查看: 175|回复: 2
为什么我下载的simulink仿真程序打不开
发表于 2007-5-28 21:45:13 | 显示全部楼层 |阅读模式 来自 湖南湘潭
打开的时候,出现很多话:
Warning: Unable to load model file 'F:\study\倒立摆\程序\pidcontrolerfordlb\pidcontroler.mdl'.  Run "bdclose all; set_param(0, 'CharacterEncoding', Enc)" where Enc is one of windows-1252, ISO-8859-1, then load the model.  The first character that is not supported in the current character encoding setting ('ibm-1386_P100-2002') occurs on line 794, byte offset 21. To correctly load models with non-ASCII characters, you must explicitly use the character encoding that was used to save the file.  Type "help slCharacterEncoding" for more information on setting character encoding and to learn more about which encodings are commonly found on your platform.
??? Error using ==> open
'F:\study\倒立摆\程序\pidcontrolerfordlb\pidcontroler.mdl' is an invalid model name or the file 'F:\study\倒立摆\程序\pidcontrolerfordlb\pidcontroler.mdl' does not exist.
大家看看这是怎么回事啊,谢谢拉!!!
发表于 2007-6-4 22:21:47 | 显示全部楼层 来自 陕西西安
我也遇见过这种情况。这和字符的编码方式有关,警告信息是说,仿真模型中含有与你当前设置的编码方式('ibm-1386_P100-2002')不同的编码字符,出现在line 794, byte offset 21。用记事本打开看一下就清楚了,很可能是含有汉字或其他非西欧字符。运行help slCharacterEncoding,根据帮助信息重新设置一下编码方式就可以了,使用如下的命令set_param(0,'CharacterEncoding', 'ISO-8859-1'),其中参数'ISO-8859-1'改成你的当前版本支持的可以正确解码的方式,别忘记加上单引号啊。
 楼主| 发表于 2007-6-5 10:02:29 | 显示全部楼层 来自 湖南湘潭
太谢谢你了!
确实是的,有几个汉字注释就这样了.
GMT+8, 2026-1-6 10:25 , Processed in 0.030569 second(s), 14 queries , Gzip On, MemCache On.
