- 4
- 2004-10-6
楼主 |
发表于 2007-3-26 08:43:13
来自 浙江金华
谢谢zhaoxiang的建议
请各位大侠帮我解释一下:
solid97实常数
care:Coil cross-sectional area.是整个线圈的截面积?还是导体的截面积,我认为是前者。
VOLU:Modeled coil volume, required for stranded coil only.是整个线圈的电压,还是每匝电压,我认为是后者。
DIRX, DIRY, DIRZ:x, y, and z components of a unit vector (in the element coordinate system) representing the direction of current. Required for a stranded coil only.当我选择远柱坐标的时候,比如说我要加载10A/每匝的电流,这三个常数该怎么填呢?我认为是1,0,0?因为看见别人不是这么填的,所以有点怀疑。
CSYM:Coil symmetry factor: CSYM*VOLU = total volume of the coil. Required for stranded coil only. Defaults to 1.我不太明白这个参数?
FILL:Coil fill factor, required for stranded coil only. Defaults to 1.这个数值是否是导向截面积之和除以这个绕组的截面积? |
