- 2008-7-23
预应力碳纤维布加固混凝土,怎么就不收敛呢,请教!!!命令流如下:
/FILNAME,PFRP ou,0
/TITLE,PCFRP BEAM
/com,structural
/prep7
et,1,link8 !定义钢筋单元
et,2,solid65 !定义混凝土单元
et,3,plane42 ! ?
et,4,shell41 !定义FRP单元
et,5,solid45 !定义垫块单元
KEYOPT,4,1,2 !
KEYOPT,2,7,1 !
r,1,33.18 !定义箍筋的面积(直径6.5 mm)
r,2,153.94 !定义受拉(压)筋面积(直径14mm)
r,3 !定义第3种实常数:混凝土
r,4,0.167 !定义CFRP的厚度(mm)
r,5 !定义第5种实常数:刚支座
mp,ex,1,2e5 !定义箍筋(和受压钢筋)的弹性模量
mp,prxy,1,0.25 !定义箍筋(和受压钢筋)的泊松比
mp,dens,1,7800e-9 !定义箍筋(和受压钢筋)的质量密度
tb,bkin,1,1,2,1 !定义非线性材料特性表, Bkin双线性随动强化:定义箍筋(和受压钢筋)的应力—应变曲线(采用经典双线性随动强化模型BKIN)
tbdata,,210 !单位N/mm2(和tbmodif命令有什么区别?),给当前数据表定义数据(配合tbtemp,及tb使用)
/axlab,x,strain !
/axlab,y,stress
tbplot,Bkin,1,,,yes !绘制应力—应变曲线
mp,ex,2,2e5 !定义受拉筋的弹性模量
mp,prxy,2,0.3 !定义受拉筋的泊松比
mp,dens,2,7800e-9 !定义受拉筋的质量密度
tb,bkin,2,1,2,1 !定义受拉筋的应力—应变曲线(采用经典双线性随动强化模型BKIN)
tbdata,,300 !定义受拉筋的极限强度
/axlab,x,strain
/axlab,y,stress
tbplot,Bkin,2,,,yes
mp,ex,3,3.3e4 !定义混凝土的弹性模量N/mm2(C45是3.35e4)
mp,prxy,3,0.2 !定义混凝土的泊松比
mp,dens,3,2500e-9 !定义混凝土的质量密度(单位Kg/mm3)
tb,conc,3,1,9
tbdata,,0.7,1.0,2.77,-1 !定义混凝土强度准则,张口裂缝的剪切传递系数0.7(祝0.3),闭合裂缝的剪切传递系数1.0,单轴抗拉强度2.77,-1表示该混凝土材料不具有抗压能力(是关闭压碎选项?)
!混凝土第2个Data,定义其本构关系,多线性随动强化(MISO)
tb,miso,3,,20 !
tbpt,,0.0001,3.3 !定义混凝土的本构关系,应力单位是Mpa
tbpt,,0.0003,8.523
tbpt,,0.0005,13.45
tbpt,,0.0007,17.83
tbpt,,0.0009,21.545
tbpt,,0.001,23.138
tbpt,,0.0012,25.793
tbpt,,0.0014,27.751
tbpt,,0.0016,29.057
tbpt,,0.0018,29.779
tbpt,,0.002,30 !即fc 为30 N/mm2,fcu,k达到65 N/mm2,E应该是3.65以上? tbpt,,0.0022,29.809
tbpt,,0.0024,29.294
tbpt,,0.0026,28.534
tbpt,,0.0028,27.601
tbpt,,0.003,26.551
tbpt,,0.0032,25.434
tbpt,,0.0034,24.285
tbpt,,0.0036,23.13
tbpt,,0.0038,22
/axlab,x,strain
/axlab,y,stress
tbplot,miso,3,,,yes !混凝土材料的编号为3
tb,concr,3 !定义混凝土的特征值
tbmodif,2,3,0.4
tbmodif,3,3,0.6
tbmodif,4,3,2.2 !35号混凝土开裂应力?
tbmodif,5,3,-1
!CFRP材料参数定义:
MP,EX,4,2.37e5
MP,EY,4,14816 !根据拉伸弹性模量2.37×105Mpa推得
MP,EZ,4,14816
MP,PRXY,4,0.17 !根据其它资料得到CFRP泊松比
MP,PRYZ,4,0.17
MP,PRXZ,4,0.17
MP,GXY,4,7408 !根据拉伸弹性模量2.37×105Mpa推得
MP,GYZ,4,7408
MP,GXZ,4,7408
mp,dens,4,1880e-9 !定义CFRP的质量密度(单位Kg/mm3)
mp,alpx,4,-7.0e-7 !FRP线膨胀系数(为负,后面采用升温法施加预应力),预应力施加后,Read Results,向上的位移大概0.031mm?
