经测试,为发现你描述的问题!
不过在!!!!!!!!!!!!!!!!!!!!!!!!!!!save as之后的命令有些未使用参数
这里我把跨径参数改小了,经测试网格剖分正常。
!---------支座处量高
H=2
!---------跨中梁高
h_m=1.3
!---------翼板厚
d1=0.2
!---------顶板厚
d3=0.2
!---------底板厚
d2=0.3
!---------顶板内部倒角
t1=0.1
k1=0.2
!---------顶板外部倒角
t2=0.2
k2=0.6
!---------内箱宽
w=0.8
!---------支座处内箱高
u=1.5
!---------腹板宽
bw=0.4
!---------桥面宽
B=3.8
!---------第一层线性温度变化厚度
ht1=0.1
!---------中跨跨径
l1=20
!---------边跨跨径
l2=10
!---------支座不变高距离
l3=2
!----------进入前处理
/prep7
!----------定义单元
et,1,solid45
!----------定义材料泊松比
mp,prxy,1,0.2
!----------定义密度
mp,dens,1,2402
!----------定义杨氏模量
mp,ex,1,3.25e10
!----------定义线膨胀系数
mp,alpx,1,0.99e-5
!!----------建立模型
!----------建立关键点
k,1,0,0,-(l1+2*l2)/2
k,2,w/2,0,-(l1+2*l2)/2
k,3,w/2+bw,0,-(l1+2*l2)/2
k,4,w/2+bw,H-d1-t2,-(l1+2*l2)/2
k,5,w/2+bw+k2,H-d1,-(l1+2*l2)/2
k,6,B/2,H-d1,-(l1+2*l2)/2
k,7,B/2,H,-(l1+2*l2)/2
k,8,0,H,-(l1+2*l2)/2
k,9,-B/2,H,-(l1+2*l2)/2
k,10,-B/2,H-d1,-(l1+2*l2)/2
k,11,-(w/2+bw+k2),H-d1,-(l1+2*l2)/2
k,12,-(w/2+bw),H-d1-t2,-(l1+2*l2)/2
k,13,-(w/2+bw),0,-(l1+2*l2)/2
k,14,-w/2,0,-(l1+2*l2)/2
k,15,w/2,H-d3-t1,-(l1+2*l2)/2
k,16,w/2-k1,H-d3,-(l1+2*l2)/2
k,17,0,H-d3,-(l1+2*l2)/2
k,18,-(w/2-k1),H-d3,-(l1+2*l2)/2
k,19,-w/2,H-d3-t1,-(l1+2*l2)/2
!----------建立线
l,kp(0,0,-(l1+2*l2)/2),kp(w/2,0,-(l1+2*l2)/2)
l,kp(w/2,0,-(l1+2*l2)/2),kp(w/2+bw,0,-(l1+2*l2)/2)
l,kp(w/2+bw,0,-(l1+2*l2)/2),kp(w/2+bw,H-d1-t2,-(l1+2*l2)/2)
l,kp(w/2+bw,H-d1-t2,-(l1+2*l2)/2),kp(w/2+bw+k2,H-d1,-(l1+2*l2)/2)
l,kp(w/2+bw+k2,H-d1,-(l1+2*l2)/2),kp(B/2,H-d1,-(l1+2*l2)/2)
l,kp(B/2,H-d1,-(l1+2*l2)/2),kp(B/2,H,-(l1+2*l2)/2)
l,kp(B/2,H,-(l1+2*l2)/2),kp(0,H,-(l1+2*l2)/2)
l,kp(0,H,-(l1+2*l2)/2),kp(-B/2,H,-(l1+2*l2)/2)
l,kp(-B/2,H,-(l1+2*l2)/2),kp(-B/2,H-d1,-(l1+2*l2)/2)
l,kp(-B/2,H-d1,-(l1+2*l2)/2),kp(-(w/2+bw+k2),H-d1,-(l1+2*l2)/2)
l,kp(-(w/2+bw+k2),H-d1,-(l1+2*l2)/2),kp(-(w/2+bw),H-d1-t2,-(l1+2*l2)/2)
l,kp(-(w/2+bw),H-d1-t2,-(l1+2*l2)/2),kp(-(w/2+bw),0,-(l1+2*l2)/20)
l,kp(-(w/2+bw),0,-(l1+2*l2)/2),kp(-w/2,0,-(l1+2*l2)/2)
l,kp(-w/2,0,-(l1+2*l2)/2),kp(0,0,-(l1+2*l2)/2)
l,kp(w/2,0,-(l1+2*l2)/2),kp(w/2,H-d3-t1,-(l1+2*l2)/2)
l,kp(w/2,H-d3-t1,-(l1+2*l2)/2),kp(w/2-k1,H-d3,-(l1+2*l2)/2)
