查看: 262|回复: 4
流固耦合的模态分析的建模问题
发表于 2007-4-30 16:56:47 | 显示全部楼层 |阅读模式 来自 英国
我的问题是:对水中做自由振动一个矩形板的模态分析,求其在水中的固有频率和主振形(mode shape)
我用ansys的建模方式是:(参照了例子vm177)
将模型建了三层,中间的是矩形板(SOLID45),上下两层是流体(FLUID30),使用模态分析求解(ANTYPE,MODAL). 但是我的模型计算的结果明显不对,都是0
本人还是个初学者,恳求大虾们不吝赐教,求教这类问题应该如何建模
________________
|                       | <----- fluid elementFLUID30
|_ ____________|
|___ __________| <------ plate SOLID45
|                        | <------ fluidelementFLUID30 |
|_____________  |
付我的code(关键程序都注释了,可惜不对,结果都是0)
/PREP7
/TITLE, NATURAL FREQUENCY OF SUBMERGED plate
p_length =  100     !length
p_width =   50      !half of width
p_E =  1.5e11       !Young's Modulus
p_D =  2330         !Density of plate
p_P =  0.17         !Poisson's ratios
f_D = 0.998         !Density of water
f_C = 344           !sound speed in water
p_thickness = 5     !the thickness of plate
ET, 1, FLUID30             ! FLUID ELEMENTS INTERFACING WITH STRUCTURE
ET, 2, SOLID45             ! SHELL ELEMENTS TO MODEL STEEL RING
ET, 3, FLUID30, ,1         ! NON-INTERFACING FLUID ELEMENTS
R,1,1                    !the reference pressure of fluid
! water properties
MP, DENS , 1, f_D
MP, SONC , 1, f_C              ! SPEED OF SOUND IN WATER
! plate properties
MP, EX, 2, p_E
MP, DENS, 2, p_D
MP, NUXY, 2, p_P
BLC4, 0, -50, 100, 100, p_thickness  !create the plate
WPAVE, , , p_thickness
BLC4, 0, -50, 100, 100, 200          !create the top fluid bulk
WPAVE, 0, 0, 0
BLC4, 0, -50, 100, 100, -200         !create the bottom fluid bulk
TYPE,1
MAT,1
REAL,1
ESIZE, , 16
VMESH, 2
VMESH,3                         !Mesh the fluid by usingthe FLUID30
TYPE,2
MAT,2
REAL,2
ESIZE, , 16
VMESH,1                         !Mesh the plate by usingthe SOLID45
NSEL, S, LOC, Y, 0     !select middle nodes(which Y=0)
NSEL, R, LOC, Z, 0
M, ALL, UZ                  !Defines master degrees of freedom
NSEL, S, LOC, X, 0
NSEL, R, LOC, Z, 0
D,ALL,ALL      !DOF constrains (clamped)
ESEL,ALL
NSEL,S,LOC,Z,0
NSEL,A,LOC,Z,p_thickness
ESLN
ESEL,INVE
TYPE,3
MAT,1
REAL,1
EMODIF,ALL                   !define uncoupled fluid elements
!define fluid-structure interface
NSEL, ALL
ESEL, S, TYPE, , 1
!fluid-structure interaction flag
NSEL, S, LOC, Z, 0
NSEL, A, LOC, Z, p_thickness
SF,ALL,FSI                 ! COUPLE STRUCTURAL MOTION & FLUID PRESS
! SET PRESSURE AT OUTER SURFACE TO ZERO
NSEL, S, LOC, Z, 200-p_thickness
NSEL, A, LOC, Z, -200
D, ALL, PRES, 0.0              !SET PRESSURE AT OUTER RADIUS TO ZERO
NSEL,ALL
ESEL,ALL
!OUTPR,ALL, 1                !Print out every items for every substeps
FINISH
/SOLU
ANTYPE,MODAL                   ! MODAL ANALYSIS
MODOPT,UNSYM,4,-100            ! SELECT UNSYMMETRIC MATRIX MODE EXTRACTION
MXPAND,,0.1,10000              ! EXPAND THE MODES OVER A SELECTED FREQUENCY
RANGE
SOLVE                        ! Solve the problem
/POST1
SET,FIRST,1                ! Read the first step result(fundamental
frequency)
PLDISP,1                     ! Display the mode shape
! save the first frequency to files
*GET, Freq, ACTIVE, 0, SET, FREQ
/OUT, Result_MA_P_F, vrt, ,
*VWRITE, Freq
(F10.4)
/OUT
FINISH
*LIST, Result_MA_P_F, vrt  !print out results
[ 本帖最后由 alber2008 于 2007-4-30 17:03 编辑 ]
 楼主| 发表于 2007-4-30 22:45:30 | 显示全部楼层 来自 英国
这个应该不是很复杂的问题吧,nobody knows???
 楼主| 发表于 2007-5-14 16:40:44 | 显示全部楼层 来自 英国
upupupupupupupupupupupupupup
 楼主| 发表于 2007-5-16 23:58:47 | 显示全部楼层 来自 英国
发表于 2007-8-2 10:02:20 | 显示全部楼层 来自 浙江杭州
你的分析系统是什么,你想求解流体加上固体这么一个系统的固有频率吗,显然是不对的,你这样的分析,没有搞清楚分析的目标是什么,到底是流体还是结构
GMT+8, 2024-9-21 15:39 , Processed in 0.054385 second(s), 13 queries , Gzip On, MemCache On.
