查看: 456|回复: 5
[错误和警告信息] 求助钢筋混凝土板的爆炸K文件的问题
发表于 2009-2-28 20:48:09 | 显示全部楼层 |阅读模式 来自 浙江杭州
求助:急请高手指教,我是新手,请教大家啊,感激不尽!
我用LS-dyna做钢筋混凝土板的爆炸分析,改好K文件,用LS-dyn Solver 求解时遇到以下问题:
Date: 02/24/2009
Time: 22:51:22
___________________________________________________
Livermore
Software
Technology
Corporation
7374 Las Positas Road
Livermore, CA 94551
Tel: (925) 449-2500
Fax: (925) 449-2507
www.lstc.com
|_________________________________________________|
LS-DYNA, A Program for Nonlinear Dynamic
Analysis of Structures in Three Dimensions
Version:
970
Date: 01/10/2005
Revision: 5434a
Time: 18:01:01
Features enabled in this version:
ANSYS Database format
Shared Memory Parallel
Licensed to:
Platform
OS Level
: WINDOWS XP
Hostname
: 606-49038c6a3f2
Precision
: Single precision (I4R4)
Unauthorized use infringes LSTC copyrights
Input file: C:\DOCUME~1\xiaqian\
桌面\5cmAl.k
The native file format
: 32-bit small endian
Memory size from command line:
200000000
expanding
memory to
200000000
notice
notice
notice
* This is the LS-DYNA Explicit Finite Element code.
* the validity, accuracy, or applicability of any results
* obtained from this system. The user must verify his own
* results.
* LSTC endeavors to make the LS-DYNA code as complete,
* accurate and easy to use as possible.
* Suggestions and comments are welcomed.
Please report any
* errors encountered in either the documentation or results
* immediately to LSTC through your site focus.
* Copyright (C) 1990-2005
* by Livermore Software Technology Corp. (LSTC)
* All rights reserved
notice
notice
notice
contracting memory to
2456376
expanding
memory to
4892752
expanding
memory to
8813488
expanding
memory to
19804180
expanding
memory to
19834180
expanding
memory to
19894180
expanding
memory to
19920792
expanding
memory to
19998152
expanding
memory to
20020759
expanding
memory to
27209405
expanding
memory to
27861861
expanding
memory to
28514317
expanding
memory to
29166773
expanding
memory to
40112465
expanding
memory to
40764921
2
LS-DYNA will perform a structural only analysis
RC SLAB FOR 10KG CHARGE WITH 5CM FOAM
ls-dyna (version 970
date 01/10/2005
expanding
memory to
3159
expanding
memory to
25800
expanding
memory to
7344773
expanding
memory to
26699430
expanding
memory to
27307504
expanding
memory to
30956068
26772790
expanding
memory to
43402928
expanding
memory to
43404949
43404928
expanding
memory to
43445708
expanding
memory to
55731826
expanding
memory to
73588362
expanding
memory to
147471994
expanding
memory to
147990707
expanding
memory to
148090043
expanding
memory to
154968461
153283116
expanding
memory to
155241021
153432423
expanding
memory to
153939177
153939177
153939177
expanding
memory to
153939257
153939257
expanding
memory to
155896625
expanding
memory to
155896732
expanding
memory to
155896738
expanding
memory to
165286492
expanding
memory to
288930302
*** Error Memory is set
88930302 words short
increase the memory size.
