- 16
- 2006-6-3
楼主 |
发表于 2008-3-6 13:02:44
来自 美国
Thanks, molen. Intuitively, you are right. I also realize that the key is the tangent line.
By the way, you claim that: if (a,b) includes origin, than you can not get the linear function t(x) you want. This may not be always true. Consider my last example, if I just change (a,b) from (1.5,3) to (-3,3), the solutions have the exact same lower bound as before. Plus, there is a upper bound on s, too. Of course, if a function f(x) , such that f(0)>0, there is no solution at all.
My problem is that I don't have an explicit function f(x). I hope the result can apply to a family of functions with certain properties, i.e. differentiable. I would like to keep things in abstract manna and extract the sufficient conditions. But I do not want such conditions to be too restricted. Using the above example again, tangent line is the solution because that function f(x) is a global concave function. Otherwise, for a convex function, for example, the tangent line is blow the function. So, at this moment, we may simply say: for global concave differentiable functions, tangent lines will be the key for solutions. But "global concave" is a too strong limitation, even it is concave within the interval (a,b) is too restricted. I must consider more general functions. On the other hand, it is hard to tell if a condition is too restricted or not before it is given. |
