查看: 397|回复: 10
[前后处理] 急啊 这是导师给我的第一个课题做 我是新手 谢谢前辈们指教
发表于 2007-3-23 20:36:42 | 显示全部楼层 |阅读模式 来自 北京
前辈们 帮我看看  那个地方不对  怎么看不到我想要的效果
下面是网格建立:
;直接底/12.04m-24.11m
gen zone brick size 25 20 10 ratio 0.8 1 0.8 &
         p0 (0 0 0) p1 (100 0 0) p2 (0 80 0) p3 (0 0 12.04) &
         p4 (100 80 0) p5 (0 80 24.11) p6 (100 0 12.04) p7 (100 80 24.11) group 1
gen zone brick size 30 20 10 ratio 1 1 0.8 &
         p0(100 0 0) p1(200 0 0) p2(100 80 0) p3(100 0 12.04) &
         p4(200 80 0) p5(100 80 24.11) p6(200 0 12.04) p7(200 80 24.11) group 1
gen zone brick size 25 20 10 ratio 1.2 1 0.8 &
         p0(200 0 0) p1(300 0 0) p2(200 80 0) p3(200 0 12.04) &
         p4(300 80 0) p5(200 80 24.11) p6(300 0 12.04) p7(300 80 24.11) group 1
;12半煤/1.80m
gen zone brick size 25 20 3 ratio 0.8 1 1 &
         p0(0 0 12.04) p1(100 0 12.04) p2(0 80 24.11) p3(0 0 13.84) &
         p4(100 80 24.11) p5(0 80 25.91) p6(100 0 13.84) p7(100 80 25.91) group 2
gen zone brick size 30 20 3 ratio 1 1 1 &
         p0(100 0 12.04) p1(200 0 12.04) p2(100 80 24.11) p3(100 0 13.84) &
         p4(200 80 24.11) p5(100 80 25.91) p6(200 0 13.84) p7(200 80 25.91) group 2
gen zone brick size 25 20 3 ratio 1.2 1 1 &
         p0(200 0 12.04) p1(300 0 12.04) p2(200 80 24.11) p3(200 0 13.84) &
         p4(300 80 24.11) p5(200 80 25.91) p6(300 0 13.84) p7(300 80 25.91) group 2
;夹矸/1.71m
         p0(0 0 13.84) p1(100 0 13.84) p2(0 80 25.91) p3(0 0 15.55) &
         p4(100 80 25.91) p5(0 80 27.62) p6(100 0 15.55) p7(100 80 27.62) group 3
         p0(100 0 13.84) p1(200 0 13.84) p2(100 80 25.91) p3(100 0 15.55) &
         p4(200 80 25.91) p5(100 80 27.62) p6(200 0 15.55) p7(200 80 27.62) group 3
         p0(200 0 13.84) p1(300 0 13.84) p2(200 80 25.91) p3(200 0 15.55) &
         p4(300 80 25.91) p5(200 80 27.62) p6(300 0 15.55) p7(300 80 27.62) group 3
;12煤/4.50m
gen zone brick size 25 20 7 ratio 0.8 1 1 &
         p0(0 0 15.55) p1(100 0 15.55) p2(0 80 27.62) p3(0 0 20.05) &
         p4(100 80 27.62) p5(0 80 32.12) p6(100 0 20.05) p7(100 80 32.12) group 4
gen zone brick size 30 20 7 ratio 1 1 1 &
         p0(100 0 15.55) p1(200 0 15.55) p2(100 80 27.62) p3(100 0 20.05) &
         p4(200 80 27.62) p5(100 80 32.12) p6(200 0 20.85) p7(200 80 32.12) group 4
gen zone brick size 25 20 7 ratio 1.2 1 1 &
         p0(200 0 15.55) p1(300 0 15.55) p2(200 80 27.62) p3(200 0 20.85) &
         p4(300 80 27.62) p5(200 80 32.12) p6(300 0 20.85) p7(300 80 32.12) group 4
;直接顶/4.77m
         p0(0 0 20.05) p1(100 0 20.05) p2(0 80 32.12) p3(0 0 24.82) &
         p4(100 80 32.12) p5(0 80 36.89) p6(100 0 24.82) p7(100 80 36.89) group 5
         p0(100 0 20.05) p1 (200 0 20.05) p2(100 80 32.12) p3(100 0 24.82) &
         p4(200 80 32.12) p5(100 80 36.89) p6(200 0 24.82) p7(200 80 36.89) group 5
         p0(200 0 20.05) p1(300 0 20.05) p2(200 80 32.12) p3(200 0 24.82) &
         p4(300 80 32.12) p5(200 80 36.89) p6(300 0 24.82) p7(300 80 36.89) group 5
;老顶/75.18m-63.11m
gen zone brick size 25 20 15 ratio 0.8 1 1.2 &
         p0(0 0 24.82) p1(100 0 24.82) p2(0 80 36.89) p3(0 0 100) &
         p4(100 80 36.89) p5(0 80 100) p6(100 0 100) p7(100 80 100) group 6
gen zone brick size 30 20 15 ratio 1 1 1.2 &
         p0(100 0 24.82) p1(200 0 24.82) p2(100 80 36.89) p3(100 0 100) &
         p4(200 80 36.89) p5(100 80 100) p6(200 0 100) p7(200 80 100) group 6
gen zone brick size 25 20 15 ratio 1.2 1 1.2 &
         p0(200 0 24.82) p1(300 0 24.82) p2(200 80 36.89) p3(200 0 100) &
         p4(300 80 36.89) p5(200 80 100) p6(300 0 100) p7(300 80 100) group 6
attach face
下面是 弹性条件下的计算  是不是那错了  ?
