- 2007-5-13
利用Mohr-Colonmb屈服准则和粘塑性方法分析边坡稳定性问题!
program exam2
! program exam2 plane strain of an elastic-plastic(Mohr-Coulomb) solid
! using 8-node quadrilateral elements; viscoplastic strain method
use new_library ; use geometry_lib ; implicit none
integer::nels,nxe,nye,neq,nband,nn,nr,nip,nodof=2,nod=8,nst=4,ndof, &
i,k,iel,iters,limit,incs,iy,ndim=2
logical::converged ; character(len=15) :: element='quadrilateral'
real::e,v,det,phi,c,psi,gama,dt,f,dsbar,dq1,dq2,dq3,lode_theta, &
sigm,pi,tnph,phif,snph,cf,tol
!---------------------------- dynamic arrays-----------------------------------
real ,allocatable :: kb(:,,loads(:),points(:,:),bdylds(:),bot(:),fos(:),&
evpt(:,:,:),oldis(:),top(:),depth(:),gravlo(:), &
dee(:,:),coord(:,:),fun(:),jac(:,:),weights(:), &
der(:,:),deriv(:,:),bee(:,:),km(:,:),eld(:),eps(:), &
sigma(:),bload(:),eload(:),erate(:),g_coord(:,:), &
evp(:),devp(:),m1(:,:),m2(:,:),m3(:,:),flow(:,:)
integer, allocatable :: nf(:,:) , g(:), no(:) ,num(:), g_num(:,:) ,g_g(:,:)
!-------------------------input and initialisation-----------------------------
open (10,file='exam2.dat',status= 'old',action='read')
open (11,file='exam2.res',status='replace',action='write')
read (10,*) phi,c,psi,gama,e,v, nels,nxe,nye,nn,nip,tol,limit
ndof=nod*nodof
allocate (nf(nodof,nn), points(nip,ndim),weights(nip),g_coord(ndim,nn), &
top(nxe+1),depth(nye+1),num(nod),dee(nst,nst),evpt(nst,nip,nels), &
bot(nxe+1),coord(nod,ndim),fun(nod),g_g(ndof,nels), &
jac(ndim,ndim),der(ndim,nod),deriv(ndim,nod),g_num(nod,nels), &
bee(nst,ndof),km(ndof,ndof),eld(ndof),eps(nst),sigma(nst), &
bload(ndof),eload(ndof),erate(nst),evp(nst),devp(nst),g(ndof), &
m1(nst,nst),m2(nst,nst),m3(nst,nst),flow(nst,nst))
nf=1; read(10,*) nr ; if(nr>0) read(10,*)(k,nf(:,k),i=1,nr)
call formnf(nf); neq=maxval(nf) ; read(10,*) top , bot , depth
!---------- loop the elements to find nband and set up global arrays ----------
nband = 0
elements_1: do iel = 1 , nels
call slope_geometry(iel,nye,top,bot,depth,coord,num)
call num_to_g(num,nf,g); g_num(:,iel)=num
g_coord(:,num)=transpose(coord); g_g(:,iel) = g
if (nband<bandwidth(g)) nband = bandwidth(g)
end do elements_1
write(11,'(a)') "Global coordinates "
do k=1,nn;write(11,'(a,i5,a,2e12.4)')"Node",k," ",g_coord(:,k);end do
write(11,'(a)') "Global node numbers "
do k = 1 , nels; write(11,'(a,i5,a,8i5)') &
"Element ",k," ",g_num(:,k); end do
write(11,'(a,i5,a,i5)') &
"The system has",neq," equations and the half-bandwidth is ",nband
allocate(kb(neq,nband+1),loads(0:neq),bdylds(0:neq),oldis(0:neq),gravlo(0:neq))
kb=0.0; oldis=0.0; gravlo=0.0
call deemat(dee,e,v); call sample(element,points,weights)
pi = acos( -1. ); tnph = tan(phi*pi/180.)
!----------------- element stiffness integration and assembly------------------
elements_2: do iel = 1 , nels
num = g_num(:,iel) ; coord = transpose(g_coord( : , num ))
g = g_g( : , iel ) ; km=0.0 ; eld = .0
gauss_pts_1: do i =1 , nip ; call shape_fun(fun,points,i)
call shape_der (der,points,i); jac = matmul(der,coord)
det = determinant(jac) ; call invert(jac)
deriv = matmul(jac,der) ; call beemat (bee,deriv)
km = km + matmul(matmul(transpose(bee),dee),bee) *det* weights(i)
do k=2,ndof,2;eld(k)=eld(k)+fun(k/2)*det*weights(i);end do
end do gauss_pts_1
call formkb (kb,km,g)
gravlo ( g ) = gravlo ( g ) - eld * gama ; gravlo(0) = .0
end do elements_2
!------------------------ factorise left hand side-----------------------------
call cholin(kb)
!------------------------trial factor of safety loop---------------------------
read(10,*) incs; allocate ( fos (incs )) ; read(10,*) fos
load_increments: do iy=1,incs
phif = atan(tnph/fos(iy))*180./pi; snph = sin(phif*pi/180.)
dt = 4.*(1.+v)*(1.-2.*v)/(e*(1.-2.*v+snph**2)) ; cf = c/fos(iy)
write(11,'(a,i5)') "Load increment",iy ; iters=0; bdylds=.0; evpt=.0
!---------------------------- iteration loop -------------------------------
iterations: do
iters=iters+1; loads = gravlo + bdylds ; call chobac(kb,loads)
!------------------------- check convergence --------------------------------
call checon(loads,oldis,tol,converged)
if(iters==1)converged=.false. ; if(converged.or.iters==limit)bdylds=.0
!----------------------- go round the Gauss Points ---------------------------
elements_3: do iel = 1 , nels
bload=.0
num = g_num( : , iel ) ; coord =transpose( g_coord( : ,num ))
g = g_g( : , iel ) ; eld = loads ( g )
gauss_points_2 : do i = 1 , nip
call shape_der ( der,points,i); jac=matmul(der,coord)
det = determinant(jac); call invert(jac) ; deriv = matmul(jac,der)
call beemat (bee,deriv); eps=matmul(bee,eld)
eps = eps -evpt( : , i , iel) ; sigma=matmul(dee,eps)
call invar(sigma,sigm,dsbar,lode_theta)
!------------------ check whether yield is violated -------------------------
call mocouf (phif, cf , sigm, dsbar , lode_theta , f )
if(converged.or.iters==limit) then
devp=sigma
else
if(f>=.0) then
call mocouq(psi,dsbar,lode_theta,dq1,dq2,dq3)
call formm(sigma,m1,m2,m3) ; flow=f*(m1*dq1+m2*dq2+m3*dq3)
erate=matmul(flow,sigma) ; evp=erate*dt
evpt(:,i,iel)=evpt(:,i,iel)+evp; devp=matmul(dee,evp)
end if; end if
if(f>=.0) then
eload=matmul(devp,bee) ; bload=bload+eload*det*weights(i)
end if
end do gauss_points_2
!------------------- compute the total bodyloads vector ----------------------
bdylds( g ) = bdylds( g ) + bload ; bdylds(0) = .0
end do elements_3
if(converged.or.iters==limit)exit
end do iterations
write(11,'(a)') " fos max displacement"
write(11,'(2e12.4)')fos(iy),maxval(abs(loads))
write(11,'(a,i5,a)') "It took",iters," iterations to converge"
if(iters==limit)stop
end do load_increments
end program exam2
[ 本帖最后由 whutzll 于 2008-8-15 23:23 编辑 ] |
