-1-1
1,
*Elset, elset=__PickedSurf8_SNEG, internal, instance=Part-1-1, generate
1, 18, 1
*Surface, type=ELEMENT, name=_PickedSurf8, internal
__PickedSurf8_SNEG, SNEG
*End Assembly
** MATERIALS
*Material, name=Material-1
*Elastic
2e+11, 0.3
** STEP: Step-1
*Step, name=Step-1
*Static
1., 1., 1e-05, 1.
** BOUNDARY CONDITIONS
** Name: BC-1 Type: Displacement/Rotation
*Boundary
_PickedSet4, 2, 2
** Name: BC-2 Type: Displacement/Rotation
*Boundary
_PickedSet5, 6, 6
** Name: BC-3 Type: Displacement/Rotation
*Boundary
_PickedSet6, 2, 2
_PickedSet6, 4, 4
** Name: BC-4 Type: Displacement/Rotation
*Boundary
_PickedSet7, 4, 4
** LOADS
** Name: Load-1 Type: Pressure
*Dsload
_PickedSurf8, P, 100000.
** OUTPUT REQUESTS
*Restart, write, frequency=0
** FIELD OUTPUT: F-Output-1
*Output, field, variable=PRESELECT
** HISTORY OUTPUT: H-Output-1
*Output, history, variable=PRESELECT
**Nodeprint nset=BM
*End Step |