tbtemp,0 !为Data Table定义温度
!强度值在破坏准则中定义,具体为:
tb,fail,4, !4为材料号
tbtemp,,crit
tbdata,2,1 !1为最大应力破坏准则
tbtemp,
tbdata,10,4330,-2172,57.6,-316.8,57.6,- 316.8 !(纵向拉伸强度、纵向压缩强度、横向拉伸强度、横向压缩强度、Z向—厚度方向拉伸强度、Z向压缩强度) !根据拉伸拉伸强度4.33×103Mpa推得
tbdata,16,48,48,48 !(XY、YZ、XZ向剪切强度) !根据拉伸拉伸强度4.33×103Mpa推得
/axlab,x,strain
/axlab,y,stress
!定义刚支座垫块材料
mp,ex,5,2e5
mp,prxy,5,0.3
/pnum,node,1
/pnum,elem,1
n,1 !定义节点1
n,6,150 !定义节点9,梁宽150
fill,1,6 !利用节点填充命令生成中间7个节点
ngen,9,6,1,6,1,,31.25 !节点Y向复制,梁高250mm
ngen,29,1000,1,54,1,,,-100 !节点Z向复制,梁长2800mm
!另外产生左支座节点,后面没用?
NGEN,2,100000,1,9,1,,-25
NGEN,2,200000,1001,1009,1,,-25
NGEN,2,300000,2001,2009,1,,-25
!另外产生右支座节点
NGEN,2,100000,24001,24009,1,,-25
NGEN,2,100000,25001,25009,1,,-25
NGEN,2,100000,26001,26009,1,,-25
/view,1,1,1,1
nplot
type,1 !定义单元之前先声明即将定义单元的类型为Link8
real,1 !箍筋(直径6.5 mm)
mat,1 !钢筋
*do,i,8,10,1 !在节点11和16间依次建立箍筋单元,
e,i,i+1
*enddo
*do,i,44,46,1 !在节点83和88间依次建立单元,
e,i,i+1
*enddo
*do,i,8,38,6 !在节点11和74间依次建立单元,
e,i,i+6
*enddo
*do,i,11,41,6 !在节点17和80间依次建立单元,
e,i,i+6
*enddo
egen,29,1000,1,28,1 !
!受压钢筋单元建立
real,2 !受压钢筋(直径14mm)
mat,1 !钢筋
*do,i,44,27044,1000 !
e,i,i+1000
*enddo
*do,i,47,27047,1000
e,i,i+1000
*enddo
!受拉钢筋单元建立
type,1 !Link8
real,2 !主筋(直径14mm)
mat,2 !钢筋
*do,i,8,27008,1000
e,i,i+1000
*enddo
*do,i,11,27011,1000
e,i,i+1000
*enddo
type,4 !Shell41
real,4 !CFRP
mat,4 !CFRP
*do,i,2001,2005,1 !
*do,j,i,23000+i,1000 !
e,j,j+1,j+1000 !
e,j+1,j+1000,j+1000+1 !
*enddo
*enddo
/view,1,1,1,1
/pnum,elem,0
/pnum,node,0
/eshape,1
eplot
k,1
k,2,150
k,3,150,250
k,4,,250
a,1,2,3,4 !在上述关键点上生成一个面
lsel,s,loc,y,0 !定义新的选择集(选择沿y轴上y=0的面上的线)
lsel,a,loc,y,250 !定义新的选择集(选择沿y轴上y=250的面上的线)
lesize,all,,,5 !设定直线网格划分的等分数为
lsel,all
lsel,s,loc,x,0 !定义新的选择集(选择沿x轴上x=0的面上的线)
lsel,a,loc,x,150 !定义新的选择集(选择沿x轴上x=150的面上的线)
lesize,all,,,8 !设定直线网格划分的等分数为
type,3 !?
amesh,all !对前面生成的面划分网格
type,2 !Solid65
real,3 !混凝土
mat,3 !混凝土
extopt,esize,28 !?
extopt,aclear,1 !?