Current memory size
200000000
T i m i n g
i n f o r m a t i o n
CPU(seconds)
%CPU
Clock(seconds) %Clock
Initialization ....... 0.0000E+00
0.00
0.0000E+00
0.00
Element processing ... 0.0000E+00
0.00
0.0000E+00
0.00
Binary databases ..... 0.0000E+00
0.00
0.0000E+00
0.00
ASCII database ....... 0.0000E+00
0.00
0.0000E+00
0.00
Contact algorithm .... 0.0000E+00
0.00
0.0000E+00
0.00
Contact entities ..... 0.0000E+00
0.00
0.0000E+00
0.00
Rigid bodies ......... 0.0000E+00
0.00
0.0000E+00
0.00
Implicit Nonlinear ... 0.0000E+00
0.00
0.0000E+00
0.00
Implicit Lin. Alg. ... 0.0000E+00
0.00
0.0000E+00
0.00
T o t a l s
0.0000E+00
0.00
0.0000E+00
0.00
Problem time
0.0000E+00
Problem cycle
0
Total CPU time
0 seconds (
0 hours
0 minutes
0 seconds)
CPU time per zone cycle
0 nanoseconds
Clock time per zone cycle=
0 nanoseconds
Number of CPU's
NLQ used/max
96/
96
Start time
02/24/2009 22:51:22
End time
02/24/2009 22:52:16
Elapsed time
54 seconds (
0 hours
0 minutes 54 seconds)
E r r o r
t e r m i n a t i o n
我在customization preferences memory(words) 改为300000000 出现以下错误:
Date: 02/24/2009
Time: 22:55:11
Livermore
Software
Technology
Corporation
Livermore, CA 94551
Tel: (925) 449-2500
Fax: (925) 449-2507
www.lstc.com
Version:
970
Date: 01/10/2005
Revision: 5434a
Time: 18:01:01
Licensed to:
Platform
OS Level
: WINDOWS XP
Hostname
: 606-49038c6a3f2
Precision
桌面\5cmAl.k
300000000
expanding
memory to
300000000
*** Error LS-DYNA failed to allocate
300000000 words of memory.
Please use the memory option on the execute line.
T i m i n g
CPU(seconds)
%CPU
0.00
0.0000E+00
0.00
0.00
0.0000E+00
0.00
0.00
0.0000E+00
0.00
0.00
0.0000E+00
0.00
0.00
0.0000E+00
0.00
0.00
0.0000E+00
0.00
0.00
0.0000E+00
0.00
0.00
0.0000E+00
0.00
0.00
0.0000E+00
0.00
T o t a l s
0.0000E+00
0.00
0.0000E+00
0.00
Problem time
0.0000E+00
Problem cycle
0
Total CPU time
0 seconds (
0 hours
0 minutes
0 seconds)
0 nanoseconds
0 nanoseconds
Number of CPU's
0
NLQ used/max
96/
96
Start time
02/24/2009 22:55:11
End time
02/24/2009 22:55:11
Elapsed time
0 seconds (
0 hours
0 minutes
0 seconds)
E r r o r
我再改大customization preferences memory(words)数值 也是一样的
Error LS-DYNA failed to allocate的错误,我改成其他的数值要么是Error Memory is set
********* words short
的错误 要么是Error LS-DYNA failed to allocate 的错误,改到很大时干脆出现* Error Memory is set
2456376 words short
Current memory size
0
这样的错误
令我郁闷的是一样的K文件在师兄的电脑上可以算(没有改memory值,用的K文件里默认的300000000),在我的电脑上就不行,师兄电脑2G内存,我的4G
实在没法了,请教各位高手,不然我的工作没法继续了,谢谢!附上我的k文件,由于太大,我放在邮箱了,麻烦您下载下哦, goodgoodstu_dy@126.com 密码 goodgood 期待您的答复!
 楼主| 发表于 2009-3-11 16:14:49 | 显示全部楼层 来自 浙江杭州
为什么没有人回答我的问题啊,我哭了
发表于 2009-3-13 10:18:30 | 显示全部楼层 来自 福建三明
不懂,帮顶一下
发表于 2017-6-2 11:14:09 来自手机 | 显示全部楼层 来自 陕西西安
请问楼主,现在解决了吗
发表于 2020-6-8 17:39:17 | 显示全部楼层 来自 湖南长沙
您好,邮箱登陆不了了,能否发我一份k文件??非常感谢,1499957502@qq.com
发表于 2021-12-7 16:25:18 | 显示全部楼层 来自 湖北武汉
顶一下顶一下
GMT+8, 2026-1-7 04:56 , Processed in 0.034847 second(s), 16 queries , Gzip On, MemCache On.