l,kp(w/2-k1,H-d3,-(l1+2*l2)/2),kp(0,H-d3,-(l1+2*l2)/2)
l,kp(0,H-d3,-(l1+2*l2)/2),kp(-(w/2-k1),H-d3,-(l1+2*l2)/2)
l,kp(-(w/2-k1),H-d3,-(l1+2*l2)/2),kp(-w/2,H-d3-t1,-(l1+2*l2)/2)
l,kp(-w/2,H-d3-t1,-(l1+2*l2)/2),kp(-w/2,0,-(l1+2*l2)/2)
l,kp(0,H,-(l1+2*l2)/2),kp(0,H-d3,-(l1+2*l2)/2)
l,kp(0,H-d3,-(l1+2*l2)/2),kp(0,0,-(l1+2*l2)/2)
!----------建立面
al,1,2,3,4,5,6,7,21,22
al,22,21,8,9,10,11,12,13,14
al,1,15,16,17,22
al,22,18,19,20,14
asba,1,3,,delete,delete
asba,2,4,,delete,delete
kwpave,kp(0,H,-(l1+2*l2)/2)
wprota,90,90,90
wpave,,H-ht1
asbw,all,delete
wpave,,H-d1
asbw,all,delete
wpave,,H-d1-ht1
asbw,all,delete
wpave,,H-d1-2*ht1
asbw,all,delete
aglue,all
wprota,90,90
wpave,w/2-k1
asbw,all,delete
wpave,-(w/2-k1)
asbw,all,delete
wpave,w/2
asbw,all,delete
wpave,-w/2
asbw,all,delete
wpave,w/2+bw/2
asbw,all,delete
wpave,-(w/2+bw/2)
asbw,all,delete
wpave,w/2+bw
asbw,all,delete
wpave,-(w/2+bw)
asbw,all,delete
wpave,w/2+bw+k2/2
asbw,all,delete
wpave,-(w/2+bw+k2/2)
asbw,all,delete
wpave,w/2+bw+k2
asbw,all,delete
wpave,-(w/2+bw+k2)
asbw,all,delete
!----------建立拉伸母线
num_k_1=kpinqr(0,14)
k,num_k_1+1,0,0,-(l1+2*l2)/2
k,num_k_1+2,0,0,(l1+2*l2)/2
l,num_k_1+1,num_k_1+2
!----------拉伸体
ksel,s,,,num_k_1+1,num_k_1+2,1
lslk,s,1
*get,num_l_1,line,,num,max
alls
vdrag,all,,,,,,num_l_1
wprota,,90,90
wpave,,,l1/2-l3/2
vsbw,all,delete
wpave,,,l1/2
vsbw,all,delete
wpave,,,l1/2+l3/2
vsbw,all,delete
wpave,,,-l1/2+l3/2
vsbw,all,delete
wpave,,,-l1/2
vsbw,all,delete
wpave,,,-l1/2-l3/2
vsbw,all,delete
alls
!--------中跨底板下沿
!--------抛物线模拟精度
l_div=0.5 !-----------需能被l1-2*l3/2及l2-l3/2整除
*dim,z_1,array,1/l_div*(l1-2*l3/2)+1,1
*dim,y_1,array,1/l_div*(l1-2*l3/2)+1,1
*do,i,1,1/l_div*(l1-2*l3/2)+1,1
z_1(i)=-(l1/2-l3/2)+l_div*(i-1)
num_temp=(H-h_m)/(l1/2-l3/2)/(l1/2-l3/2)
y_1(i)=-num_temp*z_1(i)*z_1(i)+(H-h_m)
*enddo
alls
num_k_2=kpinqr(0,14)
k,num_k_2+1+i,1,y_1(i),z_1(i)
*enddo
*do,i,1,1/l_div*(l1-2*l3/2),1
l,num_k_2+1+i,num_k_2+2+i
*enddo
alls
num_k_3=kpinqr(0,14)
k,num_k_3+1,-1,,-(l1/2-l3/2)
l,num_k_2+2,num_k_3+1
ksel,s,,,num_k_2+2
ksel,a,,,num_k_3+1
lslk,s,1
*get,num_l_2,line,,num,max
ksel,s,,,num_k_2+1,num_k_3
lslk,s,1
