- 2008-5-18
关于密封圈压缩后加载压力,环境是ANSYS11.0。GUI如下:
Preprocessor->element type->add/edit/delete->add->hyperelastic->2D 4node 182
Preprocessor->Material props->material models->structural->nonlinear->elastic->hyperelastic->
mooney-rivlin->2 parameters,参数C10=1.87,C01=0.47.
Preprocessor->modeling->create->areas->circle->solid circle 画圆点为(0,0),半径为0.003425的圆
Preprocessor->keypoints 画点5(-0.005,-0.003425),6(0.003425,-0.003425),
7(0.003425,0.002775), 8(0.005, 0.002775),
9(0.006,0.003425), 10(-0.006, 0.003425)
Preprocessor->lines->lines->straight line 连接56,67,78,910
Preprocessor->meshing->mesh->areas->free 划分圆
Preprocessor->modeling->create->contact pair->contact wizard 选所有的线为刚性体,圆为柔性体,接触为面-面接触,磨擦系数设为0.2,改变不正确的接触方向
Solution->analysis type->new analysis->static
Solution->analysis type->sol’n controls basic中analysis option选的large displacement static
Number of substep=40 max=60 min=10
Solution->define loads->apply->structural->displacement->on lines 线56,67,78ALLDOF=0,线910UX=0,UY=-0.0005
Solution->load step opts->write LS file 设为一号载荷
Solution->define loads->apply->structural->pressure->on lines 加载在圆的左半线上,数值为20Mpa
Solution->load step opts->write LS file 设为二号载荷
Solution->solve->from LS files starting LS file number=1 ending LS file number=2
开始计算
一号载荷可以计算成功,二号载荷不行,错误说要增加子布来缓慢加载,我增加到1000了还不行,不知道什么原因,麻烦达人帮我看看是什么原因,
谢谢了 |
