查看: 156|回复: 5
激光焊的命令流(请教高手指点)
发表于 2009-4-2 18:40:16 | 显示全部楼层 |阅读模式 来自 安徽合肥
finish
/clear
/UNITS,SI
/filname,work1,1
/title,kdjkfkdsjg
/CONFIG,NRES,10000
/PREP7
*set,length,0.04
*set,width,0.04
*set,height,0.005
*SET,Vol,0.02
*SET,powe,80
*SET,lSIZE,0.001
*SET,TINC,lSIZE/Vol
*SET,Rad,0.001
*SET,pi,3.1415926
*SET,MAX_TIME,LENGTH/lSIZE+1
*SET,MAX_X,length/lSIZE+1
*SET,MAX_Y,width/lSIZE+1
*SET,power_max,0.85*powe/(pi*Rad*Rad)
*set,kk,1
et,1,solid70
keyopt,1,2,1
et,2,surf152
r,2
keyopt,2,4,1
keyopt,2,5,0
keyopt,2,8,4
MPTEMP,,,,,,,,
MPTEMP,1,20,100,200,300,400,500
mptemp,7,600,700,800,1000,1200
MPDATA,KXX,1,1,1.38,1.53,1.65,1.74,1.86,1.91
mpdata,kxx,1,7,2.02,2.09,2.15,2.29,2.43
mpdata,c,1,1,600.0,660.4,836.0,900.0,973.9,1000.0
mpdata,c,1,7,1061.7,1108.0,1086.8,1103.5,1128.6
mpdata,ex,1,1,7.78e10,7.78e10,7.78e10,8.2e10,8.2e10,8.2e10
mpdata,ex,1,7,8.2e10,8.2e10,8.52e10,8.52e10,8.52e10
mpdata,alpx,1,1,4.8e-10,5.1e-10,5.85e-10,6.27e-10,5.35e-10,6.12e-10
mpdata,alpx,1,7,6.00e-10,5.71e-10,5.62e-10,5.56e-10,5.42e-10
mp,prxy,1,1,0.17
MPDATA,DENS,1,1,2200
block,0,length,0, width, 0,height
esize,lsize
mshkey,1
vatt,1,1,1
vmesh,all
type,2
asel,s,,,1,6
amesh,all
eplot
Save
*dim,flux2,table,max_x,max_y,max_time,x,y,time
*do,k,1,max_time,1
  *do,i,1,max_x,1
   flux2(i,0,k)=(i-1)*lsize
  *enddo
  *do,j,1,max_y,1
   flux2(0,j,k)=(j-1)*lsize
  *enddo
  *do,i,1,max_x,1
    *do,j,1,max_y,1
     xcenter=vol*(k-1)*tinc
     ycenter=0
     distance=sqrt(((i-1)*lsize-xcenter)**2+((j-1)*lsize-ycenter)**2)
    *if,distance,le,rad,then
        flux2(i,j,k)=power_max/exp(kk*distance**2/(rad**2))
    *else
        flux2(i,j,k)=0
    *endif
    *enddo
  *enddo
  flux2(0,0,k)=(k-1)*tinc
*enddo
save
FINISH
/SOL
antype,trans
timint,on
autots,off
toffst,20
tunif,20
kbc,1
esel,s,type,,2
nsle,s
sf,all,conv,10,25
allsel
*SET,tim,1e-12
*do,I,1,MAX_TIME,1
*SET,tim,tim+tinc
time,tim
autots,off
deltim,,,,1
kbc,1
tsres,erase
Nsel,s,loc,z,height,height
Nsel,r,loc,x,0,length
Nsel,r,loc,y,0,0.02
Sf,all,hflux,%flux2%
allsel,all
asel,s,,,2
sfa,2,,hflux,%flux2%
Allsel,all
Solve
*enddo
save
FINISH
/POST1
set,last
plnsol,temp
请教各位高手,看看我的命令流有什么错误的地方,我模拟的图总感觉不对,待会上图
 楼主| 发表于 2009-4-3 09:32:44 | 显示全部楼层 来自 安徽合肥
怎么都不见人指教呀
 楼主| 发表于 2009-4-3 11:03:45 | 显示全部楼层 来自 安徽合肥
这是我的模拟图片焊缝温度过高,而且等温曲线也不对,请教高手指点
发表于 2009-4-3 16:19:35 | 显示全部楼层 来自 江西南昌
激光焊接采用椭球或锥体热源,高斯穿透能力有限
 楼主| 发表于 2009-4-3 17:56:01 | 显示全部楼层 来自 安徽合肥
谢谢zxw19851015 ,再请问有没有加载锥体的命令流?热源模型我已经学习了不少,但是命令流还是不行
发表于 2009-7-8 21:16:31 | 显示全部楼层 来自 江西南昌
好久没有来论坛了,不知道你还在不
GMT+8, 2024-9-21 01:29 , Processed in 0.069424 second(s), 13 queries , Gzip On, MemCache On.
