查看: 244|回复: 3
有奖求助:生死单元两道焊温度场模拟
发表于 2008-5-21 11:04:30 | 显示全部楼层 |阅读模式 来自 山东东营
/units,si
/config,nres,10000
!定义参数值
pi=3.1415926
y_dist=0.04
钢板宽度
x_dist=0.05
钢板长度
z_dist=0.008
钢板厚度
x_size=0.002
!x
向单元网格长度
y_size=x_size
!y
向单元网格长度
weld_v=0.01
焊接速度
weld_tm=x_dist/weld_v
焊接时间
tinc=x_size/weld_v
单元子步时间
weld_I=180
焊接电流
weld_U=20
焊接电压
ef=0.75
焊接热效率
weld_r=0.0071
有效加热半径
Qmax =3*weld_I*weld_U*ef/(pi*weld_r**2)
最大热流高斯密度
vdist1=0.008
vdist2=0.014
max_time=1+weld_tm/tinc
max_x=1+x_dist/x_size
max_y=1+2*vdist1/x_size
/prep7
et,1,solid70
keyopt,1,2,1
et,2,surf152
r,2
keyopt,2,4,1
keyopt,2,5,0
keyopt,2,8,1
mptemp,1,20,250,500,750,1000,1500,1700,2500
mpdata,kxx,1,1,50,47,40,27,30,35,140,142
mpdata,c,1,1,460,480,530,675,670,660,780,820
mpdata,hf,1,1,100,350,520,1000,1500,3000,3100,3500
mpdata,dens,1,1,7820,7700,7610,7550,7490,7350,7300,7090
!建模,划分网格
/PREP7
ET,1,SOLID70
ET,2,SURF152
BLOCK,0,0.05,-0.02,0.02,0,0.008,
ESIZE,0.002,0,
MSHAPE,0,3D
MSHKEY,1
CM,_Y,VOLU
VSEL, , , ,
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
FINISH
Allsel
Nsel,s,loc,z,0,0.004
Nsel,r,loc,y,-0.0020.002
Nsel,r,loc,x,0,0.05
Esln,,1
Cm,bdelem1, elem
Allsel
Nsel,s,loc,z,0.004,0.008
Nsel,r,loc,x,0,0.05
Esln,,1
Cm,bdelem2, elem
finish
边界条件求解
/solu
Ekill,bdelem2
*dim,weld_f,table,max_x,max_y,max_time,x,y,time
*do,k,1,max_time,1
*do,i,1,max_x,1
weld_f(i,0,k)=(i-1)*x_size
*enddo
*do,j,1,max_y,1
weld_f(0,j,k)=(j-1)*x_size-vdist1
*enddo
*do,i,1,max_x,1
*do,j,1,max_y,1
xcenter=weld_v*(k-1)*tinc
ycenter=0
  distance=sqrt(((i-1)*x_size-xcenter)**2+((j-1)*x_size-vdist1-ycenter)**2)
*if,distance,le,weld_r,then
weld_f(i,j,k)=Qmax*exp(-3*distance**2/(weld_r**2))!高斯移动热源公式
*else
weld_f(i,j,k)=0
*endif
*enddo
*enddo
weld_f(0,0,k)=(k-1)*tinc
*enddo
antype,trans
tunif,20
初始温度20
kbc,1
timint,on
autots,off
NROPT,FULL !设定牛顿-拉夫森选项
esel,s,type,,2
选择表面效应单元
nsle,s
sf,all,conv,-1,20
施加对流边界条件
allsel
tinc=tinc
载荷子步时间
*do,t,1e-6,weld_tm,tinc
time,t
autots,0
deltim,,,,1
kbc,0
渐变载荷
outres,all,all
tsres,erase
nsel, s,loc,z,0               有问题
sf, all,hflux,%weld_f%
solve
*enddo
sfdele,all,hflux
删除热流密度
allsel
t=t+4
冷却4
time,t
deltim,0.2,0.1,0.5
solve
t=t+10
冷却14
time,t
deltim,0.5,0.5,1
solve
t=t+10
冷却24
time,t
deltim,1,1,2
solve
t=t+50
冷却74
time,t
deltim,5,5,10
t=t+40
冷却114
time,t
deltim,10,10,20
T=T+400
TIME,T
DELTIM,50,50,100
solve
finish
第二次无法加载
/solu
Ealive,bdelem2
*dim,weld_f1,table,max_x,max_y,max_time,x,y,time
*do,m,1,max_time,1
*do,n,1,max_x,1
weld_f1(n,0,m)=(n-1)*x_size
*enddo
*do,g,1,max_y,1
weld_f1(0,g,m)=(g-1)*x_size-vdist1
*enddo
*do,n,1,max_x,1
*do,g,1,max_y,1
xcenter=weld_v*(m-1)*tinc
ycenter=0
  distance=sqrt(((n-1)*x_size-xcenter)**2+((g-1)*x_size-vdist1-ycenter)**2)
weld_f1(n,g,m)=Qmax*exp(-3*distance**2/(weld_r**2))!高斯移动热源公式
*else
weld_ f1(n,g,m)=0
*endif
*enddo
*enddo
weld_f1(0,0,m)=(m-1)*tinc
*enddo
antype,trans
kbc,1
timint,on
autots,off
esel,s,type,,2
选择表面效应单元
nsle,s
sf,all,conv,-1,20
施加对流边界条件
allsel
Tsres,erase
tinc=tinc
载荷子步时间
*do,t, 520+1e-6,weld_tm+520,tinc
time,t
autots,0
deltim,,,,1
kbc,0
渐变载荷
outres,all,all
tsres,erase
nsel,s,loc,z,z_dist/2
sf,all,hflux,%weld_f1%
solve
*enddo
sfdele,all,hflux
删除热流密度
allsel
t=t+4
冷却4
time,t
deltim,0.2,0.1,0.5
solve
t=t+10
冷却14
time,t
deltim,0.5,0.5,1
solve
t=t+10
冷却24
time,t
deltim,1,1,2
solve
t=t+50
冷却74
time,t
deltim,5,5,10
t=t+40
冷却114
time,t
deltim,10,10,20
T=T+400
TIME,T
DELTIM,50,50,100
solve
finish
又知道那里错的高手,请把改正意见发到我的邮箱(tiankun789789141@sina.com),咨询费RMB100,决不食言。
发表于 2008-5-21 20:14:48 | 显示全部楼层 来自 辽宁大连
都什么错误提示啊?
发表于 2009-3-16 14:01:26 | 显示全部楼层 来自 江西南昌
错误比较多
发表于 2011-5-26 17:03:07 | 显示全部楼层 来自 上海
学习一下,看来你研究很长时间了
GMT+8, 2024-9-20 09:34 , Processed in 0.044411 second(s), 10 queries , Gzip On, MemCache On.
