- 2009-3-13
这是一个精馏塔仿真程序,我怎么看不懂啊!我因为做毕设刚刚接触mathematica,以前制学过c语言,看这个有点吃力,那位大侠替我解释下,或者给我发个mathematica程序设计的简单知识,比如代码解释什么的!我急啊!!
This is for the operating condition:
The TOTAL NUMBER OF STGRES EQUALS: 20+reboiler = 7/6/7 +reboiler.
This is a static model for an ideal reactive distillation column.
The reversible reaction involved in the distillation
column is: A + B = C + D.
The production spec. is 0.95 for both overhead and bottom.
The total holdup on reactive stages is 6 kmol.
RDSIM---reactive distillation simulation;
propdata---property data base;
xtov---from liquid composition to vapor flow calculation;
NewRap---Newton-Rapsion iteration subroutine
Mbalance---material balance subroutine;
Reaction---reaction subroutine;
acf---activity energy of forward reaction, cal/mol;
acb---activity energy of backward reaction, cal/mol;
af---preexponential factor of backward reaction;
alpha---relative volatility;
Avp--- vapor pressure coefficient;
bf---preexponential factor of forward reaction;
Bvp---vapor pressure coefficient;
Bc---specified D composition in bottom product;
component 1---A;
component 2---B;
component 3---C;
component 4---D;
cov---Newton-Raphsion covergent criterion;
cov1, cov2, cov3---error of vapor-liquid equilibrium;
dx---step length of Newton-Raphsion iteration;
error---error of component material balance equations;
ext---adjustion of step length;
fcomp---feed composition;
feedflow---feed flow rate;
holdup---stage holdup;
hor---heat of reaction, cal/mol;
hov---heat of vaporization,cal/mol;
i---component index;
j---stage index;
Lc---subsitute of liquid;
liquid---liquid flow rate;
mstep---Newton-Raphsion iteration number;
nstep---number of material balance calculation;
nt---total number of stages;
nc---total number of components;
ns---number of stages in the stripping section;
nfeed1---number of first feeding stage;
nfeed2---number of second feeding stage;
nrb---number of the bottom reactive stage;
press--- pressure of reactive distillation column;
ptimes---frequency of printing calculation results;
qfeed----feed thermal condition;
Qcon---condenser duty;
Qrea---exothermic reaction heat;
Qreb---reboiler duty;
rmax---maximum error of material balance;
rate---reaction rate, kmol/s;
R1---ideal gas law constant;
RR---reflux rate;
