!下面的命令流进行的是一个简单的二维焊接分析, 利用ANSYS单元生死和热-结
构耦合分析功能进
!行焊接过程仿真, 计算焊接过程中的温度分布和应力分布以及冷却后的焊缝残
余应力。
finish
/clear
/filnam,1-2D element birth and death
/title,Weld Analysis by "Element Birth and Death"
/prep7
/unit,si !采用国际单位制
et,1,13,4 !13号二维耦合单元, 同时具有温度和位移自由度
et,2,13,4
et,3,13,4
!1号材料是钢
!2号材料是铝
!3号材料是铜
!铝是本次分析中的焊料, 它将钢结构部分和铜结构部分焊接起来
!下面是在几个温度点下, 各材料的弹性模量
mptemp,1,20,500,1000,1500,2000
mpdata,ex,1,1,1.93e11,1.50e11,0.70e11,0.10e11,0.01e11
mpdata,ex,2,1,1.02e11,0.50e11,0.08e11,0.001e11,0.0001e11
mpdata,ex,3,1,1.17e11,0.90e11,0.30e11,0.05e11,0.005e11
!假设各材料都是双线性随动硬化弹塑性本构关系
!下面是各材料在各温度点下的屈服应力和屈服后的弹性模量
tb,bkin,1,5
tbtemp,20,1
tbdata,1,1200e6,0.193e11
tbtemp,500,2
tbdata,1, 933e6,0.150e11
tbtemp,1000,3
tbdata,1, 435e6,0.070e11
tbtemp,1500,4
tbdata,1, 70e6,0.010e11
tbtemp,2000,5
tbdata,1, 7e6,0.001e11
tb,bkin,2,5
tbtemp,20,1
tbdata,1,800e6,0.102e11
tbtemp,500,2
tbdata,1,400e6,0.050e11
tbtemp,1000,3
tbdata,1, 70e6,0.008e11
tbtemp,1500,4
tbdata,1, 1e6,0.0001e11
tbtemp,2000,5
tbdata,1,0.1e6,0.00001e11
tb,bkin,3,5
tbtemp,20,1
tbdata,1,900e6,0.117e11
tbtemp,500,2
tbdata,1,700e6,0.090e11
tbtemp,1000,3
tbdata,1,230e6,0.030e11
tbtemp,1500,4
tbdata,1, 40e6,0.005e11
tbtemp,2000,5
tbdata,1, 4e6,0.0005e11
!材料密度(假设为常值)
mp,dens,1,8030
mp,dens,2,4850
mp,dens,3,8900
! 热膨胀系数(假设为常值)
mp,alpx,1,1.78e-5
mp,alpx,2,9.36e-6
mp,alpx,3,1.66e-5
!泊松比(假设为常值)
mp,nuxy,1,0.29
mp,nuxy,2,0.30
mp,nuxy,3,0.30
!热传导系数(假设为常值)
mp,kxx,1,16.3
mp,kxx,2,7.44
mp,kxx,3,393
!比热(假设为常值)
mp,c,1,502
mp,c,2,544
mp,c,3,385
!热膨胀系数(假设为常值)
!由于该13号单元还有磁自由度, 此处假设一磁特性, 但并不影响我们所关心的
结果
mp,murx,1,1
mp,murx,2,1
mp,murx,3,1
!假设焊料(铝)焊上去后的初始温度是1500℃
mp,reft,1,20
mp,reft,2,1500
mp,reft,3,20
!下面建立几何模型
csys,0
k,1,0,0,0
k,2,0.5,0,0
k,3,1,0,0 !长1米
k,4,0,0.3,0 !厚度0.3米(二维中叫做宽度)
k,5,0.35,0.3,0
k,6,0.65,0.3,0
k,7,1,0.3,0
a,1,2,5,4
a,2,6,5
a,2,3,7,6
!!!!!!!!!!!!!!!!!!!!!!!!!!划分网格!!!!!!!!!!!!!!!!!
esize,0.025
type,2
mat,2
amesh,2
esize,0.05 !网格划分出现问题
type,1
mat,1
amesh,1
mat,3
amesh,3
eplot
/solu
antype,4 ! 瞬态分析
trnopt,full
!!!!!!!!!!!!!!!!!!!!!!!!在模型的左边界加位移约
束!!!!!!!!!!!!!!!!!!!!!!!!!!!
