- 26
- 2003-6-20
DOWNLOAD THE FILES BY YOURSELF.
http://www.eng.ox.ac.uk/solidmech/books/ICP/
Introduction to Computational Plasticity
Fionn Dunne and Nik Petrinic
Oxford University Press, 2005, ISBN 0 19 856826 6 (Hbk)
Appendix B: Fortran coding available via the OUP website
Directory / File Description
elasticity
elastic.f
UMAT for plane strain and axial symmetry for elastic behaviour using ABAQUS stress and strain quantities.
elas_axidisp.inp
ABAQUS input file for single axisymmetric element under uniaxial displacement controlled loading, requiring UMAT elastic.f
elas_axiforce.inp
ABAQUS input file for single axisymmetric element under uniaxial force controlled loading, requiring UMAT elastic.f
plasticity_exp
code_exp.f
UMAT for plane strain and axial symmetry for elastic, linear strain hardening plastic behaviour using explicit integration with continuum Jacobian, using ABAQUS stress and strain quantities. Suitable for large deformations
plas_exp_axidisp_aba.inp
ABAQUS input file for single axisymmetric element under uniaxial displacement controlled loading, using ABAQUS *PLASTIC
plas_exp_axiforce_aba_inp
ABAQUS input file for single axisymmetric element under uniaxial force controlled loading, using ABAQUS *PLASTIC
plas_exp_axidisp.inp
ABAQUS input file for single axisymmetric element under uniaxial displacement controlled loading, requiring UMAT code_exp.f
plas_exp_axiforce.inp
ABAQUS input file for single axisymmetric element under uniaxial force controlled loading, requiring UMAT code_exp.f
beam_mesh.inp
plas_exp_beam_aba.inp
Four point bend loading using ABAQUS*PLASTIC, requiring mesh file beam_mesh.inp
plas_exp_beam.inp
Four point bend loading requiring UMAT code_exp.f, requiring mesh file beam_mesh.inp
plasticity_imp
code_imp.f
UMAT for plane strain and axial symmetry for elastic, linear strain hardening plastic behaviour using implicit integration with consistent Jacobian, using ABAQUS stress and strain quantities. Suitable for large deformations.
plas_imp_axidisp_aba.inp
plas_imp_axiforce_aba_inp
plas_imp_axidisp.inp
ABAQUS input file for single axisymmetric element under uniaxial displacement controlled loading, requiring UMAT code_imp.f
plas_imp_axiforce.inp
ABAQUS input file for single axisymmetric element under uniaxial force controlled loading, requiring UMAT code_imp.f
beam_mesh.inp
plas_imp_beam_aba.inp
Four point bend loading using ABAQUS *PLASTIC, requiring mesh file beam_mesh.inp
plas_imp_beam.inp
Four point bend loading requiring UMAT code_imp.f, requiring mesh file beam_mesh.inp
spin
spin_elastic.f
UMAT for 3D, plane strain and axial symmetry for elastic behaviour using ABAQUS stress and strain quantities
spin_elas_def.f
UMAT for 3D, plane strain and axial symmetry for elastic behaviour using the deformation gradient
spin_axidisp.inp
ABAQUS input file for single axisymmetric element under uniaxial displacement controlled loading, requiring UMAT spin_elas_def.f
spin_axiforce.inp
ABAQUS input file for single axisymmetric element under uniaxial force controlled loading, requiring UMAT spin_elas_def.f
spin_shear.inp
ABAQUS input file for a single plane strain element under simple shear, requiring UMAT spin_elas_def.f
spin_shear_aba.inp
ABAQUS input file for a single plane strain element under simple shear, using ABAQUS *ELASTIC
visco
uni_visco_imp.f
Closed form fortran implicit solution for uniaxial elasto- viscoplasticity
uni_visco_exp.f
Closed form fortran explicit solution for uniaxial elasto- viscoplasticity
visco_imp.f
UMAT for plane strain and axial symmetry for elastic, linear strain hardening viscoplastic behaviour using implicit integration using the initial tangent stiffness, using ABAQUS stress and strain quantities. Suitable for large deformations.
visco_beam.f
visco_imp_axidisp.inp
ABAQUS input file for single axisymmetric element under uniaxial displacement controlled loading, requiring UMAT visco_imp.f
visco_imp_axiforce.inp
ABAQUS input file for single axisymmetric element under uniaxial force controlled loading, requiring UMAT visco_imp.f
beam_mesh.inp
visco_imp_beam.inp
Four point bend loading requiring UMAT visco_beam.f, requiring mesh file beam_mesh.inp |