T0---ambient temperature;
tc--- subsitute of temp;
Tc---specified C composition in top product ;
temp---stage temperature;
vapor--- vapor flow rate;
vc---- subsitute of vapor;
xc---subsitute of xcomp;
xcomp--- liquid phase composition;
xtry, xtry1--- working arrays for decison variables;
yc---subsitute of ycomp;
ycomp---vapor phase composition;
Clear[RDSIM, NewRap, Mbalance, Reaction, Tc, Bc,
nfeed1, nfeed2, ns, nt, xtry,
feedflow, qfeed, fcomp, press, holdup,
xcomp, ycomp, liquid, vapor, temp, RR,
xc,yc,Lc,vc,
ratio, Avp, Bvp, error, rmax,
alpha, T0, mstep, nstep];
RDSIM[nfeed1_, nfeed2_, ns_, Tc_, Bc_, COPROD1_, COPROD2_]:=
Module[{NewRap, Mbalance, xtry,
feedflow, qfeed, fcomp,press,holdup,
xcomp, ycomp, liquid, vapor, temp, Qheat, RR,
xc,yc,Lc,vc,ratio,
Avp, Bvp, error, rmax, alpha, T0, mstep, nstep},
propdata[]:=Module[{},
(* Ideal gas law Constant, cal/mol/K *)
R1=1.987;
(* Vapor Pressure Constants: Ln P = Avp - Bvp/T *)
Avp[1]=12.3463; Avp[2]=11.6531;
Avp[3]=13.0394; Avp[4]=10.9600;
Bvp[1]=3862;Bvp[2]=3862;
Bvp[3]=3862;Bvp[4]=3862;
(* Relative Volatilities *)
alpha[1]=4;alpha[2]=2;
alpha[3]=8;alpha[4]=1;
(* Activity energy, cal/mol *)
acf=30000;
acb=140047/4.184;
(* Heat of reaction, cal/mol *)
hor=14527/4.184;
(* Heat of vaporization, mol/cal *)
hov=6944;
(* Preexponential factors, kf=af*Exp[-acf/(R*T)] and
kb=ab*Exp[-acb/(R*T)] *)
af=0.008*Exp[acf/(R1*366)];
ab=0.004*Exp[acb/(R1*366)];
(* Zero Absolute Temperature *)
T0=273.15;
xtov[]:=Module[{cov1, cov2, cov3, tguess1,
tguess2, tguess3, ysum, Vp},
Do[
{xc[4,j]=1-xc[1,j]-xc[2,j]-xc[3,j];
If[xc[4,j]<=0,
{xc[4,j]=0;
Do[xc[i,j]=xc[i,j]/(xc[1,j]+xc[2,j]+xc[3,j]+xc[4,j]),{i,1,nc}]}
},{j,1,nt}];
Do[
Do[
xtry[(i-1)*nt+k]=xc[i,k]
,{i,1,nc-1}];
,{k,1,nt}];
(* Stage temperature calculation *)
(* Guessing Temperature *)
Do[{
tguess1=Bvp[4]/(Avp[4]-Log[press])+ 0.1;
tguess2=Bvp[3]/(Avp[3]-Log[press])- 0.1;
Do[{
Vp[i]= Avp[i]-Bvp[i]/tguess1;
Vp[i]=Exp[Vp[i]]
},{i,1,nc}];
cov1=press;
Do[
cov1=cov1-xc[i,j]*Vp[i]
,{i,1,nc}];
Do[{
Vp[i]= Avp[i]-Bvp[i]/tguess2;
Vp[i]=Exp[Vp[i]]
},{i,1,nc}];
cov2=press;
Do[
cov2=cov2-xc[i,j]*Vp[i]
,{i,1,nc}];
cov3=press;
While[Abs[cov3]>=1.0*10^-8,
{tguess3=(tguess1+tguess2)/2;
Do[{
Vp[i]= Avp[i]-Bvp[i]/tguess3;
Vp[i]=Exp[Vp[i]]
},{i,1,nc}];