nsel,all
*get,minx,node,,mnloc,x
nsel,s,loc,x,minx
d,all,ux,0
*get,miny,node,,mnloc,y
nsel,r,loc,y,miny
d,all,uy,0
!*****假设模型的左右边界处温度始终保持在20摄氏度左右*****
!其他边界条件如对流和辐射等均可施加,此处因为只是示意而已,故只施加恒
温边界条件
nsel,all
nsel,s,loc,x,minx
d,all,temp,20
nsel,all
*get,maxx,node,,mxloc,x
nsel,s,loc,x,maxx
d,all,temp,20
!!!!!!!!!!!!!!!由于第2个面是焊接所在区域,因此首先将该区域的单元“杀死
nna=2
esel,all
*get,emax,elem,,num,max
asel,s,area,,nna
esla
*get,nse,elem,,count
*dim,ne,,nse
*dim,nex,,nse
*dim,ney,,nse
*dim,neorder,,nse
mine=0
!下面的do循环用于将焊料区的单元按其形心y坐标排序
!以便后面模拟焊料由下向上逐步“生长”过程
*do,i1,1,nse
esel,u,elem,,mine
*get,nse1,elem,,count
ii=0
*do,i,1,emax
*if,esel(i),eq,1,then
ii=ii+1
ne(ii)=i
*endif
*enddo
*do,i,1,nse1
*get,ney(i),elem,ne(i),cent,y
*get,nex(i),elem,ne(i),cent,x
*enddo
miny=1e20
minx=1e20
*do,i,1,nse1
*if,ney(i),lt,miny,then
miny=ney(i)
minx=nex(i)
mine=ne(i)
*else
*if,ney(i),eq,miny,then
*if,nex(i),lt,minx,then
miny=ney(i)
minx=nex(i)
mine=ne(i)
*endif
*endif
*endif
*enddo
neorder(i1)=mine
*enddo
max_tem=1500 !按照前面假设,焊料的初始温度为1500℃
dt1=1e-3 !用于建立初始条件的一个很小的时间段
dt=5 !焊接一个单元所需的时间
t=0 !起始时间
esel,all
eplot
/auto,1
/replot
*do,i,1,nse
ekill,neorder(i)
esel,s,live
eplot
*enddo
allsel,all
!控制输出
outres,all,all
!设定初始环境
ic,all,temp,20
kbc,1
!是否瞬时加载
timint,0,struct
timint,1,therm
timint,0,mag
tintp,0.005,,,1,0.5,0.2
nsub1=2
nsub2=40
*do,i,1,nse
ealive,neorder(i)
esel,s,live
eplot
esel,all
!******下面的求解用于建立温度的初始条件******
t=t+dt1
time,t
nsubst,1
*do,j,1,4
d,nelem(neorder(i),j),temp,max_tem
*enddo
solve
!****下面的求解用于保证初始的升温速度为零****
t=t+dt1
time,t
solve
!*********下面的步骤用于求解温度分布**********
*do,j,1,4
ddele,nelem(neorder(i),j),temp
*enddo
t=t+dt-2*dt1
time,t
nsubst,nsub1
solve
*enddo
t=t+50000 !*********下面的步骤用于冷却过程求解*****
time,t
nsubst,nsub2
solve
save
finish
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!后处理过
程!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
/post1
!**************下面的一系列命令用于生成应力的动画文件*******
/seg,dele
/cont,1,15,0,1200e6/16,1200e6
/dscale,1,1.0
avprin,0,0
avres,1
/seg,multi,stress1,0.1
esel,all
*do,i,1,nse
esel,u,elem,,neorder(i)
*enddo
*do,i,1,nse
esel,a,elem,,neorder(i)
set,(i-1)*3+1,1
plnsol,s,eqv
*do,j,1,nsub1
set,(i-1)*3+3,j
plnsol,s,eqv
*enddo
*enddo
*do,i,1,nsub2
set,(nse-1)*3+4,i
plnsol,s,eqv
*enddo
/seg,off,stress1,0.1
/anfile,save,stress1,avi
!**********下面的一系列命令用于生成温度的动画文件************
/seg,dele
/cont,1,15,0,1500/16,1500
/dscale,1,1.0
avprin,0,0
avres,1
/seg,multi,temp1,0.1
esel,all
*do,i,1,nse
*enddo
*do,i,1,nse
set,(i-1)*3+1,1
plnsol,temp
*do,j,1,nsub1
set,(i-1)*3+3,j
plnsol,temp
*enddo
*enddo
*do,i,1,nsub2
set,(nse-1)*3+4,i
plnsol,temp
*enddo
/seg,off,temp1,0.1
/anfile,save,temp1,avi
finish
上面代码中涉及到排序问题,可以参考 |
