- 2004-11-1
发表于 2007-12-20 09:35:48
来自 江苏苏州
看看是不是这个,readme里的
1. unrar crack.rar to c:\flexlm
2. edit c:\flexlm\msc2005.dat, replace <name> with your host name, save it.
3. run lmtools.exe, configuration using service, then click
congfig service tab, set 'path to lmgrd.exe' with C:\flexlm\LMGRD.EXE,
set 'path to the license file' with C:\flexlm\msc2005.dat, select
'use services', then click 'save service' button. now click
start/stop/reread tab, click start server button. ok. now
flexlm service should be start.
4. set the enviroment string: [email=LM_LICENSE_FILE=1700@<your]LM_LICENSE_FILE=1700@<your[/email] hostname>
dont forget to replace <your hostname> with your true hostname
5. Install MSC products, when asked for license, use [email=1700@<your]1700@<your[/email] hostname>
Enjoy this fine app:) |
