- 4
- 2004-9-12
楼主 |
发表于 2007-1-25 17:07:31
来自 德国
in Transferrring Results Between ABAQUS 7.7.3-11
the Assembly can also be transferred between Standard. I have tried and becomed such of error.
there is also instruction for CAE in 7.7.3.-1
PROCESSING PART, INSTANCE, AND ASSEMBLY INFORMATION
***ERROR: Problem when parsing keyword: INSTANCE Invalid parameter: 4. The
parameter may be misspelled, obsolete, or invalid.
***NOTE: DUE TO AN INPUT ERROR THE ANALYSIS PRE-PROCESSOR HAS BEEN UNABLE TO
INTERPRET SOME DATA. SUBSEQUENT ERRORS MAY BE CAUSED BY THIS OMISSION
***ERROR: in keyword *IMPORT, file "Pre-load2.inp", line 22: The keyword is
misplaced.
***ERROR: in keyword *ENDINSTANCE, file "Pre-load2.inp", line 23: The keyword
is misplaced. It can be suboption for the following keyword(s):
assembly
***ERROR: in keyword *ELSET, file "Pre-load2.inp", line 1975: The following
sets/ids do not exist: "TUBUS K60 PHI4,4,8-1-1".1, "TUBUS K60
PHI4,4,8-1-1".316609
***ERROR: in keyword *NSET, file "Pre-load2.inp", line 1163: The following
PHI4,4,8-1-1".62814
***ERROR: in keyword *NSET, file "Pre-load2.inp", line 1977: The following
sets/ids do not exist: "TUBUS K60 PHI4,4,8-1-1".46, "TUBUS K60
PHI4,4,8-1-1".47, "TUBUS K60 PHI4,4,8-1-1".49, "TUBUS K60
PHI4,4,8-1-1".51, "TUBUS K60 PHI4,4,8-1-1".52, "TUBUS K60
PHI4,4,8-1-1".3226, "TUBUS K60 PHI4,4,8-1-1".3227, "TUBUS K60
PHI4,4,8-1-1".3228, "TUBUS K60 PHI4,4,8-1-1".3229, "TUBUS K60
PHI4,4,8-1-1".3230, "TUBUS K60 PHI4,4,8-1-1".3231, "TUBUS K60
PHI4,4,8-1-1".3232, "TUBUS K60
***NOTE: Warning message is too long. It has been truncated.
***ERROR: in keyword *NSET, file "Pre-load2.inp", line 2544: The following
PHI4,4,8-1-1".4, "TUBUS K60 PHI4,4,8-1-1".55, "TUBUS K60
PHI4,4,8-1-1".56, "TUBUS K60 PHI4,4,8-1-1".57, "TUBUS K60
PHI4,4,8-1-1".58, "TUBUS K60 PHI4,4,8-1-1".59, "TUBUS K60
PHI4,4,8-1-1".60, "TUBUS K60 PHI4,4,8-1-1".61, "TUBUS K60
PHI4,4,8-1-1".62, "TUBUS K60 PHI4,4,8-1-1".63, "TUBUS K60
PHI4,4,8-1-1".64, "TUBUS K60 PHI4,4,8-1-1".65, "TUBUS K60
END PROCESSING PART, INSTANCE, AND ASSEMBLY INFORMATION
*visco, cetol=0.5
OPTIONS BEING PROCESSED
*import, update=NO
Element and node information will be imported at
Step 6
Increment number 1
of the specified ABAQUS/Standard analysis.
The element state is to be imported.
The imported configuration will not be updated.
The elements in the following element sets
are to be imported :
ASSEMBLY_PRODUCT2-1-1__PICKEDSET7
ASSEMBLY_PRODUCT2-5-1__PICKEDSET25
***ERROR: PRE WORKSPACE IS INSUFFICIENT. PRE_MEMORY IS CURRENTLY SET TO 256.00
MBYTES. NO ESTIMATES OF THE REQUIRED MEMORY ARE AVAILABLE DURING
INPUT FILE PROCESSING. PLEASE INCREASE THE VALUE OF PRE_MEMORY.
THE PROGRAM HAS DISCOVERED 8 FATAL ERRORS
** EXECUTION IS TERMINATED **
END OF USER INPUT PROCESSING
JOB TIME SUMMARY
USER TIME (SEC) = 24.520
SYSTEM TIME (SEC) = 1.5300
TOTAL CPU TIME (SEC) = 26.050
WALLCLOCK TIME (SEC) = 50 |
