我想知道,flag是不是算作一个调用函数呢,我把命令中添加了不同粒径材料的体积比。但是运行不了,看看有什么毛病
/PREP7
/COM, Structural
ET,1,PLANE42
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,4.2e11
MPDATA,PRXY,1,,0.17
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,2,,2.07e11
MPDATA,PRXY,2,,0.32
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,3,,3.5e11
MPDATA,PRXY,3,,0.22
*DIM,MM,ARRAY,4000,3
*SET,XL,0.0
*SET,YB,0.0
*SET,XR,0.001
*SET,YT,0.001
*SET,B,XR-XL
*SET,H,YT-YB
*SET,TT,0.0
*SET,TOTALAREA,B*H
*SET,AREA,0
*SET,AREA1,0
*SET,AREA2,0
*SET,RATE,0.4
*SET,RATE1,0.05
*SET,RATE2,0.1
*SET,FLAG,1
*SET,FLAGE,1
*SET,FLAGEE,1
*SET,FLAG1,0
*SET,i,1
*SET,Rmin,0.007*B
*SET,Rmax,0.049*B
BLC4,,,B,H
*SET,MM(1,1),RAND(Rmin,Rmax)
*SET,d,Rmin/10
*SET,MM(1,2),RAND(XL+MM(1,1)+d,XR-MM(1,1)-d)
*SET,MM(1,3),RAND(YB+MM(1,1)+d,YT-MM(1,1)-d)
CYL4,MM(1,2),MM(1,3),7E-6
*SET,AREA,3.14159265*MM(1,1)*MM(1,1)
*SET,MM(2,2),RAND(XL+MM(2,1)+d,XR-MM(2,1)-d)
*SET,MM(2,3),RAND(YB+MM(2,1)+d,YT-MM(2,1)-d)
CYL4,MM(2,2),MM(2,3),1E-6
*SET,AREA1,3.14159265*MM(2,1)*MM(2,1)
*SET,MM(3,1),RAND(Rmin,Rmax)
*SET,MM(3,2),RAND(XL+MM(2,1)+d,XR-MM(2,1)-d)
*SET,MM(3,3),RAND(YB+MM(2,1)+d,YT-MM(2,1)-d)
CYL4,MM(3,2),MM(3,3),0.5E-6
*SET,AREA2,3.14159265*MM(3,1)*MM(3,1)
*DOWHILE,FLAG
*SET,i,i+1
*SET,MM(i,1),RAND(Rmin,Rmax)
*SET,MM(i,2),RAND(XL+MM(i,1)+d,XR-MM(i,1)-d)
*SET,MM(i,3),RAND(YB+MM(i,1)+d,YT-MM(i,1)-d)
*set,flag1,1
*Do,j,1,i-1
*SET,SHU1,(MM(i,2)-MM(j,2))*(MM(i,2)-MM(j,2))+(MM(i,3)-MM(j,3))*(MM(i,3)-MM(j,3))
*SET,R2,(MM(i,1)+MM(j,1)+d)*(MM(i,1)+MM(j,1)+d)
*IF,SHU1,LT,R2,THEN
*SET,FLAG1,0
*ENDIF
*ENDDO
*IF,FLAG1,GT,0,THEN
CYL4,MM(i,2),MM(i,3),7E-6
*ELSE
*SET,i,i-1
*ENDIF
*DOWHILE,FLAGE
*SET,i,i+1
*set,flagE1,1
*Do,j,1,i-1
*SET,SHU2,(MM(i,2)-MM(j,2))*(MM(i,2)-MM(j,2))+(MM(i,3)-MM(j,3))*(MM(i,3)-MM(j,3))
*SET,R3,(MM(i,1)+MM(j,1)+d)*(MM(i,1)+MM(j,1)+d)
*IF,SHU2,LT,R3,THEN
*SET,FLAGE1,0
*ENDIF
*ENDDO
*IF,FLAGE1,GT,0,THEN
CYL4,MM(i,2),MM(i,3),1E-6
*SET,AREA1,AREA1+3.14159265*MM(i,1)*MM(i,1)
*ELSE
*SET,i,i-1
*ENDIF
*DOWHILE,FLAGEE
*SET,i,i+1
*set,flagEE1,1
*Do,j,1,i-1
*SET,SHU3,(MM(i,2)-MM(j,2))*(MM(i,2)-MM(j,2))+(MM(i,3)-MM(j,3))*(MM(i,3)-MM(j,3))
*SET,R4,(MM(i,1)+MM(j,1)+d)*(MM(i,1)+MM(j,1)+d)
*IF,SHU3,LT,R4,THEN
*SET,FLAGEE1,0
*ENDIF
*ENDDO
*IF,FLAGEE1,GT,0,THEN
CYL4,MM(i,2),MM(i,3),0.5E-6
*SET,AREA2,AREA2+3.14159265*MM(i,1)*MM(i,1)
*ELSE
*SET,i,i-1
*ENDIF
*SET,TT,AREA/TOTALAREA
*SET,TT1,AREA1/TOTALAREA
*SET,TT2,AREA2/TOTALAREA
*IF,TT,LE,RATE,THEN
*SET,FLAG,1
*ELSEIF,TT1,LE,RATE1,AND,TT,GE,RATE,THEN
*SET,FLAGE,1
*ELSEIF,TT2,LE,RATE2,AND,TT1,GE,RATE1,AND,TT,GE,RATE,THEN
*SET,FLAGEE,1
*ELSE
*SET,FLAG,0
*SET,FLAGE,O
*SET,FLAGEE,0
*ENDIF
*ENDDO |