cov3=press;
Do[
cov3=cov3-xc[i,j]*Vp[i]
,{i,1,nc}];
If[cov3*cov1>=0,
{cov1=cov3;tguess1=tguess3},{cov2=cov3;tguess2=tguess3}];
tc[j]=tguess3;
(* Vapor phase composition calculation *)
ysum=0;
Do[
ysum=ysum+alpha[i]*xc[i,j]
,{i,1,nc}];
Do[
yc[i,j]=alpha[i]*xc[i,j]/ysum,
{i,1,nc}];
},{j,1,nt}];
(* liquid flow rate calculation *)
Reaction[];
Lc[1]=xtry[(nc-1)*nt+1];vc[nt]=xtry[(nc-1)*nt+2]/hov;
Do[Lc[j]=Lc[1],{j, 2, nrt-1}];
Do[Lc[j]=Lc[j-1]-rate[j]*hor/hov,{j, nrt, nrb}];
Do[Lc[j]=Lc[j]+qfeed[nfeed1]*feedflow[nfeed1],{j, nfeed1, nrb}];
Do[Lc[j]=Lc[j]+qfeed[nfeed2]*feedflow[nfeed2],{j, nfeed2, nrb}];
Do[Lc[j]=Lc[nrb],{j, nrb+1, nt-1}];
Lc[nt]=Lc[nt-1]-vc[nt];
(* Vapor flow rate calculation *)
Do[vc[j]=vc[nt],{j, nt-1, nrb+1, -1}];
Do[vc[j]=vc[j+1]+rate[j]*hor/hov,{j, nrb, nrt, -1}];
Do[vc[j]=vc[j]+(1-qfeed[nfeed2])*feedflow[nfeed2],{j, nfeed2, nrt, -1}];
Do[vc[j]=vc[j]+(1-qfeed[nfeed2])*feedflow[nfeed2],{j, nfeed1, nrt, -1}];
Do[vc[j]=vc[nrt],{j, nrt-1, 2, -1}];
vc[1]=vc[2];
Reaction[]:=Module[{kf, kb},
Do[{rate[j]=0;
Qrea[j]=0;
},{j,1,nt}];
Do[{
kf=af*Exp[-acf/(R1*tc[j])];
kb=ab*Exp[-acb/(R1*tc[j])];
rate[j]=holdup[j](kf*xc[1,j]*xc[2,j] - kb*xc[3,j]*xc[4,j]);
Qrea[j]=rate[j]*hor;
},{j, nrt, nrb}]
NewRap[]:= Module[{kk, ptimes, xtry1,
k, m, x1, JAC, JAC1, com1, com2, ext,
nom, er, er1, cov, jvalue, dx},
nstep=0;mstep=1;ptimes=1;
(* Initial Guess *)
xtry[(nc-1)*nt+1]=0.02;
xtry[(nc-1)*nt+2]=200;
xtry[2*nt+1]=Tc;
xtry[1]=xtry[nt+1]=(1-xtry[2*nt+1])/3;
xtry[nt]=xtry[2*nt]=xtry[3*nt]=(1-Bc)/3;
Do[
Do[
xtry[(i-1)*nt+k]=xtry[(i-1)*nt+1]-
(xtry[(i-1)*nt+1]-xtry[(i-1)*nt+nt])/(nt-1)*(k-1)
,{k,2,nt-1}]
,{i,1,nc-1}];
init=ReadList["xstatic.nb", Number];
Do[xtry[k1]=Part[init , k1], {k1, 1, (nc-1)*nt+2}];
Do[
Do[
xc[i,k]=xtry[(i-1)*nt+k]
,{i,1,nc-1}]
,{k,1,nt}];
xtov[];
nstep=nstep+1;
Print["The Number of Jacobi Inversion Calcuation:mstep = ", mstep];
Print["The Number of XtoV Calcuation:nstep = ", nstep];
Mbalance[];
Do[er[k]=error[k],{k,1,(nc-1)*nt+2}];
cov=Max[Table[Abs[er[k]],{k,1,(nc-1)*nt+2}]];
Print["cov=", cov, " ","Reflux rate =", xtry[(nc-1)*nt+1],
" ","Qreb = ", xtry[(nc-1)*nt+2]];
While[cov>=1*10^-8,{
Do[{xtry1[m]=xtry[m];
If[m>=(nc-1)*nt+1,xtry[m]=xtry[m]*0.98,
xtry[m]=xtry[m]*0.98];
Do[
Do[
,{i,1,nc-1}]
,{k,1,nt}];
xtov[];
