- 2004-10-6
c++中的STL库中的vector向量类在向量中任何位置都可以插入和删除单元。基本功能list一样了,比list的优势在于还能随机读取,太方便了。Fortran能不能实现呢?下面给出实现的一种方式,该方法适用于任何的数据类型,所以有些近似于c++模板的功能。
下面是个对c++ vector类的Fortran模拟,如果向量中没有指针,该方法是合适的!!
文件 vector.f90
type VECTOR
private
integer :: no_used
type(VECTOR_DATA), dimension(:), pointer :: data => null()
end type VECTOR
private
public :: VECTOR, VECTOR_DATA
public :: vector_create, vector_append, vector_at, &
vector_size, vector_put, vector_delete_elements, &
vector_destroy, vector_insert_empty
real, parameter :: growth_rate = 1.1
contains
! vector_create
! Create a new vector
! Arguments:
! vec Variable that should hold the vector
! capacity Initial capacity (optional)
! Note:
! The fields of the vector data structure are set
subroutine vector_create( vec, capacity )
type(VECTOR) :: vec
integer, optional :: capacity
integer :: cap
! Check that the vector does not have any data left
if ( associated(vec%data) ) then
call vector_destroy( vec )
endif
if ( present(capacity) ) then
cap = max( 1, capacity )
else
cap = 10
endif
allocate( vec%data(1:cap) )
vec%no_used = 0
end subroutine vector_create
! vector_destroy
! Destroy a vector
! Arguments:
! vec Vector in question
subroutine vector_destroy( vec )
type(VECTOR) :: vec
deallocate( vec%data )
endif
vec%no_used = 0
end subroutine vector_destroy
! vector_size
! Return the number of elements in use
! Arguments:
! vec Variable that holds the vector
integer function vector_size( vec )
type(VECTOR) :: vec
vector_size = vec%no_used
end function vector_size
! vector_at
! Get the value of the nth element of the vector
! Arguments:
! n Index of the element whose value
! should be retrieved
type(VECTOR_DATA) function vector_at( vec, n )
type(VECTOR) :: vec
integer :: n
if ( n .lt. 1 .or. n .gt. vec%no_used ) then
vector_at = empty_vector_data
else
vector_at = vec%data(n)
endif
end function vector_at
! vector_insert_empty
! Insert one or more empty elements
! Arguments:
! vector Vector in question
! pos Position to insert the empty elements
! number Number of empty elements
subroutine vector_insert_empty( vec, pos, number )
type(VECTOR) :: vec
integer, intent(in) :: pos
integer, intent(in) :: number
integer :: i
if ( number .lt. 1 .or. pos .lt. 1 .or. pos .gt. vec%no_used ) then
return
endif
if ( vec%no_used+number .ge. size(vec%data) ) then
call vector_increase_capacity( vec, vec%no_used+number )
endif
do i = vec%no_used,pos,-1
vec%data(i+number) = vec%data(i)
enddo
do i = 1,number
vec%data(pos+i-1) = empty_vector_data
enddo
vec%no_used = vec%no_used + number
end subroutine vector_insert_empty
! vector_delete_elements
! Delete one or more elements
! Arguments:
! pos Position to start deletion
! number Number of elements
subroutine vector_delete_elements( vec, pos, number )
type(VECTOR) :: vec
integer :: i
return
endif
do i = pos,vec%no_used-number
vec%data(i) = vec%data(i+number)
enddo
vec%no_used = vec%no_used - number
end subroutine vector_delete_elements
! vector_append
! Append a value to the vector
! Arguments:
! data Data to be appended
subroutine vector_append( vec, data )
type(VECTOR) :: vec
type(VECTOR_DATA) :: data
if ( vec%no_used .ge. size(vec%data) ) then
call vector_increase_capacity( vec, vec%no_used+1 )
endif
vec%no_used = vec%no_used + 1
vec%data(vec%no_used) = data
end subroutine vector_append
! vector_put
! Put a value at a specific element of the vector
! (it needs not yet exist)
! Arguments:
! data Data to be put in the vector
subroutine vector_put( vec, n, data )
type(VECTOR) :: vec
integer :: n
if ( n .lt. 1 ) then
return
endif
if ( n .gt. size(vec%data) ) then
call vector_increase_capacity( vec, n )
endif
vec%no_used = max( vec%no_used, n)
vec%data(n) = data
end subroutine vector_put
! vector_increase_capacity
! Expand the array holding the data
! Arguments:
! capacity Minimum capacity
subroutine vector_increase_capacity( vec, capacity )
type(VECTOR) :: vec
integer :: capacity
integer :: new_cap
type(VECTOR_DATA), dimension(:), pointer :: new_data
new_cap = max( capacity, nint( growth_rate * size(vec%data) ) )
if ( new_cap .gt. size(vec%data) ) then
allocate( new_data(1:new_cap) )
new_data(1:vec%no_used) = vec%data(1:vec%no_used)
new_data(vec%no_used+1:new_cap) = empty_vector_data
vec%data => new_data
endif
end subroutine vector_increase_capacity
主程序文件 main.f90
module DATA_MODULE
type REAL_DATA
real :: value
end type REAL_DATA
type(REAL_DATA), parameter :: empty_data = REAL_DATA(-999.0)
end module DATA_MODULE
! Module defining the vector type
module REAL_VECTORS
use DATA_MODULE, VECTOR_DATA => REAL_DATA, &
empty_vector_data => empty_data
include "vector.f90"
end module REAL_VECTORS
program test_vectors
use REAL_VECTORS
implicit none
type(VECTOR) :: vector1
integer :: i
! Create a vector and set some elements
call vector_create( vector1, 2 )
do i = 1,10
data%value = i
call vector_put( vector1, i, data )
enddo
write(*,*) 'Contents of the vector: numbers 1 to 10'
do i = 1,vector_size(vector1)
write(*,*) i, vector_at(vector1,i)
enddo
! Insert an element in the middle
call vector_insert_empty( vector1, 5, 3 )
data%value = 3.1415926
call vector_put( vector1, 5, data )
write(*,*) 'Contents of the vector: 1 to 4, pi, two empty, 5 to 10'
enddo
! Append an element at the end
data%value = exp(1.0)
call vector_append( vector1, data )
write(*,*) 'Contents of the vector: plus e'
enddo
! Delete the two empty entries
call vector_delete_elements( vector1, 6, 2 )
write(*,*) 'Contents of the vector: minus the empty ones'
enddo
end program
[ 本帖最后由 zhoulon 于 2008-11-10 08:10 编辑 ] |
