- 2006-6-14
感觉温度场分布不对,似乎不怎么传热,欢迎大家交流。
/prep7
/units,si
toffst,273
*set,rb,0.001
length=0.1
width=0.05
height=0.005
et,1,solid70
et,2,solid90
et,3,solid87
mptemp,1,20,250,500,750,1000,1500,1700,2500
mpdata,kxx,1,1,50,47,40,27,30,35,40,300
mpdata,c,1,1,460,480,530,675,670,660,780,820
mpdata,dens,1,1,7820,7700,7610,7550,7490,7350,7300,7090
mpdata,hf,1,1,24,46,73,140,125,224,400,450,500,500
block,0,0.1,0,0.05,-0.003,0
block,0,0.1,0,0.004,-0.003,0
block,0,0.1,0,0.01,-0.003,0
vovlap, all
numcmp,node
numcmp,area
numcmp,volume
Lesize,4,rb !定义焊缝区单元尺寸
Lesize,5,rb
Lesize,9,rb
Lesize,10,rb
Lesize,14,rb
Lesize,19,rb
Lesize,23,rb
Lesize,24,rb
Lesize,37,rb
Lesize,38,rb
Lesize,39,rb
Lesize,40,rb
Lesize,45,rb !定义过渡区单元尺寸
Lesize,46,rb
Lesize,47,rb
Lesize,48,rb
Lesize,26,3*rb !定义远缝区单元尺寸
Lesize,35,3*rb
Lesize,31,3*rb
Lesize,36,3*rb
Lesize,41,3*rb
Lesize,42,3*rb
Lesize,43,3*rb
Lesize,44,3*rb
Lesize,2,3*rb
Lesize,7,3*rb
Lesize,11,3*rb
Lesize,12,3*rb
Save
type,1 !划分网格
mat,1
mshkey,1
mshape,0
vmesh,1
vmesh,2
type,2
mat,1
mshape,1,3D
mopt,pyra,1
mshkey,0
mshape,1
vmesh,3
mopt,split,2
vimp,3,1,3
save
/solu
v=0.0045
tm=length/v
tinc=rb/v
U=25
I=100
ef=0.75
p=25*100*ef
r=0.003
qmax=3*p/(3.14159*r**2)
max_time=length/rb+1
max_x=length/rb+1
max_y=width/rb+1
*dim,flux2,table,max_x,max_y,max_time,x,y,time
*do,k,1,max_time,1
*do,i,1,max_x,1
flux2(i,0,k)=(i-1)*rb
*enddo
*do,j,1,max_y,1
flux2(0,j,k)=(j-1)*rb
*enddo
*do,i,1,max_x,1
*do,j,1,max_y,1
xcenter=v*(k-1)*tinc
ycenter=0
a=(i-1)*rb-xcenter
b=(j-1)*rb-ycenter
distance=sqrt(a**2+b**2)
*if,distance,le,r,then
flux2(i,j,k)=qmax/exp(3*distance**2/(r**2))
*else
flux2(i,j,k)=0
*endif
*enddo
*enddo
flux2(0,0,k)=(k-1)*tinc
*enddo
/solu
antype,trans
ic,all,temp,20
*do,t,1e-6,tm,tinc
time,t
autos,0
deltim,,,,1
kbc,1
nsel,s,loc,x,0,0.1 !选择要加载热源的节点
nsel,r,loc,y,0,0.05
nsel,r,loc,z,0,0
sf,all,hflux,%flux2%
FLST,5,3,5,ORDE,3 !选择要加载对流载荷的表面
FITEM,5,1
FITEM,5,3
FITEM,5,-4
ASEL,U, , ,P51X
ALLSEL,BELOW,AREA
NSLA,S,1
sf,all,conv,-1,20 !在节点上施加对流载荷(与空气的对流换热系数)
allsel,below,volu
timint,on !打开时间积分
tintp,,,,1 !将THETA设定为1
outres,all,all !输入每个子步的结果
solve
*enddo
finish |
