我做的模型是,铁心上绕着一个线圈,外面是空气层,用的是117单元做,想求出线圈的电感,但是到最后求解却出来"component COIL1 is not defined",我的命令里面写了cm,coils(1),elem,应该是定义了组件吧?可为什么还出现警告呢?命令流如下,各位帮忙看看哪个地方出错了,谢谢!
/COM, Magnetic-Edge
/PREP7
ET,1,SOLID117
ET,2,SOLID117
ET,3,SOLID117
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MURX,1,,1
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,PERX,1,,2e-7
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MURX,2,,5000
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MURX,3,,1
BLOCK,-0.05,0.55,-0.05,0.05,-0.35,0.35,
BLOCK,0.05,0.45,-0.05,0.05,-0.25,0.25,
FLST,2,2,6,ORDE,2
FITEM,2,1
FITEM,2,-2
VOVLAP,P51X
VDELE, 2, , ,1
CYLIND,0.1,0.075,-0.1,0.1,0,360,
CYL4, , ,2, , , ,2
FLST,3,1,6,ORDE,1
FITEM,3,2
VGEN, ,P51X, , , , ,-1, , ,1
FLST,2,3,6,ORDE,2
FITEM,2,1
FITEM,2,-3
VOVLAP,P51X
LOCAL,11,1,0,0,0, , , ,1,1,
CM,_Y,VOLU
VSEL, , , , 1
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 1, , 1, 11
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,VOLU
VSEL, , , , 3
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 2, , 2, 0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,VOLU
VSEL, , , , 4
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 3, , 3, 0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
FLST,5,4,4,ORDE,4
FITEM,5,2
FITEM,5,4
FITEM,5,-5
FITEM,5,7
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,18, , , , ,1
FLST,5,4,4,ORDE,2
FITEM,5,9
FITEM,5,-12
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,20, , , , ,1
FLST,5,28,4,ORDE,10
FITEM,5,1
FITEM,5,3
FITEM,5,6
FITEM,5,8
FITEM,5,13
FITEM,5,15
FITEM,5,18
FITEM,5,20
FITEM,5,25
FITEM,5,-44
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,6, , , , ,1
FLST,5,4,4,ORDE,2
FITEM,5,21
FITEM,5,-24
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,16, , , , ,1
FLST,5,4,4,ORDE,4
FITEM,5,14
FITEM,5,16
FITEM,5,-17
FITEM,5,19
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,14, , , , ,1
FLST,5,2,6,ORDE,2
FITEM,5,1
FITEM,5,3
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
FLST,5,10,4,ORDE,2
FITEM,5,45
FITEM,5,-54
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,4, , , , ,1
MSHAPE,1,3D
MSHKEY,0
CM,_Y,VOLU
VSEL, , , , 4
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
*SET,symfac,1
*SET,nc,1
*SET,ns,500
*dim,cur,array,nc
*dim,coils,char,nc
*SET,cur(1),1
*SET,oils(1),'coil'
*SET,coils(1),'coil'
FINISH
/SOL
FINISH
/PREP7
VSEL,S,MAT,,1
ALLSEL,BELOW,VOLU
VPLOT
cm,coils(1),elem
ALLSEL,ALL
VPLOT
FINISH
/SOL
ANTYPE,0
FLST,2,4,5,ORDE,2
FITEM,2,17
FITEM,2,-20
DA,P51X,AZ,0,0
VSEL,S,MAT,,1
ALLSEL,BELOW,VOLU
VPLOT
BFv,ALL,JS,,cur(1)*ns/0.005
ALLSEL,ALL
VPLOT
cnvtol,csg,,1.0e-4
eqslv,front
/STATUS,SOLU
SOLVE
VSEL,S,MAT,,1
ALLSEL,BELOW,VOLU
VPLOT
FINISH
lmatrix,1,'coil','cur','ind' |
