- 2006-12-14
发表于 2007-7-27 23:32:24
来自 德国
回复 #1 jwooh 的帖子
personal opinion, the bearing kinematic model should be built in adams, with the cage and innen outer ring defined as rigid bodies, and the rolling body such as balls as flexible bodies, the lubrications will be dealt later.. then define the movement of the innenring, balls and cages. the ball has 2 rotating velocity and can be calculated with cage rotating velocity and pressing angle and so on.. the balls will be first modeled in ansys as a NMF, netrual modal file, i dont know how to do it now though, and then input this file in adams later.
still everything remains unsolved to me, pff, need to hurry up -.-! |
