再次求助!管子对焊问题我在论坛上搜到了一个apdl的例子,但是那个例子也是没有最终做出来,我改了改,结果还是不行
焊缝热场也是轴向延伸的,没有体现出沿着圆周移动的效果,请高手指点啊!
下面是我参照一些例子改过的apdl(管子对接焊接),哪位高手帮着看看是哪的问题啊,万分感谢!
/prep7
/units,si
*afun,deg
*set,inradius,0.02
*set,outradius,0.03
*set,degree,90
*set,length,0.1
et,1,solid70
mp,dens,1,2640
mptemp,1,100,200,400,600,800,1000
mptemp,7,1200
mpdata,c,1,1,660.4,836,973.9,1061.7,1086.8,1103.5
mpdata,c,1,7,1128.6
mpdata,enth,1,1,0,7.583e4,2.592e5,4.619e5,6.875e5,9.528e5
mpdata,enth,1,7,1.278e6
mptemp,1,20,100,200,400,600,800
mptemp,7,1000,1200
mpdata,kxx,1,1,1.38,1.53,1.65,1.86,2.02,2.15
mpdata,kxx,1,7,2.29,2.43
csys,1
k,1,inradius,0,0
k,2,inradius,degree,0
k,3,inradius,degree,length
k,4,inradius,0,length
k,5,outradius,0,0
k,6,outradius,degree,0
k,7,outradius,degree,length
k,8,outradius,0,length
v,1,2,3,4,5,6,7,8
/view,1,1,1,1
lesize,5,,,5
lesize,6,,,25
lesize,8,,,50
mshkey,1
vatt,1,1,1
vmesh,1
save
*set,delt,1
*SET,qmax,10000000
*SET,r,0.004
*SET,pi,3.14159
*SET,lsize,0.002
*SET,v,0.003
*SET,tinc,lsize/v
*dim,flux2,table,25,50,25,y,z,time
*do,k,1,25,1
*do,i,1,25,1
*SET,flux2(i,0,k),(i-1)*lsize/(0.03*pi)*180
*enddo
*do,j,1,50,1
*SET,flux2(0,j,k),(j-1)*0.002
*enddo
*do,i,1,25,1
*do,j,1,50,1
*afun,deg
*SET,ycenter,v*(k-1)*tinc/(0.03*pi)*180
*SET,zcenter,length/2
a=(i-1)*lsize-ycenter
b=(j-1)*0.002-zcenter
*SET,distance,sqrt(a**2+b**2)
*if,distance,le,r,then
*SET,flux2(i,j,k),qmax/EXP(DISTANCE**2/(r**2))
*else
*SET,flux2(i,j,k),0
*endif
*enddo
*enddo
*SET,flux2(0,0,k),(k-1)*tinc
*enddo
/solu
*afun,deg
antype,trans
nroPt,auto,,!在完全瞬态分析中,指定Newton-raphson选项
*do,t,1e-6,15.71,tinc
time,t
autos,0
deltim,,,,1
kbc,1
allsel,all
asel,s,,,6
nsel,r,loc,y,0,90
nsel,r,loc,z,0,0.1
sf,all,hflux,%flux2%
timint,on !打开时间积分
tintp,,,,1 !将THETA设定为1
outres,all,all !输入每个子步的结果
solve
*enddo
finish |
