- 10
- 2008-8-26
之前曾看到“ABAQUS6.9新功能”帖子中说“ABAQUS6.9新功能这次了解到ABAQUS具有专门的实现多机并行计算的模块,……”
我按照以前设置并行计算的方法测试了一下,用两台工作站在64位Linux下并行计算,测试结果如下:
whu@workstation-A:~> /ABAQUS/6.9-1/exec/abq691.exe verify -parallel
Abaqus Product Install Verification...
Thu Jun 25 17:06:22 2009
Running system requirement checks.
Requirement: SuSE 9.3, 10.0, 10.1, 10.2 or 10.3, SuSE Enterprise Linux
9.0 or 10.0, SuSE Enterprise Desktop 10, Red Hat Enterprise
Linux 4.0 or 5.0, or Fedora Core 6.0
Product: All Abaqus Products
Status: Pass - Found openSUSE 10.3 (X86-64)
Requirement: GNU Lib C 2.3.2 or greater
Status: Pass - Found GNU Lib C 2.6.1, which was installed with
glibc-2.6.1-18.rpm.
Requirement: Linux Kernel 2.4.20 or newer
Status: Pass - Found Linux Kernel 2.6.22.19-0.1-default.
Requirement: GNU Compiler Suite 3.2 or later
Product: Abaqus make utility with C++ and Abaqus make utility with
Fortran and Abaqus with user subroutines
Status: Pass - Found gcc version 4.2.1
Requirement: Intel C++ Compiler 9.1 or 10.1
Status: Fail - Unable to locate or determine the version of a C++
compiler on this system.
Requirement: Intel Fortran Compiler 9.1 or 10.1
Product: Abaqus make utility with Fortran and Abaqus with user
subroutines
Fortran compiler on this system.
Requirement: HP-MPI 02.02.05.01
Product: Abaqus analyses using MPI-based parallelization
Status: Pass - Found HP-MPI 02.02.05.01.
Requirement: Mesa 4.3.0 or greater
Product: Abaqus/CAE and Abaqus/Viewer
Status: Pass - Found Mesa 7.0.1
Requirement: X server must be configured to use OpenGL.
Status: Pass - X server is configured to use OpenGL.
Requirement: Mozilla 1.2, Firefox 1.0.1, or greater
Product: Abaqus Documentation
Status: Pass - Found Firefox 2.0.0.6
Making /home/whu/verify. All verification files will reside in this
directory.
Abaqus analyses using parallelization
Running MPI-based parallel with 16 cpu(s)
Basic communication
...PASS
Abaqus/Explicit domain-level parallel
...PASS
Abaqus/Standard parallel with iterative solver
...PASS
Abaqus/Standard parallel with direct solver
...PASS
Running thread-based parallel with 16 cpu(s)
Basic communication
...PASS
...PASS
Abaqus/Standard iterative solver
...PASS
Abaqus/Standard direct solver
...PASS
Continuing...
Clean-up...
Verification directory /home/whu/verify has been deleted.
每个都顺利通过,不知道那个“专门的实现多机并行计算的模块”如何使用,等有时间仔细看看帮助文件再和大家交流。2 X* |6 u% P0 l* N, B ? |
