- 4
- 2006-4-23
发表于 2009-4-30 18:43:00
来自 大连理工大学
C3D4 4-node linear tetrahedron (Section 22.1.4)
C3D4E 4-node linear piezoelectric tetrahedron (Section 22.1.4)
C3D4H 4-node linear tetrahedron, hybrid, linear pressure (Section 22.1.4)
C3D4T 4-node thermally coupled tetrahedron, linear displacement and temperature (Section 22.1.4)
C3D6 6-node linear triangular prism (Section 22.1.4)
C3D6E 6-node linear piezoelectric triangular prism (Section 22.1.4)
C3D6H 6-node linear triangular prism, hybrid, constant pressure (Section 22.1.4)
C3D6T 6-node thermally coupled triangular prism, linear displacement and temperature (Section 22.1.4)
C3D8 8-node linear brick (Section 22.1.4)
C3D8E 8-node linear piezoelectric brick (Section 22.1.4)
C3D8H 8-node linear brick, hybrid, constant pressure (Section 22.1.4)
C3D8HT 8-node thermally coupled brick, trilinear displacement and temperature, hybrid, constant pressure (Section 22.1.4)
C3D8I 8-node linear brick, incompatible modes (Section 22.1.4)
C3D8IH 8-node linear brick, hybrid, linear pressure, incompatible modes (Section 22.1.4)
C3D8P 8-node brick, trilinear displacement, trilinear pore pressure (Section 22.1.4)
C3D8PH 8-node brick, trilinear displacement, trilinear pore pressure, hybrid, constant pressure (Section 22.1.4)
C3D8R 8-node linear brick, reduced integration, hourglass control (Section 22.1.4)
C3D8RH 8-node linear brick, hybrid, constant pressure, reduced integration, hourglass control (Section 22.1.4)
C3D8RHT 8-node thermally coupled brick, trilinear displacement and temperature, reduced integration, hourglass control, hybrid, constant pressure (Section 22.1.4)
C3D8RP 8-node brick, trilinear displacement, trilinear pore pressure, reduced integration (Section 22.1.4)
C3D8RPH 8-node brick, trilinear displacement, trilinear pore pressure, reduced integration, hybrid, constant pressure (Section 22.1.4)
C3D8RT 8-node thermally coupled brick, trilinear displacement and temperature, reduced integration, hourglass control (Section 22.1.4)
C3D8T 8-node thermally coupled brick, trilinear displacement and temperature (Section 22.1.4)
C3D10 10-node quadratic tetrahedron (Section 22.1.4)
C3D10E 10-node quadratic piezoelectric tetrahedron (Section 22.1.4)
C3D10H 10-node quadratic tetrahedron, hybrid, constant pressure (Section 22.1.4)
C3D10M 10-node modified tetrahedron, hourglass control (Section 22.1.4)
C3D10MH 10-node modified quadratic tetrahedron, hybrid, linear pressure, hourglass control (Section 22.1.4)
C3D10MHT 10-node thermally coupled modified quadratic tetrahedron, hybrid, linear pressure, hourglass control (Section 22.1.4)
C3D10MP 10-node modified displacement and pore pressure tetrahedron, hourglass control (Section 22.1.4)
C3D10MPH 10-node modified displacement and pore pressure tetrahedron, hybrid, linear pressure, hourglass control (Section 22.1.4)
C3D10MT 10-node thermally coupled modified quadratic tetrahedron, hourglass control (Section 22.1.4)
C3D15 15-node quadratic triangular prism (Section 22.1.4)
C3D15E 15-node quadratic piezoelectric triangular prism (Section 22.1.4)
C3D15H 15-node quadratic triangular prism, hybrid, linear pressure (Section 22.1.4)
C3D15V 15 to 18-node triangular prism (Section 22.1.4)
C3D15VH 15 to 18-node triangular prism, hybrid, linear pressure (Section 22.1.4)
C3D20 20-node quadratic brick (Section 22.1.4)
C3D20E 20-node quadratic piezoelectric brick (Section 22.1.4)
C3D20H 20-node quadratic brick, hybrid, linear pressure (Section 22.1.4)
C3D20HT 20-node thermally coupled brick, triquadratic displacement, trilinear temperature, hybrid, linear pressure (Section 22.1.4)
C3D20P 20-node brick, triquadratic displacement, trilinear pore pressure (Section 22.1.4)
C3D20PH 20-node brick, triquadratic displacement, trilinear pore pressure, hybrid, linear pressure (Section 22.1.4)
C3D20R 20-node quadratic brick, reduced integration (Section 22.1.4)
C3D20RE 20-node quadratic piezoelectric brick, reduced integration (Section 22.1.4)
C3D20RH 20-node quadratic brick, hybrid, linear pressure, reduced integration (Section 22.1.4)
C3D20RHT 20-node thermally coupled brick, triquadratic displacement, trilinear temperature, hybrid, linear pressure, reduced integration (Section 22.1.4)
C3D20RP 20-node brick, triquadratic displacement, trilinear pore pressure, reduced integration (Section 22.1.4)
C3D20RPH 20-node brick, triquadratic displacement, trilinear pore pressure, hybrid, linear pressure, reduced integration (Section 22.1.4)
C3D20RT 20-node thermally coupled brick, triquadratic displacement, trilinear temperature, reduced integration (Section 22.1.4)
C3D20T 20-node thermally coupled brick, triquadratic displacement, trilinear temperature (Section 22.1.4)
C3D27 21 to 27-node brick (Section 22.1.4)
C3D27H 21 to 27-node brick, hybrid, linear pressure (Section 22.1.4)
C3D27R 21 to 27-node brick, reduced integration (Section 22.1.4)
C3D27RH
以上是ABA STANDARD的三维实体单元,除了轴对称等其他单元。
楼主可以采用其他单元类型近似模拟,比如5面体单元,你赋给六面体单元
*element=c3d8
element number,node1,node2,node3,node4,node5,node5
其中有两个节点是相同的。
如果这个方法不行,我也不知道有啥方法了 呵呵 |