adrag,all,,,,,,num_l_2
asll
cm,a_sub_1,area
alls
vsel,s,loc,z,-l1/2,l1/2
vsba,all,a_sub_1,,delete,delete
ksel,s,loc,y,0,(H-h_m)
lslk,s,1
asll,s,1
vsla,s,1
vdele,all,,,1
alls
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!建议将体切开
!--------------save as
!--------边跨底板下沿(-Z侧)
alls
*dim,z_2_1,array,1/l_div*(l2-l3/2)+1,1
*dim,y_2_1,array,1/l_div*(l2-l3/2)+1,1
*do,i,1,1/l_div*(l2-l3/2)+1,1
z_2_1(i)=-(l1/2+l2)+l_div*(i-1)
num_temp=(H-h_m)/(l2-l3/2)/(l2-l3/2)
y_2_1(i)=-num_temp*(z_2_1(i)+l1/2+l3/2)*(z_2_1(i)+l1/2+l2+l2-l3/2)
*enddo
alls
num_k_4=kpinqr(0,14)
k,num_k_4+1+i,1,y_2_1(i),z_2_1(i)
*enddo
*do,i,1,1/l_div*(l2-l3/2),1
l,num_k_4+1+i,num_k_4+2+i
*enddo
alls
num_k_5=kpinqr(0,14)
k,num_k_5+1,-1,,-(l1/2+l3/2)
l,num_k_5,num_k_5+1
ksel,s,,,num_k_5
ksel,a,,,num_k_5+1
lslk,s,1
*get,num_l_3,line,,num,max
ksel,s,,,num_k_4+1,num_k_5
lslk,s,1
adrag,all,,,,,,num_l_3
asll
cm,a_sub_2,area
alls
vsel,s,loc,z,-(l1/2+l2),-l1/2
vsba,all,a_sub_2,,delete,delete
lslk,s,1
asll,s,1
vsla,s,1
vdele,all,,,1
!--------边跨底板下沿(+Z侧)
alls
*dim,z_3_1,array,1/l_div*(l2-l3/2)+1,1
*dim,y_3_1,array,1/l_div*(l2-l3/2)+1,1
z_3_1(i)=(l1/2+l2)-l_div*(i-1)
y_3_1(i)=-num_temp*(z_3_1(i)-(l1/2+l3/2))*(z_3_1(i)-(l1/2+l2+l2-l3/2))
*enddo
alls
num_k_6=kpinqr(0,14)
k,num_k_6+1+i,1,y_3_1(i),z_3_1(i)
*enddo
l,num_k_6+1+i,num_k_6+2+i
*enddo
alls
num_k_7=kpinqr(0,14)
k,num_k_7+1,-1,,l1/2+l3/2
l,num_k_7,num_k_7+1
ksel,s,,,num_k_7
ksel,a,,,num_k_7+1
lslk,s,1
*get,num_l_4,line,,num,max
ksel,s,,,num_k_6+1,num_k_7
lslk,s,1
adrag,all,,,,,,num_l_4
asll
cm,a_sub_3,area
alls
vsel,s,loc,z,l1/2+l2,l1/2
vsba,all,a_sub_3,,delete,delete
lslk,s,1
asll,s,1
vsla,s,1
vdele,all,,,1
!--------跨中底板上沿
alls
*dim,z_2,array,1/l_div*(l1-2*l3/2)+1,1
*dim,y_2,array,1/l_div*(l1-2*l3/2)+1,1
z_2(i)=-(l1/2-l3/2)+l_div*(i-1)
y_2(i)=-num_temp*z_2(i)*z_2(i)+(H-h_m)+d2
*enddo
alls
num_k1_2=kpinqr(0,14)
k,num_k1_2+1+i,1,y_2(i),z_2(i)
*enddo
l,num_k1_2+1+i,num_k1_2+2+i
*enddo
alls
num_k1_3=kpinqr(0,14)
k,num_k1_3+1,-1,d2,-(l1/2-l3/2)
l,num_k1_2+2,num_k1_3+1
ksel,s,,,num_k1_2+2
ksel,a,,,num_k1_3+1
lslk,s,1
*get,num_l1_2,line,,num,max
ksel,s,,,num_k1_2+1,num_k1_3
lslk,s,1