restore wangge.sav
model elas
;直接底
prop bulk 3.5e9 shear 2.5e9 range group 1
;12半煤
prop bulk 1.0e9 shear  0.65e9 range group 2
;夹矸
prop bulk 3.5e9 shear 2.5e9 range group 3
;12煤
prop bulk 1.0e9 shear  0.65e9 range group 4
;直接顶
prop bulk 1.93e9 shear 1.39e9 range group 5
;老顶
prop bulk 2.5e9 shear 2.0e9 range group 6
ini dens 2600
;边界条件
fix x range x -0.1 0.1
fix x range x 299.9 300.1
fix y range y -0.1 0.1
fix y range y 79.9 80.1
fix x y z range z -0.1 0.1
ini szz -11.54e6 grad 0,0,2.6e4 range z 0 100
ini sxx -23.08e6 grad 0,0,5.2e4 range z 0 100
ini syy -23.08e6 grad 0,0,5.2e4 range z 0 100
apply szz -8.94e6 range z 99.9 100.1
apply szz -11.54e6 range z -0.1 0.1
apply sxx -17.88e6 grad 0,0,5.2e5 range x -0.1 0.1
apply sxx -17.88e6 grad 0,0,5.2e5 range x 299.9 300.1
apply syy -17.88e6 grad 0,0,5.2e5 range y -0.1 0.1
apply syy -17.88e6 grad 0,0,5.2e5 range y 79.9 80.1
hist unbal
发表于 2007-3-24 09:08:37 | 显示全部楼层 来自 云南昆明
你最好是把你的问题说清楚一点,不然大家也没有很多时间来分析你的命令流,因为出现问题的可能性很多的。你把你已有的结果图发上来看一下,说说是哪里不对,高手们就可以很容易看出你的问题了。我的水平有限,不能帮你解决问题
 楼主| 发表于 2007-3-24 09:30:38 | 显示全部楼层 来自 北京
回复 #1 lzquan 的帖子
我吧椅上所有的命令输进去以后,模型应力已经显示是层状(通过重力自己计算的),我就想问还需要设定计算步吗?  我试过,可是算完的模型基本全显示是红色的,我是新手,还不怎么会看图。
要看某一个切面,命令是什么?
发表于 2007-3-24 10:17:25 | 显示全部楼层 来自 北京
pl set orig x y z norm xvector yvector zvector
pl cont disp plan
 楼主| 发表于 2007-3-24 10:21:17 | 显示全部楼层 来自 北京
回复 #3 lzquan 的帖子
前面的师兄 能不能举个例子阿,命令我试过,就是弄不出来
plot set plane orig x y z norm x y z 里面是orig 是从什么意思?
发表于 2007-3-24 15:37:36 | 显示全部楼层 来自 北京
面所通过任意一点的坐标!!!
仔细好好看看书吧!!!!一点点的试
发表于 2007-3-24 18:12:40 | 显示全部楼层 来自 江苏南京
是不是要建立接触面啊 各层之间!
我也使新手
发表于 2007-3-25 21:04:11 | 显示全部楼层 来自 北京
回复 #1 lzquan 的帖子
你把你的命令流打包传上来,我们才好看你的命令错在那里。
另外,
pl set orig (x y z) norm ( x y z )
pl cont disp plan
可以查看一个切面的变量, orgin 是一个点的坐标,normal 定义法向向量方向,你自己试试看吧。。
发表于 2007-3-25 21:06:10 | 显示全部楼层 来自 北京
土层与土层之间不需要建立接触面,建立接触面是土与其他:如桩,基础等模型不同的结构单元间建立接触面,用interface 命令建立。
发表于 2007-6-7 18:23:47 | 显示全部楼层 来自 陕西西安
这部分是多余的
发表于 2011-4-13 15:51:17 | 显示全部楼层 来自 江苏徐州
这部分命令为什么是多余的呢?
10# dk0852
GMT+8, 2024-9-25 04:29 , Processed in 0.043917 second(s), 14 queries , Gzip On, MemCache On.
