- 2007-7-20
excite primer中的例题讲解是不是漏了一些步骤?
我照着excite powerunit primer的例子做,好多次,都没法做出来.
而且我确定我没有操作错误.
请告知这是为什么,谢谢
有人能照着例子把它做出来吗?
% SYSTEM UNIT 2
% SYSTEM MNAM primer
% SYSTEM PIOL 1
% BODY DEF 1@ NOD6 2 0
% NAME 1@ Conrod1 CR01
% READI (_tmp_, &
% ConrodModeler.DOFT)
% BODY PRO 1@ DOFT _tmp_
$ BPRO Default data: [Available]
$ BPRO Check data: [New default data]
$ Information (Code 1850005)
Numbers of nodes and degrees of freedom of body >Conrod1<.
Number of nodes with DOFs in analysis set (grid + scalar): 3
Number of DOFs in analysis set (physical + dynamic): 18
% READR (_tmp_, &
% ConrodModeler.GEOM)
$ DELETE Array >>_tmp_ << is deleted from memory!
% BODY PRO 1@ GEOM _tmp_
% LOAD R _tmp_ 6 3
% 0 0 38.29
% 8019.43884707 0 0
% 0 0 -1679587.34452
% 0 0 0
% 0 -50.75594207 0
% 0 0 0 |
% BODY PRO 1@ FRM2 _tmp_
% SETIO BCD
% BODY PRO 1@ NAST
% SMAT : KXX KXX ::
% ConrodModeler.OUT4 |
$ BPRO Data block/file information for NASTRAN input filter:
$ BPRO [SMAT] KXX : KXX :: file -> ConrodModeler.OUT4
$ BPRO8 NASTRAN Input Filter / Body: 1@
$ BPRO8 -> SMAT - Stiffness matrix
$ BPRO8 Default data: [Available]
$ BPRO8 Check data: [Use local data]
$ BPRO8 Extraction: [ok]
% SETIO BCD
% BODY PRO 1@ NAST
% MMAT : MXX MXX ::
$ BPRO [MMAT] MXX : MXX :: file -> ConrodModeler.OUT4
$ BPRO8 -> MMAT - Mass matrix
% BODY PRO 1@ DMAT D=aM+bS 41.8879020479 1.48544613552e-005
$ BPRO9 Default data: [Available]
$ BPRO9 Check data: [Use local data]
% READI (_tmp_, &
% ConrodModeler.KDIC)
% BODY PRO 1@ KDIC _tmp_
% SETIO BCD
% READ4 (_tmp_, KELM, &
% ConrodModeler.KELM)
% BODY PRO 1@ KELM _tmp_
% LOAD R _tmp_ 724 4 [email=1@.L]1@.L[/email]
% BODY PRO 1@ LOAD _tmp_
% BODY INT 1@ NEWM 0.25 0.5
$ DELETE Array >>1@N << is deleted from memory!
% BODY DEF 2@ CON6 2 -1
$ BDEF1 Warning: The definition of a reference node may lead to
$ BDEF1 loss of accuracy in certain applications.
% NAME 2@ Crankshaft CS
% READI (_tmp_, &
% ../../fem/Crankshaft/Crankshaft.DOFT)
% BODY PRO 2@ DOFT _tmp_
$ BPRO Check data: [Use default data]
$ Information (Code 1850007)
Numbers of nodes and degrees of freedom of body >Crankshaft<.
Number of nodes with DOFs in analysis set (grid + scalar): 36
Number of DOFs in analysis set (physical + dynamic): 86
Number of grid points with DOFs in analysis set: 16
Number of physical DOFs in analysis set: 66
Total number of nodes: 3472
Total number of DOFs: 11258
% READR (_tmp_, &
% ../../fem/Crankshaft/Crankshaft.GEOM)
% BODY PRO 2@ GEOM _tmp_
% LOAD R _tmp_ 6 3
% 0 0 0
% 0 0 0
% 0 0 0
% 0 0 0
% 0 209.439510239 0
% 0 0 0 |
% BODY PRO 2@ FRM1 _tmp_
% SETIO BCD
% BODY PRO 2@ NAST
% SMAT : KXX KSAA ::
% ../../fem/Crankshaft/Crankshaft.OUT4 |
$ BPRO [SMAT] KXX : KSAA :: file -> ../../fem/Crankshaft/Crankshaft.OUT4
$ BPRO8 NASTRAN Input Filter / Body: 2@
$ BPRO8 Default data: [Not available]
$ BPRO8 Extraction: [error]
$ Error (Code 1860008)
Body Crankshaft:
Error in opening NASTRAN file: ../../fem/Crankshaft/Crankshaft.OUT4
User action: (1) Check the defined file name.
(2) Check the file. |
