- 2009-6-16
发表于 2010-3-23 15:55:39
来自 北京海淀
The executable C:\Program Files\simula\6.9-1\exec\explicit.exe aborted with system error code 693. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
楼主帮我看看,这是怎么回事?是在搞不明白 了 |
