- 30
- 2003-4-18
发表于 2009-4-18 19:42:07
来自 江苏南京
1# qngb314
ANSYS中的MPC没用过,也不熟,
看你的要求用HM中的CERIG似乎可以解决,
Ansys中相关解释如下:
CERIG, MASTE, SLAVE, Ldof, Ldof2, Ldof3, Ldof4, Ldof5
Defines a rigid region.
]Constraint Equations
MASTE Retained (or master) node for this rigid region. If MASTE = P, then graphical picking of the master and slave nodes is enabled (first node picked will be the master node, and subsequent nodes picked will be slave nodes), and subsequent fields are ignored (valid only in GUI).
这样在HM中便可以按下图来设置dof了。
此外,有了Hm模型,export to ansys,在apdl里面添加MPC184单元应该可以的吧,
没用过。 |
