查看: 168|回复: 3
求助 关于弹簧单元的边界问题
发表于 2007-7-5 10:26:52 | 显示全部楼层 |阅读模式 来自 江苏南京
这是我做的关于承台的例子,我在承台底部加了弹簧单元来模拟桩土作用,我是加的竖向约束,只限制其竖向位移,但在计算时,出现模型倒塌了,可能是弹簧单元出现问题,但不知如何改动,求助各位大侠。
D:\cab0\1.dat
Starting Job on Thu Jul 05 09:40:21 2007
Checking prerequisite files...
Maximum memory allowed for solution = 455.8 mb
Initializing ... Stage 1
Initializing ... Stage 2
Allocating 455779736 bytes of memory ...
Starting Solution Process ...
Computation starts ...
Input phase...
Available memory for ADINA without sparse solver -   455.8 mb
Estimated storage by ADINA without sparse solver -    22.4 mb
Assemblage of linear matrices.
Calculate and store the load vector
Re-allocating 22066020 bytes of Memory ...
Initial contact penetration,contact group    1,no. of penetrating nodes      33
Storage used by the sparse solver (in-core) -   142.0 mb
Total storage occupied by the ADINA program -   164.0 mb
*** Stiffness matrix not positive definite ***
node=      5559 equation=      5116  dof= Z-TRANSLATION  pivot= -1.42443771E+01
node=     14239 equation=     30930  dof= X-TRANSLATION  pivot=  0.00000000E+00
node=     14239 equation=     30931  dof= Y-TRANSLATION  pivot=  0.00000000E+00
node=     14240 equation=     30933  dof= X-TRANSLATION  pivot=  0.00000000E+00
node=     14240 equation=     30934  dof= Y-TRANSLATION  pivot=  0.00000000E+00
node=     14241 equation=     30936  dof= X-TRANSLATION  pivot=  0.00000000E+00
node=     14241 equation=     30937  dof= Y-TRANSLATION  pivot=  0.00000000E+00
node=     14242 equation=     30939  dof= X-TRANSLATION  pivot=  0.00000000E+00
node=     14242 equation=     30940  dof= Y-TRANSLATION  pivot=  0.00000000E+00
node=     14242 equation=     30941  dof= Z-TRANSLATION  pivot=  0.00000000E+00
node=     14243 equation=     30942  dof= X-TRANSLATION  pivot=  0.00000000E+00
node=     14243 equation=     30943  dof= Y-TRANSLATION  pivot=  0.00000000E+00
Stiffness matrix not positive definite,boundary conditions or model collapsed
*** ERROR NO. A1002 ***
ENDCODE=1
*** Program stopped abnormally ***  Please see the *.out file for details.
Error encountered ...
Releasing network license ...
Job Canceled on Thu Jul 05 09:40:59 2007
发表于 2007-7-5 11:33:41 | 显示全部楼层 来自 美国
是否可以计算一个最简单的例子看一下弹簧单元如何使用?比如一个质点和一个弹簧构成的模型。
发表于 2007-7-21 10:13:57 | 显示全部楼层 来自 上海松江区
楼主的问题解决了吗
发表于 2007-8-23 15:14:47 | 显示全部楼层 来自 天津
这个我也琢磨了很久,可以先让整个模型生成网格以后再设弹簧元,而且要让弹簧元连接的两点位置处有节点,不能让弹簧元单独生成一个节点,但这样做了,模型虽然能算了还是有其他问题,还是要向高手请教。
GMT+8, 2024-9-21 15:44 , Processed in 0.028936 second(s), 10 queries , Gzip On, MemCache On.
