查看: 219|回复: 2
Siemens Femap Velocity Webinar Series
发表于 2009-5-14 02:05:22 | 显示全部楼层 |阅读模式 来自 美国
大家有兴趣可看看:
What you will see and learn:
In this short presentation and demonstration, we’ll open with an introduction to Femap, the high-performance Finite Element Analysis (FEA) modeling software solution within the Velocity Series portfolio from Siemens PLM Software. Then we’ll dive in to how you can model smarter products in Femap.
What you’ll learn:
• Import data from multiple CAD sources • Geometry treatment and model detail management • Accurate and robust meshing techniques • Assembly modeling accurate component interaction • Accurate load and boundary • condition representation
Modeling Smarter Products with Femap for FEA
Date: Thursday, May 14, 2009
Time: 2:00 PM EDT
Duration: 60-minutes
http://w.on24.com/r.htm?e=142113&s=1&k=803F8390E7E83A65FAF6EE63687206CD
Audience members may arrive 15-minutes in advance of this time. Attend the event at the link provided above.
Important: System Setup & Compatibility Check
Test the computer that you will be using the day of the event and make sure you have the minimum technical requirements to attend this event. Allow sufficient time prior to the event for this test. Test at
http://webcast.on24.com/view/help/ehelp.html.
Siemens PLM Software, a business unit of the Siemens Industry Automation Division, is a leading global provider of product lifecycle management (PLM) software and services with 5.5 million licensed seats and 51,000 customers worldwide. Headquartered in Plano, Texas, Siemens PLM Software’s open enterprise solutions enable a world where organizations and their partners collaborate through Global Innovation Networks to deliver world-class products and services. For more information on Siemens PLM Software products and services, visit
www.siemens.com/plm.
发表于 2009-5-15 09:51:48 | 显示全部楼层 来自 辽宁大连
这个要注册
 楼主| 发表于 2009-5-19 21:21:38 | 显示全部楼层 来自 美国
2# 虫二
随意注册的,留个E_MAIL就行了,
Mike Paludan  讲的, 有问题可现场提问.
把材料下载了,给大家分享.
GMT+8, 2026-1-6 12:15 , Processed in 0.029459 second(s), 12 queries , Gzip On, MemCache On.