nstep=nstep+1;
Mbalance[];
Do[er1[k]=error[k],{k,1,(nc-1)*nt+2}];
Do[{com1[k,m]=com2[k,m]=
(er[k]-er1[k])/(xtry1[m]-xtry[m]);
},{k,1,(nc-1)*nt+2}];
xtry[m]=xtry1[m]
},{m,1,(nc-1)*nt+2}];
JAC1=Table[com1[k,m],{k,1,(nc-1)*nt+2},{m,1,(nc-1)*nt+2}];
JAC1=Inverse[JAC1];
jvalue=Det[JAC1];
Do[{
Do[com2[k,m]=-er[k],{k,1,(nc-1)*nt+2}];
nom=Table[com2[k,kk],{k,1,(nc-1)*nt+2},{kk,1,(nc-1)*nt+2}];
dx=jvalue*Det[nom];
ext=0.0001;
If[mstep>=200,ext=0.005];
If[mstep>=220,ext=0.01];If[mstep>=240,ext=0.02];
If[mstep>=260,ext=0.04];If[mstep>=280,ext=0.1];
xtry[m]=xtry[m]+ext*dx;
If[m<=(nc-1)*nt && xtry[m]<=0,xtry[m]=0.000001];
If[m<=(nc-1)*nt && xtry[m]>=1.0,xtry[m]=xtry[m]-ext*dx];
If[m>=(nc-1)*nt+1 && xtry[m]<=0,{}];
Do[com2[kk,m]=com1[kk,m],{kk,1,(nc-1)*nt+2}]
Do[
Do[
,{i,1,nc-1}];
,{k,1,nt}];
xtov[];
nstep=nstep+1;mstep=mstep+1;
Mbalance[];
ptimes=ptimes+1;
Print["The Number of XtoV Calcuation:nstep=", nstep," The Number of Jacobi Inversion Calcuation: mstep = ", mstep];
If[ptimes>=30,{
Print["xc[1,j] ", "xc[2,j] ", "xc[3,j] ", "xc[4,j] ","Lc[j] ", "tc[j]", " rate[j]"];
Do[
Print[xc[1,k], " ",xc[2,k]," ", xc[3,k], " ",xc[4,k], " ",Lc[k]," ",tc[k], " ", rate[k]]
,{k,1,nt}];
Print[];
Print["yc[1,j] ", "yc[2,j] ", "yc[3,j] ", "yc[4,j] ", vc[j]];
Do[
Print[yc[1,k]," ", yc[2,k], " ",yc[3,k]," ", yc[4,k]," ",vc[k]]
,{k,1,nt}];
Print[];ptimes=0}];
Print["cov=", cov, " ","Reflux Rate =", xtry[(nc-1)*nt+1],
rmax=cov;
Do[{vapor[k]=vc[k];
liquid[k]=Lc[k];
temp[k]=tc[k];
Do[{
xcomp[i,k]=xc[i,k];
ycomp[i,k]=yc[i,k];
},{i,1,nc}];
},{k,1,nt}];
RR=xtry[(nc-1)*nt+1];
Qcon=vapor[1]*hov;
Qreb=xtry[(nc-1)*nt+2];
Mbalance[]:=Module[{k },
Reaction[];
Do[
{error[(i-1)*nt+1]=Lc[1]*xc[i,1]+(vc[1]-xtry[(nc-1)*nt+1])*yc[i,1]
-vc[2]*yc[i,2];
Do[error[(i-1)*nt+k]=Lc[k]*xc[i,k]+vc[k]*yc[i,k]
-Lc[k-1]*xc[i,k-1]-vc[k+1]*yc[i,k+1]
,{k, 2, nfeed1-1}];
error[(i-1)*nt+nfeed1]=Lc[nfeed1]*xc[i,nfeed1]+vc[nfeed1]*yc[i,nfeed1]
-Lc[nfeed1-1]*xc[i,nfeed1-1]-vc[nfeed1+1]*yc[i,nfeed1+1]-feedflow[nfeed1]*fcomp[i, nfeed1];
-Lc[k-1]*xc[i,k-1]-vc[k+1]*yc[i,k+1],{k,nfeed1+1,nfeed2-1}];
error[(i-1)*nt+nfeed2]=Lc[nfeed2]*xc[i,nfeed2]+vc[nfeed2]*yc[i,nfeed2]
-Lc[nfeed2-1]*xc[i,nfeed2-1]-vc[nfeed2+1]*yc[i,nfeed2+1]-feedflow[nfeed2]*fcomp[i, nfeed2];
-Lc[k-1]*xc[i,k-1]-vc[k+1]*yc[i,k+1],{k,nfeed2+1,nt-1}];
