- 116
- 2007-6-28
发表于 2009-9-5 20:25:45
来自 新加坡
8# zsq-w 6.5有这个功能的,只是我不太明白那个创建平面截面时所说的2轴到底是个什么轴?按说一个法线和一个点就可以确定一个截面啊?
chenfei1233 发表于 2009-9-5 19:50
CAE Manual 46.2.1(我用6.9的,你可以找到你的版本的对应位置):
f you select the Key-in method, enter the coordinates for the following points, depending on the cut shape:
- For Plane cuts, enter the coordinates for the origin; the normal axis; and, optionally, axis 2. Axis 2 is an axis lying in the plane; the view cut can be rotated about this axis or about Axis 3, defined as the axis orthogonal to the normal axis and to Axis 2. See “Repositioning a view cut,” Section 46.2.3.
2轴就是让你指定一个面内的轴。 |
