查看: 197|回复: 2
sph问题求救
发表于 2008-12-16 10:19:22 | 显示全部楼层 |阅读模式 来自 江苏南京
我做了个关于液体晃动的计算,70000个sph粒子,结果计算报下面的错误,折腾了好久没解决,不知道是不是内存的问题,高手帮我看下,非常感谢
*** INFO *** MEMORY ALLOCATION AFTER INPUT PHASE :
     TOTAL PEAK MEMORY USED ..........     18.93 Mbytes
     TOTAL ACTUAL MEMORY NEEDED ......     16.18 Mbytes
*** ERROR *** RESSOURCES EXHAUSTED.
              UNABLE TO ALLOCATE    2130.89 MEGABYTES OF MEMORY.
              MEMORY ALREADY ALLOCATE      31.02 MEGABYTES
*** INFO *** MEMORY ALLOCATION AFTER SOLUTION PHASE :
     TOTAL PEAK MEMORY USED ..........     31.02 Mbytes
     TOTAL ACTUAL MEMORY NEEDED ......     31.02 Mbytes
E R R O R   T E R M I N A T I O N
      TOTAL NUMBER OF CYCLES =        0
AVERAGE TIME PER ZONE CYCLE =     0.00
NUMBER OF SHELLS ELIMINATED =        0
NUMBER OF SOLIDS ELIMINATED =        0
NUMBER OF BEAMS  ELIMINATED =        0
                            CPU(s)    ELAPSED(s)    CPU%  ELAPS%
INPUT/INITIALIZATION     3.0000E+00  4.0000E+00  100.00  100.00
INTERNAL FORCES          0.0000E+00  0.0000E+00    0.00    0.00
NODAL OPERATIONS         0.0000E+00  0.0000E+00    0.00    0.00
OUTPUTS                  0.0000E+00  0.0000E+00    0.00    0.00
CONTACTS                 0.0000E+00  0.0000E+00    0.00    0.00
CONSTRAINTS(RB,RW,BC..)  0.0000E+00  0.0000E+00    0.00    0.00
KJOINT/MBS SOLVERS       0.0000E+00  0.0000E+00    0.00    0.00
ADAPTIVE MESH (STAMP)    0.0000E+00  0.0000E+00    0.00    0.00
TOTALS                   3.0000E+00  4.0000E+00  100.00  100.00
CPU TIME                  3.000E+00 (s)
ELAPSED TIME              4.000E+00 (s)
RATIO CPU/ELAPSED TIME        75.00  %
ERROR TERMINATION,EXITO MESSAGE
发表于 2008-12-22 16:10:20 | 显示全部楼层 来自 台湾
元素用少一点看看阿~只是建议
发表于 2009-2-9 10:59:04 | 显示全部楼层 来自 江苏南京
我也在做液体晃荡的例子,留个联系方式,交流交流吧
我邮箱coldfly_leng@126.com
GMT+8, 2026-1-2 20:00 , Processed in 0.030837 second(s), 15 queries , Gzip On, MemCache On.
