- 1
- 2008-12-14
发表于 2009-6-1 14:56:59
来自 香港
Firstly, please built a block in the ANSYS classic environment.
Secondly, please chose Solid 46 elment to mesh the block volume.
You can define the thinkness of each layer use Real constant.
The height of the block must equal to the thinkness of the composite material (laminate), and you can calculate the thinkness of each layer by the equation: t=h/n, where t is the thinkness of each layer, h is the height of the block and n is the total number of laminate layer. |