error[(i-1)*nt+nt]=Lc[nt]*xc[i,nt]+
vc[nt]*yc[i,nt]-Lc[nt-1]*xc[i,nt-1]
},{i,1,nc-1}];
Do[
Do[
If[i<=2, error[(i-1)*nt+k]=error[(i-1)*nt+k]+rate[k],error[(i-1)*nt+k]=error[(i-1)*nt+k]-rate[k]]
,{i, 1, nc-1}]
,{k, nrt, nrb}];
error[(nc-1)*nt+1]=Tc-yc[3,1];
error[(nc-1)*nt+2]=1-Bc-xc[1,nt]-xc[2,nt]-xc[3,nt];
(* Main Program *)
propdata[];
(* Number of components *)
nc=4;
nrt=nfeed1-COPROD1;nrb=nfeed2+COPROD2;
nt=nfeed2+ns+1;
Print["nfeed1 = ",nfeed1," nfeed2 = ",nfeed2,
" nrt = ",nrt, " nrb = ",nrb," nt = ",nt];
(* Operating Pressure, Ba *)
press=9;
(* Stage holdup, kmol *)
Do[holdup[j]=1.0*6/(nrb-nrt+1), {j, 1, nt}];
(* Feed information *)
Do[Do[fcomp[i,j]=0,{i, 1, nc}], {j, 1, nt}];
Do[feedflow[j]=qfeed[j]=0, {j, 1, nt}];
(* The Feed F1 information *)
fcomp[1,nfeed1]=0.0;fcomp[2,nfeed1]=1.0;
fcomp[3,nfeed1]=0.0;fcomp[4,nfeed1]=0.0;
qfeed[nfeed1]=1.0;
feedflow[nfeed1]=0.0126;
(* The Feed F2 information *)
fcomp[1,nfeed2]=1.0;fcomp[2,nfeed2]=0.0;
fcomp[3,nfeed2]=0.0;fcomp[4,nfeed2]=0.0;
qfeed[nfeed2]=1.0;
feedflow[nfeed2]=0.0126;
Print["The beginning of calculation"];
NewRap[];
Print["SUCCESS of NEWTON-RAPHSION ITERATIVE SOLUTION"];
Print["The Number of Jacobi Inversion Calcuation: mstep = ", mstep];
Print["The Maximum Error of Component Balance:rmax=",rmax];
Print[" Reflux Rate = ", RR ];
Print["Qcon = ",Qcon," Qreb = ",Qreb];
Print[];
Print["xcomp[1,j] ", "xcomp[2,j] ",
"xcomp[3,j] ", "xcomp[4,j]"];
Do[
Print[xcomp[1,j], " ", xcomp[2,j], " ",
xcomp[3,j], " ", xcomp[4,j]],
{j,1,nt}];
Print[];
Print["ycomp[1,j] ", "ycomp[2,j] ",
"ycomp[3,j] ", "ycomp[4,j]"];
Do[
Print[ycomp[1,j], " ", ycomp[2,j], " ",
ycomp[3,j], " ", ycomp[4,j]],
{j, 1, nt}];
Print[];
Do[
{Print["temp[",j,"]=",temp[j]," Qrea[",j,"]=",Qrea[j]];
},{j, 1, nt}];
Print[];
Do[Print["rate[",j,"]=", rate[j]],{j, 1, nt}];
Print[];
sumR=0;
Do[sumR = sumR + rate[j],{j, 1, nt}];
Print["sumR = ", sumR];
Do[Print["vapor[",j,"]=",vapor[j]],{j, 1, nt}];
Print[];
Do[Print["liquid[",j,"]=",liquid[j]],{j, 1, nt}];
Print[];
Do[
Do[{xcomp[i,j]>>>xfile;ycomp[i,j]>>>yfile},{i,1,nc}]
,{j, 1, nt}];
Do[{temp[j]>>>tfile;Qrea[j]>>>qrfile;
vapor[j]>>>vfile;liquid[j]>>>lfile
},{j, 1, nt}];
Do[xtry[k]>>>xstatic,{k, 1, (nc-1)*nt+2}];
RDSIM[9, 12, 7, 0.95, 0.95, 2, 5] |
