What result you are interested? the T(t) or, e.g. max temperature at each period?
If second case, use harmonic thermal analysis.
ANSYS take sine function input for load. You only need input amplitude and frequency. However, your load is rectangle waveform, you have to first use fourier transform to convert it into summation of sine() at different frequency.