vext,all,,,,,-2800
!左刚支座单元的建立
k,9
k,10,150
k,11,150,-31.25
k,12,,-31.25
a,9,10,11,12 !在上述关键点上生成一个面
lsel,a,loc,y,-31.25 !定义新的选择集
lsel,all
lesize,all,,,1 !设定直线网格划分的等分数为1
type,3
amesh,7 !对7号面划分网格(前面拉伸后已经有6个面了,故从7开始编号)
type,5 !Solid45
real,5 !刚支座
mat,5 !刚支座
extopt,esize,2
extopt,aclear,1
vext,7,,,,,-200 !支座长是200 !定义拉伸的面,应该是前面划分网格的7号面
!右刚支座单元的建立
k,17,,,-2800
k,18,150,,-2800
k,19,150,-31.25,-2800
k,20,,-31.25,-2800
a,17,18,19,20 !在上述关键点上生成一个面
lsel,a,loc,y,-31.25 !定义新的选择集()
lsel,all
type,3
amesh,13 !对13号面划分网格(前面拉伸后已经有12个面了,故从13开始编号)
type,5 !Solid45
real,5 !刚支座
mat,5 !刚支座
extopt,esize,2
extopt,aclear,1
vext,13,,,,,200 !支座长是200 !定义拉伸的面,应该是前面划分网格的13号面
!左垫块单元的建立
k,25,0,250,-1000
k,26,150,250,-1000
k,27,150,281.25,-1000
k,28,0,281.25,-1000
a,25,26,27,28 !在上述关键点上生成面19
lsel,s,loc,y,250 !定义新的选择集(选择沿y轴上y=250的面上的线)
lsel,a,loc,y,281.25 !定义新的选择集(选择沿y轴上y=的面上的线)
lsel,all
type,3
amesh,19 !对19号面划分网格
type,5 !Solid45
real,5 !刚支座
mat,5 !刚支座
extopt,esize,2
extopt,aclear,1
vext,19,,,,,-200
!右垫块单元的建立
k,33,0,250,-1800
k,34,150,250,-1800
k,35,150,281.25,-1800
k,36,0,281.25,-1800
a,33,34,35,36 !在上述关键点上生成面25
lsel,all
type,3
amesh,25 !对25号面划分网格
type,5 !Solid45
real,5 !刚支座
mat,5 !刚支座
extopt,esize,2
extopt,aclear,1
vext,25,,,,,200 !支座长是200 !定义拉伸的面25
/pnum,mat,1
/pnum,node,0
/pnum,elem,0
/view,1,1,1,1
eplot
allsel
!nummrg,all !用all或node均是相同的警告,对计算结果影响不大
nummrg,node, , , ,low !合并FRP单元和混凝土单元节点,支座和CFRP的怎么合并\或者该处不设CFRP?
Nummrg,KP !如果多次发生合并命令,一定要先合并节点,再合并关键点。合并节点后,实体荷载不能转化到单元,此时可合并关键点解决问题
!CPINTF,ALL,0.0001 !(耦合),但生成许多约束符号,后面有警告?
numcmp,all !压缩相同编号的节点,复杂计算可以提高计算速度
eplot
FINISH
/SOL
nsel,s,loc,y,-31.25
nsel,r,loc,z,-100
d,all,uy
d,all,uz
d,all,ux !
nsel,s,loc,y,-31.25
nsel,r,loc,z,-2700
d,all,uy
d,all,uz
d,all,ux
allsel
gplot !绘制所有的实体
nsel,s,node,,1669,1669,1 !
nsel,a,node,,1670,1670,1 !a-再选择某些节点,加入Active节点中
f,all,fy,-27000 !集中力,单位是N
nsel,s,node,,1687,1687,1
nsel,a,node,,1688,1688,1
f,all,fy,-27000
allsel save
esel,s,type,,4 !用此命令为什么需要单独一行一行的输入或者执行两次bfe才能执行
eplot
bfe,all,temp,,2610
bfe,all,temp,,2610
nlgeom,on !打开大位移选项
nropt,full, !指定完全的牛顿-拉普森选项求解,祝202(对结果没有影响),郝239
eqslv,spar, ,0, !选用稀疏矩阵求解器SPARSE, 适用于实对称和非对称的矩阵, antype,0 !求解类型为静态分析
nsubst,200 !指定此荷载步的子步数200,
OUTRES,ERASE
outres,all,all !输出全部子步的结果
neqit,50 !在非线性分析中指定平衡迭代的最大次数(越大越容易收敛)
pred,on !在非线性分析中打开预测选项
ncnv,1 !终止分析选项(0 如果求解不收敛,也不终止分析, 1 如果求解不收敛,终止分析和程序(缺省),2如果求解不收敛,终止分析,但不终止程序)
cnvtol,U,,0.5,0,,!位移收敛控制(则应再用力收敛),容易收敛,0无穷范数控制收敛?MINREF值1.0)
cnvtol,f,,0.02,2,1 !设置迭代收敛准则(一般用力收敛控制即可,Value默认,Toler收敛标准为0.02, Specifies norm selection-NORM(残余力的第2范数控制收敛?),MINREF默认1)
allsel
acel,,9.8 !定义加速度
AUTOTS,1 !
LNSRCH,1 !
TIME,2 !
solve |
