我做的就是用场路耦合模拟一个单相变压器的变比分析,
在低压侧加30000伏50Hz的交流电压,高压侧接一个100欧的电阻
命令流如下
KEYW,MAGNOD,1
!Part 1:intializing the parameter of geometry and properties,
Rc=1.51/2 !铁心半径 ;
Hc=3.49 !铁心高度;
Rh1=2.044/2 !高压绕组内半径;
Rh2=2.384/2 !高压绕组外半径;
h1=2.05 !高压绕组高
Wh=Rh2-Rh1 !高压绕组宽
Rl1=1.574/2 !低压绕组内半径;
Rl2=1.824/2 !低压绕组外半径;
l1=2.08 !低压绕组高
Lh=Rl2-Rl1 !低压绕组宽;
Nh=508 !Turns of high winding;
L=4.28 !变压器长;
H=3.720 !变压器高;
W=3 !变压器宽;
Nl=32 !Turns of low winding;
Hw=2.25 !内窗高
Ww=0.595 !内窗宽
R1=0.000003 !绕组电阻率
R2=0.000003 !油箱电阻率
R3=0.000003 !磁屏蔽电阻率
!Part 2:建立2维变压器模型
/PREP7
Rectng,0,Rc+Ww+Rc,-Hc/2,Hc/2
Rectng,0,L/2+0.022,-H/2-0.022,H/2+0.022 !磁屏蔽
Rectng,Rc,Rc+Ww,-Hw/2,Hw/2 !右内窗,铁心
Rectng,Rh1,Rh2,-h1/2,h1/2 ! 高压绕组
Rectng,Rl1,Rl2,-l1/2,l1/2 !低压绕组
AOVLAP,ALL
NumCmp,All
!Part 3:定义材料、单元
ET,1,PLANE53 !空气,铁心,油
ET,2,PLANE53,3, !高压铰线圈
ET,3,PLANE53,3, !低压铰线圈
ET,4,PLANE53,0, !油箱和磁屏蔽(算涡流)
MP,MURX,1,1 !油;
Mp,Murx,2,8000 !铁心
UIMP,3,MURX,RSVX,,1,R1 !高压线圈
UIMP,4,MURX,RSVX,,1,R1 !低压线圈
MP,MURX,5,1
r,1,Wh*h1,Nh,3.14*(Rh1+Rh2),1,1 !高压线圈单元的实常数
r,2,Lh*l1,Nl,3.14*(Rl1+Rl2),1,1 !低压线圈单元的实常数
ASEL,s,area,,1 !1号面高压线圈1
AATT,3,1,2
ASEL,s,area,,2 !2号面低压线圈2
AATT,4,2,3
Asel,S,area,,3 !
AATT,5,,4
Asel,S,area,,4 !
AATT,2,,1
Asel,S,area,,5 !
AATT,1,,1
!Part 4:划分单元网格
!part4.1:划分线圈
LSel,S,,,13
LSel,A,,,15
LSel,A,,,17
LSel,A,,,19
Lesize,All,,,30
LSel,S,,,12
LSel,A,,,14
LSel,A,,,16
LSel,A,,,18
Lesize,All,,,5
Asel,s,area,,1
Asel,A,area,,2
MShape,0,2D
Mshkey,1
Amesh,All
Allsel,All
!part4.2:划分铁心,空气油,油箱,磁屏蔽
Asel,s,area,,3
Asel,A,area,,4
Asel,A,area,,5
ESIZE,,30,
MShape,0,2D
Mshkey,0
Amesh,All
Allsel,All
!part4.1:细分磁屏蔽和油箱
Allsel,All
Lsel,s,,,1
Lsel,A,,,2
Lsel,A,,,3
!LREFINE,all,,,1,
! LREFINE,all,,,1,
!Part 5: 场路耦合;
!part5.1:高压侧1
Allsel,All
Et,50,Circu124
R,50,0.000000001
Et,5,Circu124,5 !高压铰线圈;
R,5,1
Et,6,Circu124
R,6,100
N,,-6,1
N,,-6,2
N,,-7,1
N,,-7,2
*Get,Nmax,Node,0,Num,Max
Type,6
Real,6
E,Nmax,Nmax-1 !Independent Current Source element;
Type,5
Real,5
E,Nmax-2,Nmax-3,241 !Stranded Coil element(To FEM domain)
Type,50
Real,50
E,Nmax,Nmax-2
E,Nmax-1,Nmax-3
NSEL,S,NODE,,Nmax-1
D,ALL,VOLT,0 !电压零点约束
!part5.3:低压侧1
Allsel,All
Et,7,Circu124,5 !低压铰线圈;
R,7,1
Et,8,Circu124,4,1
R,8,,30000,50
N,,6,1
N,,6,2
N,,7,1.5
N,,7,1
N,,7,2
Type,8
Real,8
E,Nmax-1,Nmax,Nmax-2
Type,7
Real,7
E,Nmax-3,Nmax-4,888 !Stranded Coil element(To FEM domain)
Type,50
Real,50
E,Nmax,Nmax-3
E,Nmax-1,Nmax-4
NSEL,S,NODE,,Nmax
Allsel,All
!Part6:耦合自由度
ESel,S,Mat,,3 !线圈
NSLE,S
CP,1,CURR,ALL
CP,2,EMF,ALL
Allsel,All
ESel,S,Mat,,4 !线圈
NSLE,S
CP,1,CURR,ALL
CP,2,EMF,ALL
Allsel,All
!Part 7: 加边界条件
ESEL,ALL
NSEL,EXT ! Select exterior nodes
D,ALL,AZ,0 ! Set potentials to zero (flux-parallel)
ALLSEL,ALL
FINISH |