adrag,all,,,,,,num_l1_2
asll
cm,a_sub_1,area
alls
!--------边跨底板上沿(-Z侧)
alls
*dim,z_2_2,array,1/l_div*(l2-l3/2)+1,1
*dim,y_2_2,array,1/l_div*(l2-l3/2)+1,1
z_2_2(i)=-(l1/2+l2)+l_div*(i-1)
y_2_2(i)=-num_temp*(z_2_2(i)+l1/2+l3/2)*(z_2_2(i)+l1/2+l2+l2-l3/2)+d2
*enddo
alls
num_k1_4=kpinqr(0,14)
k,num_k1_4+1+i,1,y_2_2(i),z_2_2(i)
*enddo
l,num_k1_4+1+i,num_k1_4+2+i
*enddo
alls
num_k1_5=kpinqr(0,14)
k,num_k1_5+1,-1,d2,-(l1/2+l3/2)
l,num_k1_5,num_k1_5+1
ksel,s,,,num_k1_5
ksel,a,,,num_k1_5+1
lslk,s,1
*get,num_l1_3,line,,num,max
ksel,s,,,num_k1_4+1,num_k1_5
lslk,s,1
adrag,all,,,,,,num_l1_3
asll
cm,a_sub_2,area
alls
lslk,s,1
asll,s,1
vsla,s,1
vdele,all,,,1
!--------边跨底板上沿(+Z侧)
alls
*dim,z_3_2,array,1/l_div*(l2-l3/2)+1,1
*dim,y_3_2,array,1/l_div*(l2-l3/2)+1,1
z_3_2(i)=(l1/2+l2)-l_div*(i-1)
y_3_2(i)=-num_temp*(z_3_2(i)-(l1/2+l3/2))*(z_3_2(i)-(l1/2+l2+l2-l3/2))+d2
*enddo
alls
num_k1_6=kpinqr(0,14)
k,num_k1_6+1+i,1,y_3_2(i),z_3_2(i)
*enddo
l,num_k1_6+1+i,num_k1_6+2+i
*enddo
alls
num_k1_7=kpinqr(0,14)
k,num_k1_7+1,-1,d2,l1/2+l3/2
l,num_k1_7,num_k1_7+1
ksel,s,,,num_k1_7
ksel,a,,,num_k1_7+1
lslk,s,1
*get,num_l1_4,line,,num,max
ksel,s,,,num_k1_6+1,num_k1_7
lslk,s,1
adrag,all,,,,,,num_l1_4
asll
cm,a_sub_3,area
alls
lslk,s,1
asll,s,1
vsla,s,1
vdele,all,,,1
alls
ldele,num_l_1,,,1
ldele,num_l_2,,,1
ldele,num_l_3,,,1
ldele,num_l_4,,,1
ldele,num_l1_2,,,1
ldele,num_l1_3,,,1
ldele,num_l1_4,,,1
nummrg,all
numcmp,all
alls
ksel,s,loc,x,w/2+bw
ksel,r,loc,y,0
ksel,r,loc,z,l1/2
*get,n_l_1,kp,,num,max
ksel,s,loc,x,-(w/2+bw)
ksel,r,loc,y,0
ksel,r,loc,z,l1/2
*get,n_l_2,kp,,num,max
alls
l,n_l_1,n_l_2
ksel,s,,,n_l_1
ksel,a,,,n_l_2
lslk,s,1
*get,n_drag_1,line,,num,max
vsel,s,loc,z,l1/2+l3/2,l1/2-l3/2
vsel,a,loc,z,-l1/2+l3/2,-l1/2-l3/2
wpave,,0.3
wprota,,,90
vsbw,all,delete
ksel,s,loc,y,0,1
ksel,r,loc,x,0.8
lslk,s,1
asll,s,1
vdrag,all,,,,,,n_drag_1
alls
vovlap,all
!----------定义单元尺寸
esize,l_div/2+0.01,0
!----------单元网格划分
alls
ksel,s,loc,y,0,1
lslk,s,1
asll,s,1
vsla,s,1
vsel,u,loc,z,l1/2+l3/2,l1/2-l3/2
vsel,u,loc,z,-l1/2+l3/2,-l1/2-l3/2
vsweep,all
alls
esize,l_div/2,0
vsel,s,loc,y,1,2
vsweep,all
alls
vsweep,all |
