以前有贴子说
97单元不适合处理磁铁边界的问题
然后发了段小程序
我计算了三种情况
117单元
97单元未处理边界
97单元处理边界
我发现处理边界后效果反而没有原先的好
例子比较简单
有什么问题希望大家多多交流
/prep7
et,1,97,1
et,2,97
et,3,97,1
mp,murx,1,1
mp,rsvx,1,1e-4
mp,murx,3,1000
mp,rsvx,3,1e-5
mp,murx,2,1
blc5,,,1,1,1
blc5,,,2,2,1
blc5,,,4,4,1
vsel,all
vovlap,all
numcmp,all
vsel,s,,,1
vatt,1,1,1
vsel,s,,,2
vatt,2,2,2
vsel,s,,,3
vatt,3,3,3
vsel,all
vsel,s,,,1,2
aslv
lsla
lesize,all,,,10
vmesh,1
vsel,all
vsel,s,,,2,3
mshape,1,3d
mshkey,0
vmesh,all
vsel,s,,,3
asel,s,ext
lsla,s,ext
nsll,s,1
cm,mubdry2n,node
nsla,s,all
norl,all,,1 !这一条是我加上的,因为相对于下面nora的那一指令
cmse,u,mubdry2n
cm,mubdry1n,node
nora,all,1
alls
*get,nmax,node,,num,max
vsel,s,,,3
eslv,s,1
nsle
cm,scrap_e,elem
cm,scrap_n,node
ngen,2,nmax,all
egen,2,nmax,all
cmse,s,scrap_n
cmse,s,scrap_e
VCLEAR, all
vdele,all,,,1
alls
numc,node
alls ! UNSELECT "FLAT SURFACE" NODES, LEAVING CORNER
cmse,u,mubdry2n ! AND EDGE NODES. COUPLE AX/Y/Z ?????这一条为什么不是cmse,s,mubdry2n
cpintf,ax,1e-8
cpintf,ay,1e-8
cpintf,az,1e-8
alls ! UNSELECT EDGE/CORNER NODES, LEAVING ONLY FLAT
cmse,u,mubdry1n ! SURFACE NODES. COUPLE AY/Z ONLY?????这一条为什么不是cmse,s,mubdry1n
cpintf,ay,1e-8
cpintf,az,1e-8
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
allsel,all
esel,s,mat,,1
nsle
nsel,r,loc,z,1
d,all,volt,0
nsle
nsel,r,loc,z,0
cp,1,volt,all
*get,nmin,node,,num,min
f,nmin,amps,10000
asel,all
asel,s,ext
da,all,asym
finish
/solu
antype,harmic
harfrq,5000
allsel,all
solve
/prep7
et,1,117,1
et,2,117
et,3,117,1
mp,murx,1,1
mp,rsvx,1,1e-4
mp,murx,3,1000
mp,rsvx,3,1e-5
mp,murx,2,1
blc5,,,1,1,1
blc5,,,2,2,1
blc5,,,4,4,1
vsel,all
vovlap,all
numcmp,all
vsel,s,,,1
vatt,1,1,1
vsel,s,,,2
vatt,2,2,2
vsel,s,,,3
vatt,3,3,3
vsel,all
vsel,s,,,1,2
aslv
lsla
lesize,all,,,10
vmesh,1
vsel,all
vsel,s,,,2,3
mshape,1,3d
mshkey,0
vmesh,all
allsel,all
esel,s,mat,,1
nsle
nsel,r,loc,z,1
d,all,volt,0
nsle
nsel,r,loc,z,0
cp,1,volt,all
f,nmin,amps,10000
asel,all
asel,s,ext
da,all,az,0
finish
/solu
antype,harmic
harfrq,5000
allsel,all
solve
[ 本帖最后由 infrom 于 2008-8-27 10:20 编辑 ] |
